TBI 'check engine' lights + open element
Old Nov 13, 2000 | 01:55 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Ok guys I need some help here .
First I just installed a K&N Open element air cleaner and I have to say, the first time I touched the throttle I took off. Excellent mod. I do have some questions though. I plugged the vacuum, but I need to know where to put the sensors (3)? It doesn't look like it will fit anywhere.
Also my 'check engine' soon light came on IMMEDIATELY after I turned the engine on for the first time, why is it on?
I also get the light when I am in overdrive and hit 70, it feels like I receive a minor loss of power, though it could be in my head, Can anyone help? I also have some other minor questions, but it is way too late, so if anyone can help, I would greatly appreciate it.
James
88 Camaro Convertible SC 305 TBI Auto
Old Nov 13, 2000 | 02:09 AM
mike ghoul's Avatar
The check engine light is just coming on because you don't have that sensor connected, once you reconect it, the light will not return.
I have a k&n open air filter, and what I did was drill a hole in the back(towards the firewall) of the air cleaner, place the sensor in there, then just plug it in and your ready to rock. You can use any decent drill to get this accomplished, just make sure you size it correctly.
After that you shouldn't see that light come on anymore(I didn't).
Old Nov 13, 2000 | 09:21 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Do what Mike said about putting the sensor in. Another thing that you could do is splice a lenght of wire in on that sensor, and run it over towards the front of the car where it will get lots of cold air. That might give you a small boost too.
You are noticing a loss of power. When the check engine light goes on, the engine goes into 'limp mode' it still runs, but it doesn't have the *****...
Have fun,
Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
Old Nov 13, 2000 | 11:22 AM
Zant69's Avatar
Yeah, I have an open K&N, too... I installed the sensor and capped the hose and My service engine soon light still comes on, from time to time. I don't know about that lack of power, though...that's kinda' wierd. It usually comes on when in overdrive, but not every time.... and after a few minutes, it usually goes off.
Everything I know I learned by messing it up at least once.
Old Nov 13, 2000 | 11:43 AM
Engine: 355
Thanks for the info.
It seems, from what it sounds like, that I will always have that light?
Whenever I do hit 70 in overdrive it coems on and never goes off, until I turn the engine off and restart it. i was told it could be soemthing to do with vacuum.
Also it seemed I was BURNING through gasoline like there was no tomorrow after I put in the open element. i thought I would be getting a little bit better mileage with the very least getting the same mileage and better horsepower. Once again it was late when I drove it last and I was working on several cars all day (12 hours)
Also I jsut purchased a MSD 6al Ignition. Where do I put it? There is no room. Also any suggestions on wires and coil? cap and rotor?
Thanks guys,
James
Old Nov 13, 2000 | 12:48 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Check you MAP sensor, and vacuum lines. That was my problem, I had a vacuum leak at the MAP sensor. I could pretty much watch the gas guage move to empty.
Old Nov 13, 2000 | 12:56 PM
jm91rs's Avatar
My check engine light never came on and i have an open element cleaner. Maybe the sensor will fix that.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood
Old Nov 13, 2000 | 02:35 PM
Scott C's Avatar
The service engine soon light should NOT be on just because you switched to an open element air cleaner. You must not have reconnected the intake air temp sensor (IAT) which was inside the stock air cleaner assembly. You must remove it from the stock assembly, mount it either inside the open element or somewhere else, and plug in the connector. The light is on because the connector is not connected to the sensor.
After you fix the sensor, disconnect the negative battery terminal for a few minutes, reconnect it and take a drive! The computer will need to reset itself so you can see the power increase form the new air cleaner setup. Good luck!
Old Nov 13, 2000 | 07:53 PM
Engine: 355
Ok plugged the sensor back in and you guys are right my light never came on, but as I do not have the tools to cut the open element, the sensor is just laying there. Is that goign to seriously scre* me?
No it's not on heat, and i got it too stick up, but that's it.
Also I remember seeing a lot of your guys's engines and you do not have all of the hoses I do. On the passenger side of the engine there are hoses that plug into the radiator and than run back and forth between the firewall and back. It looks like a big waste of plastic pieces and hoses. I want to keep my heater, but can I cut down on all of this 'wasted' space?
Thanks guys
Old Nov 14, 2000 | 01:01 AM
mike ghoul's Avatar
all you need is a drill to put a hole in the base of your k&n then put the sensor in and your set. having it lying there probaly dosen't make much differnce, although in the air cleaner measuring actual intake temp is what the sensor is designed to do.
bad gas mileage is do to you flooring it all the time so you can feel that power and hear that intake roar... ha ha
Old Nov 14, 2000 | 02:07 PM
BlackBird305's Avatar
theres 2 sensors right? 1 in the front of the stock assembly and 1 in the back right? IAT and IAC?...do they both need to be relocated inside the new filter base?
Old Nov 14, 2000 | 08:32 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
You only need to connect the one in the rear, the front one is the thermac, you don't need that on an open element
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Nov 15, 2000 | 12:54 AM
Zant69's Avatar
What about the "breather-silencer" thing? (or whatever it's called)the white plastic thing with the mesch stuff in it that is attached to the passenger side valve cover.... Is it ok to use that one or should You go to a chrome-type breather? I get the service engine soon light every now and then and My rear sensor is hooked up right and the front one is capped off with a screw in the tube.
Old Nov 15, 2000 | 11:28 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Either an aftermarket of the stock breather will work. both will ventilate while filtering.
I still have my factory breather in, and Ive never had an engine trouble code in my car since I've owned it.
Old Nov 15, 2000 | 12:25 PM
Zant69's Avatar
If You want to change it to the chrome type, how does the black rubber hose part come out? Does it just pull out? Or do You have to take the valve cover off to get to it? Also...... do You know the size of the hole? I bought one one time and was totally the wrong size... Thanks for all the info! Brant
Old Nov 15, 2000 | 01:01 PM
Engine: 355
Hey Brant,
The black rubber hose I believe you are referring is the breather tube that plugs into the old filter housing. Just get an edelbrock breather filter. It should plug right in and looks realyl good. It's also suppose to help the cooling process, but doubt it really does much. It just pops right off, but save it, if you don't want it I'll take it as mine is kind of thrashed and I need to keep it for the every two year pain in the A** that the state of California likes to inpose on you. Hope this helps,
James
Old Nov 15, 2000 | 10:25 PM
Zant69's Avatar
Yeah, that helps a bunch.....even though this wasn't my post.. hehee sorry dude...
anyway, thanks alot for the info!
Brant
Old Nov 15, 2000 | 10:46 PM
Engine: 355
Brant
Hey no problem bro. I was helped, so I was hoping I could help you too. I just couldnt figure out where to put that DARN sensor lol :-)
I am putting new valve covers with the open element breathers on from edelbrock or some other company I figure it will fit my K&N open element pretty well.
Later,
James
Old Nov 27, 2000 | 07:47 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I'm having the same problems with the SES light. Why doesn't somebody explain the WHOLE PROCESS so we can all be happy?
Old Nov 27, 2000 | 09:09 PM
chevyboy07 91's Avatar
WHOLE PROCESS>>>>>>>(edit if needed)
Pull old "mama's frying pan" off along with the tubular contraption going to the front of the engine bay. Make sure you dis-connect the IAT (intake air temp sensor) Put that sparkling open element on the T.B. base. Test fit with and without the spacer. The spacer is a faded gold looking ring that sits right under "mama's frying pan". It pulls right off>>>>>but put the open element on first w/ the spacer since it's already on. SLOWLY & GENTLY close hood to see if it clears. If it doesnt clear. Take the open element off again and pull the spacer off. This time it should work. As always, check clearances w/ the throttle linkage etc. For the Crank case breather/vent (on YOUR left looking at the motor) just pull the junk off the old frying pan and re-assemble on the tubing and just let it sit there. Re-connect the IAC BEFORE you start the car and just let it lay somewhere secure.
If you guys threw a code and then went back and connected the IAC>>>you fixed the problem, BUT, the computer will recall that code under certain driving conditions. SO>>>>>just reset the ecm and be on your way. NO MORE CODES.
Hope it helps>>>>really nothing to it at all.
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Nov 27, 2000 | 10:14 PM
Macgyver's Avatar
You don't even have to drill for the IAT sensor, just go to radio shack and get a 4.7K ohm resistor and plug it in the harness, tricks the ECM into thinking the incoming air is 58 degrees, you get a little more timing. I've had the resistor in for a few years now, NO codes, NO problems.
Old Nov 27, 2000 | 11:54 PM
Cool trick man.......thanx for the info. I think if everyone stopped "holding out" on ALL their knowledge>>>>>the 305 TBI cars will be consistent 14 sec cars w/ minimum grease work.
What do you guys think????
Old Nov 28, 2000 | 04:03 PM
Macgyver's Avatar
I think we'd all need new heads and cams
Old Nov 28, 2000 | 04:11 PM
snflupigus's Avatar
ok im finally writing detailed instructions as a write this also.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
wruiz
Aug 13, 2015 09:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
