Does this sound like a good set up?
Old Jan 28, 2001 | 12:46 PM
305tbilo3's Avatar
Ive got a 305 TBI LO3 my current mods are listed below. Does this sound like a good setup? What horsepower/torque improvements will this make. Edelbrock Performer TBI Intake, Crane Compu-cam(208/214) (.438"/.452"),and World Productions S/R Torquers Heads.
Current mods: edelbrock tes headers, gutted cat, flowmaster 80 series, k&n filtercharger
k&n x-treme flow top plate.
Old Jan 28, 2001 | 01:10 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Well, I can't really say since I haven't done heads/cam or intake mods. But I can say that in order for all those to run right you will need a custom chip burned. Otherwise, ur car will run ****ty and u won't notice any power out of those mods. I suggest getting a chip burned by someone who has a dyno and can put ur car on there. Also, u will need to upgrade ur tbi to probably a 670cfm tb unit. Cause there is no way in hell that engine is going to run with that stock tb unit.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Jan 28, 2001 | 09:06 PM
chevyboy07 91's Avatar
looks like w/ a higher flowing cfm TBI and maybee some more "small" mods, you'll be close to or on your way to 300 horse.
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Jan 28, 2001 | 09:10 PM
Tas's Avatar
Tas
you can't put a 670 TBI on an edelbrock intake. NJ speedster has stock cam but better heads than the SR torquers and runs 14.3.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Jan 28, 2001 | 09:34 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Why couldn't you put the Holley 670 TBI on top of an Edelbrock intake? I've got one on top of my Edelbrock intake (Torker II) with a Holley adaptor between 'em.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jan 28, 2001 | 09:37 PM
Tas's Avatar
Tas
I meant to say you can't put a 670 TB on the edelbrock TBI intake because the bores are stock size.
Old Jan 28, 2001 | 10:05 PM
Mark305TBI's Avatar
Ok, that makes a lot more sense .
-Mark W.
Old Jan 29, 2001 | 07:47 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Why not just bore out the edelbrock's holes in the intake to 2" so that they would work together. That would fix ur problem.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Jan 29, 2001 | 10:09 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i dunno, that isnt that much of a huge difference to make the car run like crap without a custom chip. look at my signature..i have a few more mods than you, and i still dont have a custom chip. my car runs pretty good without one. i mean, yeah, you will need one eventually, but its not going to be a matter of running like crap vs. running perfect. i would say it would still run pretty damn good without a custom chip, but better with one. just my 2 cents.
-brian
Old Jan 29, 2001 | 10:16 AM
LottaBallsCamaro's Avatar
You might want to look into a ramair hood to complement your open element
Pretty damn smart with cars for 17!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Old Jan 29, 2001 | 10:21 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well u have the thermomaster chip Brian. Have u tried running ur stock chip with ur setup?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
specialized
Jun 18, 2022 09:26 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 22, 2015 07:13 PM
midias
Aug 22, 2015 01:42 AM
gta power
Aug 13, 2015 06:15 AM
