Help, Car is Dead!!
Old Feb 2, 2001 | 09:28 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Help, Car is Dead!!
I started up my car this morning fine and went back inside to let it warm up, when i came out it was dead. I started it back again and the idle kept going to 1500 and to about 200 and back to 1500 and so forth. Giving it gas wouldn't help much. Finally it died and now it wont start at all. I had my friend crank it while i checked the TBI and there was no fuel coming out of the injectors at all. I'm thinking its either the fuel pump, frozen fuel line, or clogged injectors?? I really don't know how to diagnose the problem and where to begin. Thanks for any help.
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:120,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph before gears
Old Feb 2, 2001 | 09:33 AM
Car: 88 IROC
Transmission: auto
One more thing, i changed my fuel filter a few months ago
Old Feb 2, 2001 | 10:40 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hmm, i was going to say fuel filter but not anymore lol. Try putting injector cleaner in ur car and running it through by trying to start it. Probably have to hook up ur battery with another cars while running so ur battery don't run out. If that don't work then maybe u have bad injectors or ur fuel pump may be out. Also...check ur gas.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 2, 2001 | 12:00 PM
ONEFINE8T9's Avatar
well if his injectors are cloged to the point that they wont spray at all i doubt a fuel injector cleaner will help much. Go down to pep boys and get a TBI tune up kit. Comes with new screens o rings and all other gaskets. Even has a new fuel pressure regulator. The kit is 45$ and thats wheere i would start first if i where u. That could explain a high 16 second run like that. a stock LG4 with an auto should be running high 16s so u should be in high 15 second territory in proper tune.
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Feb 2, 2001 | 12:10 PM
Car: 88 IROC
Transmission: auto
Thanks, i didn't know they sell kits like that. I'll get one of those and at the same time i'll do the ultimate TBI mods. I'm gonna wait till later in the day when it gets a little warmer, i relly think this problem is due to the extremely cold weather that we had this morning. My buggles up my nose froze as soon as I walked outside. So its probably a frozen fuel line. I was thinking about going under the car with a hair dryer.
Old Feb 2, 2001 | 05:30 PM
Car: 88 IROC
Transmission: auto
After waiting a few hours, i cranked the car again and it started right up, but it only ran for 2 mins again and now its dead again. I told this to a mechanic and he says it doesn't sound like a fuel pump. But if it is, hes gonna charge me 50 for towing, 50 for diagnosing, 100 for fuel pump, and 300 for installation.
Can i disconnect the fuel line that goes into the tbi and crank the car and see if there is fuel coming out of the hose, or does this only work for carburated cars?
Old Feb 2, 2001 | 08:45 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
You have an electric fuel pump in the gas tank. All you have to do to make it pump is turn the key to the on possition.No need to crank the engine.Better have the fuel line stuck in a empty two litter, or somthing like that.Have somone else turn the key on and off so you can watch the flow.Good luck!
Old Feb 2, 2001 | 09:24 PM
bullfrawg's Avatar
the first step that i would take would be to pull the codes. It will help eliminate the problem.
1985 TransAm BLK/GLD Stock
1985 TransAm BLK/BLK
305HO (soon as it is put in) 5-speed, 3.27 posi, WS6, power everthing.
http://www.geocities.com/bullfrawgs
Old Feb 3, 2001 | 01:09 AM
9177's Avatar
instead of fuel injector cleaner try 2 or 3 bottles of heat if you can get it started and keep it running the heat should clear up any ice it the lines.
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
