need some words of wisdom
Car: 92 trans am clone
Engine: LO3
ok i have an 89 firebird with a 305tbi and 700r4. current mods are wider and stickier tires, 2.5 dynomax cat-back, gutted cat, soon to be hooker 2055's with a y pipe. what else am i going to need yes i know tuning but whats the cheapest way for me to be able to beat an 87 IROC with a L98 motor in perfect running condition and a good driver and it is completely stock.
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
try this thread itll get you in the right direction
https://www.thirdgen.org/forums/tbi/...-tbi-mods.html
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
weight reduction and a 3 or 3 1/2 inch catback with the headers.and of course chip work.
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
3" exhaust with headers, then TBI work, manifold, LT1 or ZZ4 cam, chip tune, then heads then another chip tune, then another, another, another, another, then when you think you've got it just right for your set up 5more. Thats the one part of TBI I hate is having to get computers involved...
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Yes, especially if you start changing parts in the motor such as cam, heads, intake, etc...
To keep up you are going should have full 3" exhaust, Headers, Intake, Cam swap and lots of tuning. Your exhaust will allow full potential performance of other parts.
Your starting with 170HP & 255TQ. You are trying to compete with 245HP & 345TQ. All of those changes should get you close to those numbers. If you want more you need to change your heads and do more serious tuning. By that time it may be cheaper to start with a 350.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by vipershark11
whats wrong with my 2.5" catback from dynomax? is it really going to restrict that much more power than a 3?
Engine: LO3
fast i just read your tbi post with the power that your 305tbi makes is crazy gives me hope that i soon can be somewhere about even if not that.
