Upgrade Ignition system?
Old Aug 3, 2006 | 03:40 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
I was thinking of ordering some new high performance parts to the ignition system.
I was browsing around summitracing and found Taylor wires for the 305 TBI over the valve cover style. I believe they are 10.4mm wires, I don't really have much of a problem with burning my plug wires, the plug wires I have on the car as is are fine but they are old.
I recently replaced my distributor cap and rotor for cheapie ones because I didn't have the money at the time to go out and buy MSD.
But again, as I was searching online I found out that Summit sells a cap/rotor/ICM altogether in a set for like 65-70 dollars I believe.
It's MSD all around, but the plug wires would be Taylors.
This is the part number to the plug wires set, TAY-79238- not only do I think it will clean up my engine bay giving it a more cleaner look, but I believe these wires should have stronger conductors. And the wires themselves may fix any fault I have within the electrical system.
The Distributor cap and rotor kit with the ICM as well is either gonna be this PRO-66945RC
or Summit's own brand SUM-850030
With all of this in set, I should have a much more responsive ignition system then what I have on there now. The reason why I am doing this is to not see if I can gain any power (why would I, they're plug wires) but to free up or give the car a smoother feel to it and more responsiveness.
All in all, the whole thing out the door should cost me about 130 bucks. What do you guys think?
Old Aug 6, 2006 | 10:24 AM
91ChevyRS's Avatar
Car: 1998 Volvo S70
no answers?
Old Aug 6, 2006 | 11:15 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
you main problem will be that that kit is not for our cars. the HEI ignitions with the coil up top apearantly have clearance problembs on our cars, sooo, they put the coil next to the distributor. you'll see a short wire coming off the center of the distributor down to a box thats about half-hidden by the air box, thats our coil. MSD sells a "Blaster" replacement for that. i got one for about 60 bux at autozone, but havent put it in cause, well.. im lazy.
if your ignition system is old, a new set of plugs and wires will definitly help, and a larger set of wires and hotter coil will help make power with future mods as you get more fuel and air in the chamber, but i couldnt forsee an L03 ever needing anything bigger than an 8-8.5mm wire.
also, if you wanna feel somethin from your ignition, try advancing your timing. you'll pick up some throttle response, and it sounds cooler, too. only drawback to that is possibly having to use higher octane fuel (i have to use 93) to prevent knock.
Old Aug 6, 2006 | 05:48 PM
Raiderfan's Avatar
Car: '92
Plus I also have that coil and mine is on the car , anywhoo it made no difference in performence it just made me feel better.
Old Aug 29, 2020 | 03:06 AM
Chogg Ee's Avatar
Re: Upgrade Ignition system?
How did you wire the blaster coil. I have two terminal s on the blaster and two plugs with two wires each on the factory coil. What do I need to wire to get the blaster to work?
Old Aug 29, 2020 | 08:00 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
You use the proper Blaster Coil for your application. Blaster is the product name and the make many different styles for different applications. You can see on the top in the back the 2-2 wire plugs.
Old Aug 31, 2020 | 05:47 PM
George Klass's Avatar
Car: 1989 Trans Am
Can we lock old threads?
Old Aug 31, 2020 | 07:23 PM
Sweatlock's Avatar
Why?
Old Aug 31, 2020 | 07:25 PM
Car: 1989 Trans Am
So 14 year old threads like this dont pop up?
Old Aug 31, 2020 | 07:49 PM
Sweatlock's Avatar
i wasn’t on the forum in 2006 so I wouldn’t have read it if it hadn’t popped up. I found it an interesting read.
I drive a 28 year-old car to work every day, a 14 year-old thread is pretty new to me.
Old Aug 31, 2020 | 08:24 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Six of one, half dozen of the other.
Bump an old thread that's on the topic he needs to know about, or start a new thread on this topic for the 100th time and get bitched at for not using search to find an old thread.
Old Sep 1, 2020 | 06:59 PM
Schurkey's Avatar
I'd rather have a few zombie threads come back from the grave, than to NOT have people searching before they post.
The important thing for our Year 2020 poster, is that MSD sells crappy coils with a high failure rate; you're better off with the original coil. If the original has been tested and isn't working properly, the Treasure Yards are full of 'em.
I grab Genuine GM ignition modules, coils, distributors, alternators, starters any time I happen to be at the Treasure Yard and see something interesting. MSD can keep their Made-In-China garbage. The few coils they actually make that work good, are REALLY expensive.
wgripp
Jul 18, 2017 01:45 PM
SebringZ
Aftermarket Product Review
20
Dec 18, 2008 11:03 AM
CrazyBear
Northern Great Plains and Rocky Mountain
Aug 2, 2006 10:25 AM
spitcricket
Mar 20, 2005 05:28 PM
84maroman
Oct 1, 2002 10:27 PM
