350 4 bolt main?
Car: 86 Trans Am
Engine: 305 with edlerbrock carb
Transmission: 4 speed auto
Axle/Gears: not sure yet!
350 4 bolt main?
What is so special about a 4 bolt main compared to the regular 350?
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by thirdgen88
... instead of two bolts...
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There's just a lot more work involved in that though... If its a 4-bolt main block already, just leave it that way. If its a two-bolt main block, use main cap studs or have it drilled for and use splayed 4-bolt caps..
Car: 86 Trans Am
Great thanks! All good info!!
I'm looking for a winter project to build a 350. My friend has one with the 4 bolt main, don't know what one may be worth. Any Ideas? Its nothing special, average mileage but sittign under a pine tree for 2 years. Filled full of oil and not seized.
I just don't want to run into any problems rebuilding it with it having the 4 bolt main.
Thanks!
Thanks!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Thanks!
Thanks!
Car: 88 K5 Blazer
Engine: 383 stroker, TBI with EBL
Transmission: SM 465
Axle/Gears: Dana 60/14 bolt 4.88
My 383 is 4 bolt, but only because that's what I had, not because I insist on it.
ambainb
Apr 25, 2016 09:21 PM
