JUST LANDED A 350
JUST LANDED A 350
IM PICKING UP A CRASHED 1989 FORMULA WS6 TPI,IT HAS 342 POSI AXLE . NOW HE HE WHERE TO BEGIN .DONT REALLY LIKE TPI ,WANT REAL BAD TO MAKE THIS COMBO WORK .ALSO I HAVE A TORKER INTAKE(NOT THE TORKER 2)SO NOW MY OPEN REAR WILL BE GONE WHAT SUGGESTIONS DO YOU HAVE FOR ME OH YA CAR COST 800$ AND IS STILL DRIVABLE
1991 Formula WS6 305 TBI
K&N 14x3" Open air filtercharger accel-8.8's,coil,cap,rotor,module.
poly's here and there.
245/50R16 255/50ZR16
3"catco cat
3" Borla cat back
more to come
3"catco cat
3" Borla cat back
more to come
i know ill get flamed for this, but i think your best option would be to keep the whole TPI setup, wiring harness, and everything else and just use it like that. You wont have to make any computer mods or anything, just drop in the 350 and drive away.
However if you do decide to keep TBI you can seel that TPI set up for an awful lot of money and that will be the necessary funds to buy a 454 TBI or a holley 670. Either way is a good way to go. Good Luck
If I were you I'd put the whole thing in and see how I liked it. Then I'd get a single plane holley EFi intake for $255 and swap the TPI with it. Maybe I'd hollow out the bottom of the TPI plenum and try to bolt it to the top of the efi intake.
http://www.holley.com/HiOctn/ProdLin...901-101-1.html
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
-Tas
'89 Formula WS-6
Super GRK_Taz World
Car: 91 Red Sled
I'd keep the TPI myself. Only problem is the cost of extra hp. It does get pretty expensive if you go ALL out. Other than that it's a great system, more up to date but more complicated than TBI. If you don't feel like doing the swap then you could just sell the TPI like sugested and you'll then be able to part the whole car out and have PLENTY extra to do a good build up. Heck, it was worth the $800 just for the TPI and rear end. Good job on the deal.
, Jon (91 RS too many mods to list), getting new engine in summer
why you tell him to stick with TPI on a 350?? You know how expensive that will be to mod? $350 for new base, $300 for runners, $200 for injectors, $300 for TB...
[This message has been edited by Tas (edited February 13, 2001).]
are you planning to do a full build up to this motor or do you just want to get it in and pick up displacement power?
if you want to build it i would say get some nice new pistons that will put it between 10.5-11.0 to 1 compression. get some good heads and that intake will work great. a nice cam that will spin up to 6k-6.5k real easy would work, maybe a zz4 or a nice comp extreme roller grind would be sweet.
just take your time to piece it together right.
you'll need to find a 454 or holley670 tb and some big injectors to handle that set up though. also a new fuel pump would prolly be in order, holley makes a drop in jobber that should support it very nicely.
and if you want to part any of that stuff out email me. i can see a few things i would like
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
YES IM BUILDING IT UP PROLLY 30 OVER YOU KNOW NEW OIL PUMP,6-7QT PAN,H-RODS NEW PISTONS BOTTON END WILL BE STOUT HAVING IT DONE RIGHT MY ONLY REAL QUESTION IS TOP END .I WOULD LIKE TO GET FROM SAME COMPANY HEADS,CAM,INTAKE SETUP.STAYING WITH GASP TBI.PROLLY HOLLY IF ITS THE BEST.JUST NEED A GOOD SETUP . ANY TAKERS
3"catco cat
3" Borla cat back
more to come
3"catco cat
3" Borla cat back
more to come
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have a question. Why don't u think TPI will be a good setup? And why do u think TBI will be any better then TPI? Maybe you should take this over to the TPI board first to reasearch your setup and see what they have to say. Then come back here when u want to swap to TBI (which I don't think you will be doing after you get info on your TPI)
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
mild cam, then just use the 305 HEADS!!
ive heard a lot of people are doing this lately, (hotrod magazine). the combo of 350 and 305 heads gives about a 12.5:1 compression i guess, and some nice power.
im really just spewing out what a friend of mine told me. he wanted me to swap his heads for my stock ones.
i said, sorry, i gotta drive it everyday.
