took some pics of my motor today...
Old Feb 12, 2001 | 12:48 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i know this is non-tech, so it will probly be my first thread that ever gets locked or whatever, but oh well..here goes...
there are plenty more where those come from...check out the link in my sig for more.
just as an attempt to make this tech related...
does anyone know which way to spin that wingnut on top of my air cleaner to take it off? i just can't figure it out. just so you knwo which wingnut i am talking about i have included some pics.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
[This message has been edited by Z28 Boy (edited February 11, 2001).]
Old Feb 12, 2001 | 04:06 AM
JPrevost's Avatar
Car: 91 Red Sled
It looks awesome. I wish my engine bay was that clean. Also wish it was here at school with me.
, Jon (91 RS too many mods to list), getting new engine in summer
Old Feb 12, 2001 | 08:40 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hehe, the new webpage is cool Brian. Need more pics of that 91 Firebird with the Ram Air though.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 12, 2001 | 10:04 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
what is that pulley where the AC should be?
Old Feb 12, 2001 | 12:57 PM
Keith5's Avatar
Car: C1500
No one should delete this thing of beauty!!
Old Feb 12, 2001 | 01:46 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
forget it...lets try this again...
[This message has been edited by Z28 Boy (edited February 12, 2001).]
Old Feb 12, 2001 | 01:50 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
<font face="Verdana, Arial" size="2">what is that pulley where the AC should be?</font>
thast teh a/c delete pulley that you can find on teh 1LE cars. here is the GM part number - 10055890
here is a better pic of it...
and thanks for the kind words..
-brian
Old Feb 12, 2001 | 02:29 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I've gotta ask, what is your secret to such a clean engine compartment? Oh yeah, to answer your question just grab it between your thumb and forefinger and twist. If that doesn't work try a hacksaw and just cut the air cleaner stud off just below the wingnut .
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Feb 12, 2001 | 05:51 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
what are you runnin 1/4? just wondering.
Old Feb 12, 2001 | 06:12 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
That engine looks awesome! BTW, what kind of
belt do you use?
Dare to be different-
build a 305! &lt;gasp!&gt;
Old Feb 12, 2001 | 08:28 PM
Basett Racing's Avatar
Sweet pics. That is a really clean car. Were did you aquire the 1LE delete pulley assembly??
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Feb 12, 2001 | 09:06 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Nice setup man! Post your 1/4 results and/or dyno results, good luck!
[This message has been edited by TonyC (edited February 12, 2001).]
Old Feb 12, 2001 | 09:39 PM
Keith5's Avatar
Car: C1500
The pulley's can be found on junkyard cars, or at the dealership. It doesn't have to be a 1LE to have it, "2thpick's" is an RS and he has one.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
*****Possible summer '01 mods*****
Open Element, Auburn Posi, Keyless Entry, wonder Bar off the IROC, 4th gen seats, T/A tail lights
1985 Camaro IROC-Z LB9 Auto
http://www.geocities.com/krt80/
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I like that AC delete setup, but I like my AC even more . Thats pristine by the way!
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Feb 12, 2001 | 10:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i odnt know exactly what i am running in the 1/4. as of right now, i am probably around 14.2, but i need a few important things.
that is with 2.73s and only one wheel spinning, with crappy tires. and i still have a stock chip.
as soon as spring rolls around though i am getting my 3.73s and a limited slip differential, and some bfgoodrich comp ta zrs, so that should help a LOT. eventually i will get a custom chip made or make one myself, but right now its just too much of a hassle. i'll take care of the big things first.
and about the engine compartment...its not as clean as it looks. yeah, the engine and everything is very clean. just about every single part bolted to that motor is new. the blue parts you see though (the firewall, fenders, etc. could use a little freshening. hopefully next fall when the car goes off the road again, i am going to pull the motor and trailor it somewhere and have the whole engine compartment repainted. that will make a big difference.
thanks again guys...i appreciate it, it feels pretty dman good to have all this work (and money) pay off!
-brian
Old Feb 12, 2001 | 10:19 PM
snflupigus's Avatar
btw, if you dont mind me asking. How much would it cost me make mine look the same way.
Old Feb 12, 2001 | 10:24 PM
Keith5's Avatar
Car: C1500
What does your car run like? 2thpick needs an engine, he'll probably get a new GM engine this spring, he's planning on getting another L03 so he won't have any compatability trouble.
Last week he said he was still just going to drive his car on the weekends when he gets his new engine. I thought he was planning on driving it everyday when he got it back on the road.
I've been trying to convince him to pay 40 more dollars and get the caprice L05. Do you think he would have a lot of trouble getting it to run satisfactory enough to drive 2 or 3 days a week?
So far what I've advised him to do is get a 350 knock sensor and some cheap stock 350 injectors, then when he's ready buy the Holley 670 for it. He plans on getting headers when it's time for the engine whether he goes 305 or 350.
Old Feb 12, 2001 | 10:51 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
it runs fine actually...even with the stock chip. i mean i put 3400 miles on it from june 1 to october 1. i drove it almost every day, unless it was raining.
what motor does he plan on getting? i mean, if i can get this thing running really well without a chip, i think teh L05 wouldnt be a problem at all.
about the 350 knock sensor..i dont think that there is a difference. i have a stock replacement for the one in my old 305. i went to like 5 different parts places and tehy all told me that the 305 and 350 had the same one. if i remember right, i had them look up the part numbers and there were the same from engine to engine.
now the price...well, its kinda scary...ill see what i can remember..
2100 engine
200 intake
300 throttle body
200 misc. engine crap i had to get (fasteners, balancer, etc..)
75 air cleaner assembly and filter
75 valve covers
400 headers
100 new accessory brackets (old ones were dirty )
75 new power steering pump (dirty again)
200 new pulleys and belt
375 all new ignition
200 new water pump, both radiator hoses, thermostat housing
100 all new sensors
so far that is $4350, and there are a few more things. plus the HOURS AND HOURS i spent doing it. and i mean HOURS AND HOURS.
hmm...almost there...all i need is the tires and the rear end..thats only another 2 grand...haha the credit card companies LOVE me.
-brian
Old Feb 13, 2001 | 10:53 AM
snflupigus's Avatar
dude! you put all that on credit. DAMN.
thanks for the breakdown though, ive always wondered how much it would cost to just yank it all and startover from scratch.
Old Feb 13, 2001 | 01:51 PM
JPrevost's Avatar
Car: 91 Red Sled
visit my webpage and go to my car, at the bottom is a flash link to my engine swap plans. I think I figured everything out, if I'm missing something or you know a part number please let me know so I can finish the whole thing. www.crosswinds.net/~jprevost
Old Feb 13, 2001 | 02:38 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Jon...i cant find the link on your page...what one are you talking about?
-brian
Old Feb 13, 2001 | 07:14 PM
OutlawFormula's Avatar
FYI= The 305 knock sensor and the 350 knock sensor ARE different .
Just a little info from your friendly parts guy !
Later
91 Formula
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
neekolzun
Aug 24, 2015 04:59 PM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 13, 2015 08:28 PM
