a good winter diet?????
Old Nov 19, 2000 | 05:41 PM
NJ SPEEDER's Avatar
as many of you who have met me know, i am very big on lowering vehicle weight. i was wondering if anyone had any cool ideas on how to lighten the car up but still be at least kinda subtle about it. i have already removed all the insulation from the carpet and interior trim panels and put them all right back where they belong.
that is the kinda stuff that i like to try to do. also any tips on making lightweight bits to replace stock parts would be great.
thanks
tim
91 Camaro RS-LO3,Auto.
14.390 @ 94.99mph
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall), 36mm Front 25mm Rear Sway Bars, Eibach Pro Kit Springs, Bilstein Shocks and Struts, Steve Spohn Rear Rig( all rod ends), Poly Front Bushings, Baer Track Kit Front Brakes W/ Baer Disc Rears, 17x9 4th Gen SS Wheels, Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
Old Nov 19, 2000 | 05:43 PM
NJ SPEEDER's Avatar
p.s. the insulation thing was worth about 25lbs.
Old Nov 19, 2000 | 06:38 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Some early thirdgens had aluminum crash beams, if you replace both thats good for around 60-70 lbs
of course the spare tire is another 50+ or so
you can also swap to an S10 manual steering rack which ive been told is another 30 or so pounds off the front
rear seats all together were worth 27 lbs in my car
polution pump is like another 5-10 pounds
swapping to a 5 speed is 107 pounds lighter
etc
Old Nov 19, 2000 | 09:09 PM
NJ SPEEDER's Avatar
that crash beem thing is my kinda stuff. your rear seats seem kinda light. when i did my rear seats and seat belts it came to 42lbs.
thanks
tim
14.301 @ 94.39mph
Old Nov 19, 2000 | 10:44 PM
Tas's Avatar
Tas
cool. keep us posted when you get it on the scales. there are lightwight aluminm flywheels for the 5-speed too. If you are more into drag racing than handling you can get the art morrison front suspension worth 40lbs. but from you sig I think that would worsten your handling.
Old Nov 19, 2000 | 11:43 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I just remembered that you can go with the early camaro fiberglass hood (or just an aftermarket one) too
Old Nov 20, 2000 | 11:16 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Yeah, the fiberglass hoods usually weigh around 70 pounds. Thats a good weight saver.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Nov 20, 2000 | 06:50 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
70 pounds? Which hood?
Not even the steel hood weighs that much I dont think, I lifted it off the car myself and im no He-man
Old Nov 20, 2000 | 07:26 PM
Tas's Avatar
Tas
If you have a firebird, you can put the original TA "power bulge" hood on. They are supposed to be aluminum. The later versions on Formulas, like mine, are steel.
Tas
'89 Formula WS-6
Old Nov 20, 2000 | 07:33 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I belive my fiberglass ASCD ram air hood was around 70 pounds. That was including the crate though so I don't know. That is what the shipping guy told me how much the crate and the hood weighed. I didn't weigh the crate so just take a guess on how much the crate weighed.
Old Nov 20, 2000 | 08:58 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I just remembered, you can get a set of aluminum rear drums from a trans am
I did this swap, the drums are about 7 lbs lighter each which doesnt sound like much but remember 7 lbs of rotating weight makes WAY more difference than 7 lbs on the body
You also can swap to WS6 crosslace wheels which i did and weighed the total difference to be around 45 pounds, again, rotating weight, huge difference
Pablo
Old Nov 21, 2000 | 01:39 AM
mike ghoul's Avatar
I have a fiberglass hood on my camaro, and that thing weighs almost nothing, probaly about 15-20 pounds. Also you could get a lift of type hood, that way you shed the hood shocks.
other stuff: remove ac, seats, insulation, spare tire, get light aluminum/magnesium wheels, lighter brake components, all body panels(fiberglass ones actually not too expensive), horn, airbag, stereo, glass(lexan), ground effects(depending on model), that's all I can think of right now....oh and you could put the good ole GM "iron duke" 4 cylinder in...just kidding.
Old Nov 21, 2000 | 08:01 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Alliunum Underdrive Pulleys, 3 piece. Get rid of the Steel Pulleys. If that helps at all.
Eric Natzke
Old Nov 21, 2000 | 05:43 PM
NJ SPEEDER's Avatar
my plan is to bring the car out at or below 3200lbs. when i first started messing with the car it weighed 3650 with the full tank i had to carry to launch on street tires. now the car is down to 3370 with the quarter tank that i can run with my hoosier quick time pros.
my plans include v6 springs and sway bars, switching to a stock 4wheel disc brake setup(i don't think anything in the world is heavier than my baer 13in track kit), mini starter, compact battery(relocated to the trunk), removing the air bag, switching to a manual hatch release, a full radio removal, and chasing every useless wire out of the harness. the only weight going into the car is a set of tubular chromoly sub frame connectors.
i'll try to weigh as much of the stuff as i can and keep you guys posted.
lata
tim
14.301 @ 94.39mph
Old Nov 23, 2000 | 02:30 AM
mike ghoul's Avatar
I don't know what you intend to use your camaro for(road racing/drag racing or both)but there is no way I would loose thoose baer brakes if I were you. Some weight is well worth it, and the stock brakes on camaro's are just plain weak, and they fade like a son of a bitch. I have the baer track kit, and I'd rather loose the weight myself, then to give them up. just my opinion.
1990 Camaro RS
305 TBI Auto
K&N Open Air Element, Edelbrock Performer Intake, Edelbrock Headers,Catco Hi Flow Cat, Edelbrock Exhaust, Hypertech Underdrive Pulley's, Jacobs Ignition, Fast Chip PROM, B&M Shift Kit, B&M Mega Shifter, 3.73 Rear with Auburn Limited Slip, KYB GR2 Gas Shocks and Struts, Eibach Pro Kit Lowering Springs, Edelbrock 3 Point Strut Tower Brace, Baer 13 in. Slotted Rotors with Metallic Pads, American Racing Torq Thrust II 16x8 Wheels with Toyo 245 50 VR 16 Tires, 3 in. Cowl Hood, A little weight here and a little weight there.
Old Nov 23, 2000 | 06:35 PM
NJ SPEEDER's Avatar
i am just taking the baer track kit off of this car. i use the car for my daily commute, all 2 miles round trip of it, and drag racing. i am working on building up a car to the scca street modified rules for solo racing, the baer stuff will be used for this.
lata
tim
14.301 @ 94.39mph
customblackbird
Aug 15, 2021 10:16 PM
Thornburg
Aug 25, 2015 01:46 AM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
