Ram air or open air element
Old May 2, 2006 | 06:18 PM
chucknadine's Avatar
Car: 88 FireBird
Engine: 305, TBI
Transmission: 704
Hey everyone, I have a 305 TBI 1988 with the normal stock air filter set up. I was going to either add another snorkel tube to the open side of the air cleaner and then remove my signal lights and re-position them underneath the frame to make a ram air type of system, or should i by an open air element..................which will add the most HP???
Any info would be greatly appreciated........
Old May 2, 2006 | 06:50 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
open elements are very cheap and easy to install, but dont add much if any hp.. the ram air would be a lot better except for maybe the looks of it unless you do it in aluminum tubes or somethin
Old May 2, 2006 | 07:09 PM
Car: 88 FireBird
Engine: 305, TBI
Transmission: 704
Thanks,
I
Thanks,
That's what i figured. I am going to fabricate a dual snorkel setup.........I will post pictures when complete
Last edited by chucknadine; May 2, 2006 at 07:11 PM. Reason: Automerged Doublepost
Old May 2, 2006 | 11:28 PM
dirtfarmer's Avatar
Car: 1991 convertible RS
Engine: Lo3 305 TBI
Transmission: MD8 700RV
Axle/Gears: 2.73OEM to 3.08 posi disk underway
Chuck,
Check out this ram air rig.
https://www.thirdgen.org/forums/tbi/...-cool-air.html
Ron
Old May 2, 2006 | 11:40 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I just put in a dual snorkel air intake, but i havent rigged up any scoops or snorkel tubes. so, it is basically an open air intake sucking in the warm air from the engine compartment.
I would go with some sort of cold air intake, because from a stop (after the air in the engine compartment heats up), the car feels like it bogs. it never did this before, and i'm assuming its because of the warm air in the comparment.
Old May 4, 2006 | 02:03 AM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I'm a hardcore cai/rai fan, but open elements are highly underrated.
the simple removal of the hot air valve(i don't remember what it's called) and the small *** intake entrace at the front of the hood is nothing short of amazing on these cars.
anyway, there are several very old threads on how to effectively make a cai/rai setup, but nobody's come up with an elegant, specific, or easy design.
the best one I've seen to date is to cut your stock air box's arm down to about 2-3" from the box, turn it so it faces front, buy a tpi air box setup for the front bumper, and connect the two via some sort of intake hose. you can take this further by buying the metal inserts for the tpi box from hawks, buying the 1" raised air filter lid from a mid 90's blazer or several other trucks/suv's of the era, or buying a powerbowl(though you can't use both the raised lid and the powerbowl). on top of that, you can buy a k&n(although a firmly believe in amsoil foam filters, flow the same, filter better, and 20 bucks cheaper) filter, just to make sure that you're getting the most air possible. also, if/when you do this setup, make sure you stick with the circle filter as opposed to the two squares, that way you're getting the most out of the ram air effect.
from there you can still do numerous things, such as free tbi mods, an injector spacer, hell, you could get the '83 ram air hood, cut a hole out of the top of the lid, line it with rubber, and stick a piece of foam in it.
the possibilities are endless, the air is there, and so are the parts, it's just a matter of how far you want to go.
personally, everything I just mentioned would look far more appealing, and be far more effective, than removing your side lights.
as for the open element, it's the cleanest look and it's the cheapest, but that's about all it's got going for it, compared to most other options.
Brinkkl2000
Aug 4, 2018 08:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
bryan623
Aug 10, 2015 11:33 AM
