where can I find afpr
Old Mar 29, 2006 | 12:22 PM
RedRS90's Avatar
hey I was just wondering where I could order or go and buy an adjustable fuel pressure regulator for my tbi is there one that I could install in the engine bay right between where the lines come and and where they connect to the lines going to the TBI?
Old Mar 29, 2006 | 02:51 PM
Ronny's Avatar
aeromotive. the unit is installed downstream of the TBI
Old Mar 29, 2006 | 03:10 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Are you looking for an external AFPR with a gauge? IF not the following part numbers will help you.
f you ever need an adjustable fuel pressure regulator to replace your stock non-adjustable one you can get one from AutoZone. GP Sorensen # 800-225. The GM part # on your regulator unit should be 17064317. The GP listing is actually for a 95 GMC pickup 1500 with a 350 tbi. LOL. Crazy stuff. They have exactly the same fuel pressure regulator as our 305/350 tbi's lol, and it is ADJUSTABLE!!!
Old Mar 30, 2006 | 09:09 PM
RedRS90's Avatar
so would that afpr be able to handle the psi and regulate it from the TPI fuel pump I put in........the reason I had put it in originally was b/c that was the plan........to put a TPI system in......didnt happen though. and also were would I find and external one with a gauge.
Old Mar 30, 2006 | 09:12 PM
dctrumpet's Avatar
Absolutely! Your tpi fuel pump will do well in your tbi system. It will handle it well.
Old Mar 30, 2006 | 09:15 PM
RedRS90's Avatar
ok well would you know what the loud clicking is coming from my throttle body.
Old Mar 30, 2006 | 09:24 PM
dctrumpet's Avatar
Tell me more about the clicking noise. Exact location, during idle, etc.
Old Mar 30, 2006 | 10:22 PM
RedRS90's Avatar
its sort of like a fast clicking and you hear it....well right after the car dies. it wont idle, and it starts really rough. a couple times we've messed with it and we got it to idle for quite a while, but as soon as you'd put it in gear, it'd just stop running.
Old Mar 30, 2006 | 10:29 PM
dctrumpet's Avatar
Boy where do we start? LOL. make sure base timing is correct with est disconnected. Then turn car off and connect est then remove the negative battery cable for 30 seconds. Reconnect battery cable and start the car. your timing should be set. Unless you have a bad harmonic balancer or an improper chip for your car, etc.
Not sure what the clicking is in your throttle body.
Did you already post your conversion/mods on another board? if so give me the link so i can read what yo uhave already done so far.
Make sure firing order is correct. make sure that the distributor is set in correctly and that the rotor points to #1 when at TDC.
Boy a ton of stuff could be causing your idle problem. EGR valve and or solenoid bad. MAP sensor bad etc.
Bring me up to par on your car. All the mods done etc. Parts replaced? etc
Old Mar 30, 2006 | 10:38 PM
RedRS90's Avatar
lol I dont even nkow where to start anymore. It started out as a 305 TBI, Then I spun a bearing in it......So we decided we were going to put a 350 in it.......so we did all that, but not before my bro wanted to rip out all the smog stuff.......he already ordered headers for it, without the plug inserts.... newayz engine goes back in. little problems here and there, one major ones, is after I put the wiring harness back in, none of the gauges except for the tach and the gas gauge worked. sometimes the speedo would bounce...odd, its all electrical its a 90 camaro by the way......neways I drove it for about a month before it just stopped running.....didnt know why, it just did
Old Mar 30, 2006 | 10:45 PM
RedRS90's Avatar
lol I dont even nkow where to start anymore. It started out as a 305 TBI, Then I spun a bearing in it......So we decided we were going to put a 350 in it.......so we did all that, but not before my bro wanted to rip out all the smog stuff.......he already ordered headers for it, without the plug inserts.... newayz engine goes back in. little problems here and there, one major ones, is after I put the wiring harness back in, none of the gauges except for the tach and the gas gauge worked. sometimes the speedo would bounce...odd, its all electrical its a 90 camaro by the way......neways I drove it for about a month before it just stopped running.....didnt know why, it just did. then a couple hours later it decided to run again.....again not sure why but it did, for a week I think if that.....then it died again. well then I got it towed and let it sit for another month before I got around to looking at it. well I decided that it wouldnt start and I didnt know why......replaced my ESC module under the distributor and it would at least spray gas and turn over then. but then it wouldnt idle or anything. and thast where I was at....now I bought bigger injectors, and the knock and esc module were already for a 350, as well as the maf sensor I think thast what it is right? once though we saw a big spark in the engine bay b/c I didnt have a good ground......coudl that by why the gauges dont work.or do you think my ecm is fried..oh and also.....one problem we had is I never was able to get the oil pressure switch in to the side of the block, some stubborn plug that we didnt notice till the engine was in and the headers were on.......but it ran for that whole time it wasnt in it. Also during the tiem it ran, it would start....idle hard for like 30 seconds blowing black smoke, then it would smooth out.....and sometimes at a stop it'd shut off, but it would start up again......but that was before it actually shut off and wouldnt come back on. sorry I know thats alot of jumping around.
Old Mar 30, 2006 | 10:52 PM
dctrumpet's Avatar
WOW. A lot to think about. Is your oil pressure switch/sending unit in now? Another name for that is fuel pump/oil pressure sender/switch.
Old Mar 30, 2006 | 10:53 PM
RedRS90's Avatar
my unit is out lol, we are redoing a couple things, cleaning it up a little.
Old Mar 30, 2006 | 10:54 PM
dctrumpet's Avatar
Here is a diagram
RedRS90's Avatar
my unit is out lol, we are redoing a couple things, cleaning it up a little. we also think that possibly it wasnt at top dead center.......and the uhhh the balancer, was an old one and it has paint all over it so you cant see the marks, hard to time it the "right" way.
I just looked at your diagram, and wha tI replaced was the EST not the ESC
oh....flattop pistons, mildcam....like, just above stock....couldnt tell you the lift on it..my brother put this block together. and even he couldnt remember
Old Mar 30, 2006 | 10:58 PM
dctrumpet's Avatar
definitely begin with a new harmonic balancer. $49 at autozone. Make sure it matches what's on the vehicle now. Also, get your distributor set correctly to TDC. Vitally important.
You must have that oil pressure switch/fuel pump switch in.
Do those things and see what happens from there.
Well, lol. You will most definitely have to burn a chip according to your engine needs. Cam, heads, etc will change everthing especially your fueling etc. Long ways to go, but it's worth it.
Time to start on the journey of chip burning. DO NOT buy an aftermarket chip. WILL NOT, i repeat NOT work for you at all. You must do custom work.
See moates.com. Start there.
Old Mar 30, 2006 | 11:15 PM
RedRS90's Avatar
I was gonna go to that guy at tbichips.com b/c he said he can burn it to my needs
its a 70's block so I would want one for that right?harmonic balancer I mean.
Old Mar 30, 2006 | 11:16 PM
dctrumpet's Avatar
That should be great!
Old Mar 30, 2006 | 11:19 PM
RedRS90's Avatar
.....and triple post.........do you think that maybe since I didnt have it at top dead center the first time I started it up that eventually it just ****ed it up. hey, another question off topic....if I wanted to disconnect my ac but leave that stuff up by the fire wall alone, what do I have to do. or behind that black plastic is it also firewall.....I think I just want to get rid of it.....which in that case only leaves me with the drive pulley....is that what the pulley on the harmonic balancer is called....and then the water pump, alternator and power steering.
Old Mar 30, 2006 | 11:22 PM
dctrumpet's Avatar
probably didnt mess it up! Not sure about the a/c stuff. Hitting the sack now, but i will check this post sometime tomorrow. Take care
Old Mar 30, 2006 | 11:24 PM
RedRS90's Avatar
also, about that afpr, how do you adjust those, it it just goes back in the stock location....
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Ranbo108
Sep 9, 2015 12:20 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
355tpipickup
Sep 4, 2015 05:32 PM
