tuning troubles with new cam?
Old Sep 27, 2006 | 12:39 AM
bluechevy194's Avatar
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
hey guys just recently got time to install this cam, Lunati Voodoo Cam and Lifter Kits: LUN-60103LK - summitracing.com , into my tbi truck this is alot more agressive than my previous one, the problem i am having is getting the thing to run in drive. it has a pretty cosistant idle in park, when in park IAC counts are around 30-40, a vaccum of 60 kpa at 725 rpm, BLM of 127, tryed messing with the timing from 20-35 degrees of total timing at idle, but everytime i put it into drive it runs fine for about 30 sec. then dies, whats strange is that it doesnt bog or sputter, it just dies as if someone turned of the key. really stumped, never came across this before? even turning the idle to about 850, but still doest same thing?
Old Sep 27, 2006 | 07:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Turning the TB idle screw in for 5 - 10 IAC steps in park will help.
If non-swirl heads running idle SA of about 24 degrees should be good.
After that hard to say without seeing a data log. Which ECM is this?
RBob.
Old Sep 27, 2006 | 09:13 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Check your ECM for trouble codes. Make sure that you are not getting a MAP high code at idle. I was having the same problem with my L82 cam and the stock 7747 ECM. I forget which location it is, but RBob could probably pull it right off the top of his head. I ended up having to adjust it to a MAP high error of around 80 KPA or so. Stock it is like 45 or so. If you idle for long enough, above 45 KPA, it sets a MAP high code, my limp-home mode was so far off(4.3 Astro TBI ecm), it would surge once, then quit running. It would sit and run all day with the transmission in Park/Neutral. It would run great as long as I was moving. Stop and sit, it would just die. Finally ended up just checking for codes and found MAP high.
Old Sep 27, 2006 | 04:37 PM
Car: 92 c1500
Engine: 355ci
right now i am using the stock ecm, 16146299, would i be better off using a 7747, i have one. i dont think the one i am using now has a MAP high error table. i also noticed the 7747 has alot more tables.
Old Sep 27, 2006 | 05:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 16146299 and the '7747 share the same hardware. It is the code that runs the engine is different between the two. Not being familar enough with the '6299 code, I can't say which one of the two is better. The '7747 does have the advantage of being better known, which allows for easier tuning.
RBob.
Old Oct 1, 2006 | 05:42 PM
Car: 92 c1500
Engine: 355ci
i tryed 7747, i've been messing with it for the past two days and it still does the same thing, the only other thing i was told it could be is my stall might not be big enough, could this have anything to do with it? I have a 2000 stall, the cam called for a 2400.
Old Oct 1, 2006 | 09:06 PM
Car: 92 c1500
Engine: 355ci
anyone?
Old Oct 2, 2006 | 12:08 AM
Car: 92 c1500
Engine: 355ci
just found out it also dies when shifted into neutral.
Old Oct 12, 2006 | 11:29 PM
GreenManalishi's Avatar
Car: 95 Burban
Engine: 350ci
Transmission: 4l80e
Axle/Gears: 4.56
The specs on that cam list that it is not computer compatible. I'm guessing your having issues with the 110 center lobe on it. I just installed a Comp Cams 12-262-4 Camshaft Specifications and had no issues at all with pretty much the same specs with the exception of the center lobe.
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
Thirim
Aug 13, 2015 03:09 PM
355tpipickup
Aug 13, 2015 07:35 AM
