Come in for a FREE tune!!!!
Old Mar 26, 2008 | 11:52 AM
  #351
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Re: Come in for a FREE tune!!!!
Sorry i dont think the XDF file i have has these tables, how do i add tables? Do you have some step by step or screen shots to show me.
Old Mar 27, 2008 | 08:33 PM
  #352
91skybluez28's Avatar
Car: 1991 convertible z28
Transmission: standard
Axle/Gears: stock
I want to thank you for responding to my question about tuning yourself vs taking it to a pro. I didnt realize that a pro could not get it right and that it was expensive. To answer youre question about my mods the owner before me did several things but I still havent figured out every thing he did, dont think he did much because the car is lazy off the line but it does want to take off when I get pass 50 mph. For some reason it has a 1987 rear end and my car is a 91. Can anybody tell me anything about this rearend? Sorry for sloppy spelling and these ignorant questions. I love these cars I just never realized how much technical stuff is involved. Also I dont think my tranny is slipping but my gear shifts are realy prelonged or should I say in between shifts are prelonged. Is the car just old, need a tune up, maybe my timing is off. I know this question is very generic and it could be anything but any help would be apreciated.
Old Mar 29, 2008 | 01:31 PM
  #353
RBob's Avatar
Car: check
Engine: check
Transmission: check
Open TP and read inthe XDF you want to change. Move the mouse pointer (caret) onto the left side within the selection boxes. Then right click. You can then add, edit, delte, copy, etc. an item.
RBob.
Old Mar 31, 2008 | 07:30 AM
  #354
xjcamaro89's Avatar
Car: 1989 Camaro RS
I could get to the point where i add a new item, its filling in all the information for a new item and all that stuff.
Old Mar 31, 2008 | 03:05 PM
  #355
Axle/Gears: stock
Anybody?
Old Nov 20, 2008 | 09:11 PM
  #356
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
So is this where i post my datalog tables?
Old Nov 21, 2008 | 07:13 AM
  #357
xjcamaro89's Avatar
Car: 1989 Camaro RS
Yep
Old Nov 21, 2008 | 09:22 AM
  #358
Ronny's Avatar
If it is a lengthy datalog you need to zip it.
Old Nov 21, 2008 | 12:17 PM
  #359
Car: Camaro RS
So i used winaldl to datalog last night i am pretty sure i did it right. what files should i post exactly because there is the latest and average and whatnot on some of them?
Old Nov 21, 2008 | 12:49 PM
  #360
Ronny's Avatar
I will vote latest! That may disallow some earlier data however. Wide average I believe uses all. Engine should be fully heat soaked befor you datalog. Regardless you will see trends.
Old Jan 15, 2009 | 01:49 AM
  #361
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Hello guys my name is Dmitry ,Im from Kiev Ukraine.
Some of you I sent this message by private message
I am sorry for an anxiety,but i have problems with my bin on my Firebird 91 350.
I put 350 TBI L05 engine in firebird 91
Then install new Ported Gm Perfomance 12558060 64cc 170 Vortec Head
Speed Pro +0.20 pistons and rings
Edelbrock Non EGR Vortec Intake,Comp Cams camshaft CCA-08-500-8 with 206/212 spec + springs, lift 480/488 112degrees.
Holley 506-2 670CFM truck TBI with 68lb injectors. set fuel pressure to 1.2bar , timing to 10*
Fuel Pump is new BOSCH similar like Perfomance Walbro
180 degrees thermostat , Engine has shorty headers , 3'flowmaster exhaust
700r4 transmission and 3.23 gear posi
But i have very serious problem with tune up stock bin of former L05 engine ECM is 1228746.
My engine wont work properly here is the history;
At cold:
have a misfire to Intake maniford when i push pedal over 60%
Idle speed is about 1100RPM
If i push pedal shortly she its run great.
When i push pedal to a full thorottle , she is thinking about second then fire up to intake and then start acceleration
When the temperature about 170 idle is very bad , have black smoke not answering on push pedal at all and stops
Starting engine again , idle is much more good after she heatup to 200-210' she is run great but stil have ,misfire in full throttle.
Sometimes ECM have fault code RICH mixture but spark plugs is clear (like when poor mixture)
ECM is 1228746 i use 29C256 microchip
TPS is new
MAP is new
Knock Sensor is new
Lambda is new
Ignition Control module is new
i use 95 octane gasoline
Maby someone have engine with similar tech specs and can help me to modify my bin. or send my his bin and i will try it on my engine.
Or you have friends with engine like my and i can copy their bin
my email is elmagnificodima@gmail.com or forzadma@bigmir.net
P.S someone can approximately told me how much HP i have at this engine?
Anyway thanks for help.
Dmitry
File Type: zip
Old Jan 15, 2009 | 02:13 PM
  #362
Ronny's Avatar
Quote: But i have very serious problem with tune up stock bin of former L05 engine
You need to begin studying the stickies right now and consider datalogging engine. You situation is exactly mine 4 years ago. After the datalog then comes the edit of your .bin. that process of datalogging and modifying the .bin will take some time. Each edit/burn will get you closer. A WB02 sensor/controller is very helpfull. It can be done mail order but that may not be practical.
Old Jan 15, 2009 | 02:28 PM
  #363
xjcamaro89's Avatar
Car: 1989 Camaro RS
Ditto. Run your car and see what happening with the datalogging. You will also need the equipment to burn new chips if you dont have it all ready. The beginning of this thread should help you out alot getting you set up to do what your looking to do. It does take a little time, but its not that difficult. Let us know if you need anything else.
Old Jan 16, 2009 | 01:06 AM
  #364
Dmity Kiev's Avatar
Car: Firebird 91
I have programmer for burning chip about 3 month, i replace 2732 microchip to 29C256. burning is not a problem i have problems with coorectly change parameters in bin. in few days i will complete my ALDL cable , and when my car will stand on wheel again (im buy new wheel in us and waiting for delivery) i will data logging. at this moment i completely understand how to change VE1 VE2 table, im reading tuning guides here. and soon i will be have a lot of qustions about few parameters if you dont mind. thanks
Old Jan 16, 2009 | 07:06 AM
  #365
xjcamaro89's Avatar
Car: 1989 Camaro RS
Sounds like you have everything you need then, we will be able to help you once we see some datalogs and your bin that your currently using. Keep in touch.
Old Jan 23, 2009 | 01:35 AM
  #366
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
95 Octane! Wow, we can only get up to 92 here. I would think that 95 is overkill for that. Can you get 89-91? I think that would be better unless you are running high compression and aluminum heads.
I am running 92 right now, but will experiment with 89 after I get it tuned in.
Get a WB o2 sensor. It is worth it's weight in gold when it comes to tuning.
Old Jan 23, 2009 | 11:18 AM
  #367
Ronny's Avatar
95 octane. may be E85? available here in WI. WE have E10-E20-E85 and LEADED PREMIUM and race gas($$$$) all at pump.
Old Jan 29, 2009 | 01:13 AM
  #368
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
the tuner pro link is not working. I tried the tuner cat but didnt find a 91' 5.0 305 tbi lo3. Would that be the same as th 88'?
Old Jan 29, 2009 | 05:32 AM
  #369
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
CAUTION right there! octane is rated different over here (europe). we are using a rating called "Research Octane Number" whereas in the US, Canada you are using "Motor Octane Number" or mostly "Anti-Knock Index", which is RON+MON/2 iirc.
common rating numbers over here are 91, 95, 98 and 100 (RON). these would translate to about 87, 90, 92 and 93-ish (AKI). also use caution for the amount of ethanol used in gasoline as it will influence knock resistance.
you can find info about the various octane ratings on wikipedia or similar.
so, overall we are using about the same ratings for "regular", "plus" and "premium".
WTH you still have leaded for sale? or is that just unleaded gas with a very high rating? I thought EPA banned from the streets already a decade ago..
i think in europe the maximal allowed addition of ethanol is 5%.
Old Jan 29, 2009 | 09:09 AM
  #370
Ronny's Avatar
Leaded.
And the 89-92 F body uses same ECU 8746 Mask $61. Bins vary particularly for manual vs auto trans. Make sure you have trans covered. CA has a special bin too I hear.
Old Mar 19, 2009 | 08:22 AM
  #371
Dmity Kiev's Avatar
Car: Firebird 91
Hello again , at last we have a good weather here in ukraine and i can use car every day. Im trying to do some work with bin like BMonte tells to XJ , i have 16136965 ECM with v62 mask.I start edit few days ago, i calculate BPC and get 103 , i checked all BPC parameters on car fp is 18 psi now , #65 injectors , holley 670CFM TB , 206/212 480/488 comcams camshaft,GMPP vortec intake , GMPP iron vortec heads.Headman headers 3' exhaust. I have i 15 miles long good highway and dataloging today. here is my bin , and logs.
I up TPS treshhould to 70% , PE AF to 12.5 like Bmonte says . set #VE2 800-2800rpm to 15.63 . now i will edit the table and put TCC upper and lower from AXBF , becouse ECM is from caprice and for birds TCC is others. What next steps should o do ?
File Type: txt
File Type: txt
File Type: txt
Old Mar 19, 2009 | 10:14 AM
  #372
Ronny's Avatar
BLM data shows ECU is adding fuel pretty much across the board. wide average and wide latest.
I never understood how to read the LOG.txt. Need to export or something?
all I see are columns of numbers I cannot line up to titles?
Old Mar 19, 2009 | 01:24 PM
  #373
Dmity Kiev's Avatar
Car: Firebird 91
few hours ago i reedit VE table and drive home its about 15km with huge traffic.
when engine is start at cold (weather is rainy and temp is around 5-6C) idle is bad , after few pushings on pedal its much better , when the car is hot idle speed at parking around 1000rpm , on drive about 800-850. few times shes trying stops with error code HIGHT MAP but if put rpms to 2000 and hold on 5-10 sec error code is gone and work ok.
here is my new BLM , blm shows that the mixture is rich and need to reduce some cells. My question is when and how i need to set some compensation for good cold start ?
File Type: txt
File Type: txt
File Type: txt
Old Mar 19, 2009 | 10:48 PM
  #374
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have not seen a $62 hack, but you need to find out from someone who works with that ECM where the HIGH MAP trouble code threshold is at. Once high map at idle is present, the ECM will revert to limp home mode and run terrible.
Old Mar 20, 2009 | 12:30 AM
  #375
Dmity Kiev's Avatar
Car: Firebird 91
At idle MAP pressure is around 45 Kpa , in drive almost all time 55-60+Kpa , its bad? today i will try to put another MAP sensor from LT1 and see what happening
Old Mar 20, 2009 | 03:16 AM
  #376
Dmity Kiev's Avatar
Car: Firebird 91
Here is the bin that i edit last night , BLMs with this bins , i drive around 1 hr in the city and by highway.
File Type: txt
File Type: txt
File Type: zip
Old Mar 20, 2009 | 07:41 AM
  #377
Dmity Kiev's Avatar
Car: Firebird 91
I edit a bin , and cope XJ VE2 table to my bin and drive again , so here is last blm's and logs. as we see blm's is around all blm is around 128 but i have error code O2 rich few times , and then its gone. maby ats a mistake to put XJs VE2 ? but i think my original VE2 table is very bad. what i need next to do ? how edit VE2 it has one % for ich rpm and BLM counts for map 40-50-60-70 etc , and if i see that blm in this windows is different , how to choose right blm from table foir VE2 ------------------------------- using a XJ VE2 was a mistake , she is really rich so i hold my parameters now and revutn to , tell me please how correctly edit VE2 . next sper after VE2 is slightly up SA ?
Old Mar 20, 2009 | 08:25 AM
  #378
Dmity Kiev's Avatar
Car: Firebird 91
so i will try log a 14ver of my bin when drive home
Old Mar 21, 2009 | 04:39 AM
  #379
Dmity Kiev's Avatar
Car: Firebird 91
Guys i have the same problem like this guy https://www.thirdgen.org/forums/tbi/...s-new-cam.html i have 206\212 Comp cams computer compatible camshaft. at idle after few min of working car trying to die and SES is Hight Map pressure . whats can be wrong ? i try two IAC and twi MAP sensors problem not gone .... i think a cant datalogging and edit VE tables right until i have this problem
Old Mar 21, 2009 | 07:59 AM
  #380
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, went through the $62 code this morning and I am fairly sure that this is the correct location for the MAP high threshold. Will need to either add it to the XDF file or edit the BIN directly.
You need to increase the value by at least 10KPa. The BCC I looked at has it at 67.9 KPA. So increase it to 77 - 78 KPa and see if that does the trick.
The location is $46A
The conversion is: KPa = N * .369 + 10.415
RBob.
Old Mar 21, 2009 | 04:10 PM
  #381
Dmity Kiev's Avatar
Car: Firebird 91
I add this function to XDF can you check im do it right ?
I put it to Constants "MAP High threshold" old constans was 156 = 67.97 Kpa , i set it to 184 = 77.57 Kpa. I will try it monday morning.
File Type: zip
Old Mar 21, 2009 | 06:27 PM
  #382
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Very familiar with the High MAP code though. Many thanks to Rbob for going through $62 in search of that threshold. I will have to update my XDF for $62. Just in case I decide to tune a B-body someday.
My 305 TBI build had a Crane HR-276-2S-12 IG in it (276/284 @ .004, 214/222 @ .050, .488/.509" lift, 112 LSA) and idled with only 11 in/hg of vacuum in drive @ 700 rpm. I found that my engine LOVED advance at idle, around 32* is where it seemed happiest.
Old Mar 23, 2009 | 05:11 PM
  #383
Dmity Kiev's Avatar
Car: Firebird 91
Thanks Rbob you feature is really work! I dont have any high map error . will datalog tommorow
Old Mar 25, 2009 | 02:23 AM
  #384
Dmity Kiev's Avatar
Car: Firebird 91
Here is my morning bin, log, BLM table , why she always wants to lean ? this is normal? and if you see i have small SA in 30-65 Kpa and 2000-3600 rpm , should i rise them now or ofter my VE1 table wii be close to 128 is all cells?
File Type: txt
File Type: txt
File Type: txt
Old Mar 25, 2009 | 08:52 AM
  #385
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the BLM's lower then 128 the engine is running rich. The BLMs are removing fuel to bring the AFR back to where it should be.
Is the EGR active? There is a separate table of BPC values that are used when the EGR is on. Also note that there is a closed throttle VE table.
RBob.
Old Mar 25, 2009 | 10:04 AM
  #386
Dmity Kiev's Avatar
Car: Firebird 91
I dont have EGR at all. All Shoult i set to zero constants EGR on off (speed) , (Tps) , (Low Map) ?
Old Mar 26, 2009 | 08:02 AM
  #387
RBob's Avatar
Car: check
Engine: check
Transmission: check
Should disable the EGR in the calibration. Can usually set the enable temperature at the maximum value.
RBob.
Old Apr 1, 2009 | 01:47 PM
  #388
Dmity Kiev's Avatar
Car: Firebird 91
Hello i disapointed , BLMs says to me to lean VE1 but my car wont drive with those calibrations, idle is little rich , acceleration is very bad , like a 10ton trailer behing , and very very important problem that i have at all bing , even stock AXBF after idle shes wont accelerate at all and die, when i put pedal more than 20% quickly shes try to start something,when i put pedal slowly from idle shes die. first of all i think this is fuel pump , but its work great fuell pressure is 1.2 at idle and not down, i try 2 TPS , try to set TPS to 5%-10% at idle nothing help. I look to impulses on ingectors whtn i trying up RPM on inde or start driving and there is no fuel, O2 is shows 0.03 when she try to die , but BLM says lean the mixture WTF. i try to set main spark to 4-10-14 ... nothing , put new spark plugs ... nothing , use external fuel pump ... nothing , use new TPS ... nothing changed . rise , unrise SA table ... nothing . I hate my TBI
File Type: txt
File Type: txt
File Type: txt
Old Apr 1, 2009 | 02:58 PM
  #389
Ronny's Avatar
fuel pressure 1.2 lbs? I think that is a type-o you meant 12 lbs.
BLM is rich but that is not a big issue for now.
You are using a Vortec spark table I presume but that should not prevent you from getting it running decently.
By pressing pedal 20/% the engine is getting more fuel(aka pumpshot or AE) and it comes alive only to fail after the fuel is used. Seems you need more fuel in VE tables. Sounds like you are OL at idle but that is not a big deal.
See later posts in "come on in free tune" for similar issue posted.
Old Apr 1, 2009 | 03:10 PM
  #390
Dmity Kiev's Avatar
Car: Firebird 91
sorry my FP is 18psi
Old Apr 4, 2009 | 12:32 PM
  #391
Dmity Kiev's Avatar
Car: Firebird 91
Guys I am disappointed in my TBI nothing helps ... i try to use few different start bins , and always the same ... on datalogs BLM is 108-120 in all cells even when i reduce,reduce,reduce VE1 table to 10-30 , i try different BPC constant from 80 to 130 ... nothing changed after few datalogs she still want 108 but dont want to drive at all and o2 sensor show that mixture is LEAN and BLMs think that is RICH how it can be? 02 sensor work good only when car is stoped at "D" O2 jumped from 0.2 to 0.8 . In park its 0.8 most time , in slight acceleration is 0.02.... I try to up and down spark tables ... nothing , I changed AFR to stock L05 bin ...nothing. I up and donw map treshould ... always the same...I burned tons of fuel and dont have anything , my can is wont drive , smell, smoke, on cold idle is bad.
i know that i have not popular 6965 ECM but i cant find help here .... what shoul i do ? Im thinking about swap this fckn TBI to carb i will zip few bins and on every been with any BPC she want lean . Help me something , maby someone have bin for my specs ? . we have another idea WHAT will happen if we block BLM and build VE ans SA table on WB O2 sensor ?
File Type: zip
Old Apr 4, 2009 | 09:06 PM
  #392
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I happen to have the fuel and timing tables I ran with a GM "845" camshaft (214/222* @ .050, .488/.509" lift, 112* LSA), dual plane intake, and ported 062 vortecs. It was in my van with a 2,600 rpm stalled 700r4 and 3.08 gears. I copied the tables into you .bin and did the best at looking over your current settings. They seem decent enough. I will not claim this to be perfect, but it should be a better start than the stock TBI Caprice 9C1 calibration. I would give you the whole .bin that I ran, but it was setup on a "299" ecm running $99 and it is way different.
File Type: zip
Old Apr 5, 2009 | 01:19 PM
  #393
Dmity Kiev's Avatar
Car: Firebird 91
Thanks a lot Fast! i will try it tommorow
Old Apr 6, 2009 | 03:41 AM
  #394
Dmity Kiev's Avatar
Car: Firebird 91
Also question about BPC , why in last XJ's bin its 138 ? if he use 350 with Holley TB with 65 . I calculate by injectorsize.xls for this site and have 103-105 .I use Holley 670 have 65lb/hr injectors ,standart FP for this stock motor is 10 psi - I have 1.2 bar = 17.4 psi so my BPW (BPC) should be 101,4 ? Im asking this becouse early , few days ago when i first have a problem with die at part trottle i put 101 in bin shes rich by BLM but lean by O2 , when i up to BPC(BPW) 120-130 shes drive normally ar part trootle but got wery rich by all cells and smoke around.
If XJ set it to 138 how its car work correctly?
Today i will try bin that Fast355 gave me mich 105 BPW(BPC) and will see
Old Apr 6, 2009 | 10:40 AM
  #395
Ronny's Avatar
65 lbs at 17.4 lbs FP for 350 cid at 90% DC at .45 BSFC I show BPC at "114"
Old Apr 6, 2009 | 04:38 PM
  #396
Dmity Kiev's Avatar
Car: Firebird 91
Hello. Thanks to Fast355 < bin that you gave to me work much better , after few hours drivin , BLMs are from 114 to 126.6 (but not 115 in all cells ) I think my BPC is too high , i reduce it from 105 to 102 and retune VE1
Old Apr 6, 2009 | 05:20 PM
  #397
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You want a BLM reading of 126-130 or so. Not quite sure what you mean by not 115 in all cells since you should be targeting 128. Your BPC if anything is a little low...you would want to raise it a little. Honestly BPC is just a number, the only reason to raise it would be if you were starting to run out of room on the VE table. I was not sure which injectors you were running or the fuel pressure, so I just used what I thought was close.
Old Apr 11, 2009 | 10:59 PM
  #398
Dmity Kiev's Avatar
Car: Firebird 91
Hi. I make dataloging every day last week , car run much more good it have some power , and i have a little problem with it only when engine temp is around 80 C' (i think when thermostat opening) she's have no throttle response and shes Sneezes this happens only from 78-84 C' when warmed up everything is ok. here's my latest bin , I run with it about 15 min by highway and 10 min in the city stop engine save BLM , then run it again and went home 10-15 min through city and have some little different BLM. I so understand that it related to the modes of engine work at highway and city?
Also please look at my SA table , can i rise it up in 80-100 MAP for better Acceleration ? or it is high now ?
File Type: txt
File Type: txt
File Type: zip
Old Apr 11, 2009 | 11:27 PM
  #399
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You have 43* total advance at high rpm, which is WAY too much. I would limit the advance to 28-32* total timing @ 85+ KPA and WOT. Vortecs really will not need more than 32*, MAYBE 34* total timing. Keep in mind they have a fast burn chamber and increasing the timing further will only slow you down. Use my original timing table as the upper limit for 85-100KPA region. Feel free to experiment with bringing in advance quicker. My spark map was based on a heavy van with tall gearing and a stock torque converter that would knock if the timing was brought in too early.
As far as the sneeze, it looks like the AE Correction vs. Coolant temperature table is removing ALOT of AE in the trouble area. I would flatten the table out and level it out at 1.00 through the top.
The BLM numbers show you are a little lean through the loaded operating region. When you are tuning BLM you should drive with slow, steady throttle changes, and try to reach many different RPM/Load values. Time and distance is your friend here. The longer the trip, the bigger data sample you will have, and the more accurate your changes will be. My tuning on my van was once based on a weekend 80 mile trip which is now 85 miles.
Old Apr 12, 2009 | 11:01 PM
  #400
TXBowTie40's Avatar
Not trying to detract from or hijack, but wanted to ask Fast if the bin files on Moates site are from your engine when you had the Vortec heads and ZZ4 cam in it?
Still waiting on my heads to get out of the machine shop, have been looking over bins and .xdf files on TunerPro, trying to decide which would be the best starting point, and yours seemed like it might be the closest to what I am gonna be running.
I can load a $0D coded chip into my '8625 PCM and it will work, correct?
