oil on threads of plugs
Old Feb 14, 2001 | 10:31 AM
88firebirdTBI's Avatar
my last cylinder on the passenger side (i think number 8) has oil on its threads when i changed my plugs. it was the only one out of the eight. what the hell does that mean. my freind had a camaro witha 6cyl and all of them hadoil on his plug threads then his car died (we are rebuilding it now) if anyone knows please tell!!!!!!!!!!!!thanks
Old Feb 14, 2001 | 10:41 AM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Are you sure its motor oil and not a build up of unburnt fuel? How does the thing run?
If it is oil I'd first replace the pcv valve it's only a couple bucks and takes just a minute to change. Good luck.
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
12 PSI Fuel Pressure
6* Timing Advance
MSD Coil And Wires
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock RPM Muffler
No Cat/No AIR Injection
B&M Stage 2 Shift Kit
17"x8.5" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Control Arms
Lakewood Pan Hard Rod
Coming Soon:
Hedman Headers & Y Pipe
12 Bolt With 3.73 Gears
NOS System
Old Feb 14, 2001 | 10:45 AM
i just replace the pcv valve. i am going to go get bretahers today after school. do you think it is the pcv system?
Old Feb 15, 2001 | 08:16 PM
Zac's92's Avatar
No if it was your pcv system all the plugs would have oil on the threads. It is either bad rings in one cylinder, but unlikely they would all wear the same. It could also be a intake leak from the valley into an intake port of one cylinder which would suck oil in the cylinder. Does your car burn oil?
Old Feb 15, 2001 | 08:46 PM
my car only burns oil when it first starts in the morning. what could that be. i think it might be the vlve giude.
Old Feb 16, 2001 | 10:17 AM
FastBroker's Avatar
Valve guides and/or valve seals... Have FUN!
Old Feb 16, 2001 | 10:43 AM
Keith5's Avatar
Car: C1500
Did the electrode have oil on it? If not don't worry about it, you can't worry about every little thing like that, I know I've tried.
About the smoke in the morning, all of us have it, well amost everybody.
[This message has been edited by Keith5 (edited February 16, 2001).]
Old Feb 23, 2001 | 11:38 PM
Adam89F's Avatar
To all members who (still) have blue smoke after startup.
I recommend buying an oil additive by BARDAHL. It is a metal can you get at auto part stores (Canadian Tire perhaps) with a big "2" on it.
Use it. Took away my smoke....maybe it'll do the same for you.
Thanks dad.
Old Feb 27, 2001 | 10:08 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Any chance you simply have a valve cover gasket leaking and oil is running around the sparkplug hole? Under these conditions, as you pull the plug its threads get well oiled. The electrode of the plug should not be fouled with oil, if this is the case, unless it gets 'dipped' when you removed it.
Old Feb 28, 2001 | 08:07 AM
FastBroker's Avatar
It's valve guides and/or seals...
eightsixseven
Dec 16, 2024 01:50 PM
Derick15
Sep 17, 2016 05:28 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
