what size injectos do i need?
Old Apr 11, 2001 | 01:13 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
before you guys tell me to do a search, i already looked but was looking for some "personalized" suggestions..
some of my combo is in my sig, but here are some specifics:
GMPP 350 HO crate engine
454 throttle body
edelbrock performer vortec intake
cam is around 212/222 w/.460 lift
vortec heads (duh)
1-3/4" slp headers
9.3 compression
the search came up with what looks like to be 68#. does this sound right?
right now i am running the 305 injector pod in my 454 base. all last year i had the holley 670, and the car ran really rich.
what injectors should i go with? what do the "350" injectors that everyone always talks about flow? where is the best place to get them? i called turbo city and they recomment the 68# ones as well, and they have them for 125 bucks a pop. isnt that a little expensive? what do you guys think?
to save money, can i just go to NAPA or someplace like that and ask for replacement injectors for, say a 350 chevy truck?
-brian
ps...should i just keep the 305 injectors (what are they rated at again? 55#??) and just pump up the fuel pressure? just trying to get the most out of this combo..and i want to get a custom chip burned adn i have to be able to tell them what i am using for injectors.
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
10 bolt - SLP zexel torsen differential, GM 3.42s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
[This message has been edited by Z28 Boy (edited April 11, 2001).]
Old Apr 11, 2001 | 02:00 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i just called fastchips (i dont know if i talked to ed wright or not..) and they said that i need at LEAST the 350 injectors, if not the 454 ones.
i told him that i thought that they were too big (the 454 ones) but he said that the chip can take care of that. it can be calibrated so that veen though they are big, they spray less fuel.
but do they know what tehy are talking about? i mean, yeah, they are going to know all kinds of crap about teh chips themselves, but about injector sizes, etc?
i am lost...i need help..PLEASEEEEEEEEE
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Apr 11, 2001 | 02:01 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I'm still trying to work some of this out too, but here is what I've figured out. The 305 is using 55# injectors. The injectors that you need can be found, if your lucky, in a junk yard (they have a yellow/brown color code on the top of the injector), but you can get a good set of injectors from GM if you order pn# 17112560 , 17112412, or 17084327. Look at snflupigus' post to answer more questions. https://www.thirdgen.org/messgboard/...ML/000255.html
apparently to get the 68# injectors you need to get them flow matched. Turbo city's price seems pretty good for the 68# IMO. A lot of people talk about just pumping up the FP but that seems like a good way to burn out your fuel pump to me...
Good luck,
Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch.
Old Apr 11, 2001 | 02:09 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Mike..
thanks for that link...it was pretty helpful.
what is up with the different part numbers for the injectors? there are like 4 different PNs for the 65(68)# injectors.
for 83 bucks a piece (i looked it up on gmpartsdirect.com) it looks like a deal to me. what do you guys think?
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Apr 11, 2001 | 03:52 PM
Brent's Avatar
This has been covered here.
https://www.thirdgen.org/messgboard/...ML/007540.html
To choose an injector you need to know how much HP the engine will make. Then you can calculate the rough fuel requirements.
See http://www.rceng.com/technical.htm for a better explaination.
If you run smaller injectors at higher (non stock) fuel pressures you will have to buy another regulator or modify the stock one. Higher fuel pressure demands more of the fuel pump and it may not keep up.
My personal opinion is to get injectors that will fuel the engine using stock or near stk FP. In your case this means 330HP * .5 = 165lbs/hr or 2 82.5lbs/hr units.
Old Apr 11, 2001 | 04:14 PM
JPrevost's Avatar
Car: 91 Red Sled
Before Pablo jumps in on this let me just say that we both NEED a custom chip burned. I'm still running the holley 670 with the 65 injectors and my car is running rich right now. I'm going to play with the TPS sensor a little and maybe even swap out the CTS for the TPI IAT sensor, that might help me indirectly by fooling the computer to run a little less gas. I'll have to look at my plugs to be sure. Go over to the EPROM board and ask them and they'll all tell you we need a custom chip.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 11, 2001 | 10:23 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
you can make the car run with whatever injector you want. As for power production, you wanna go on the large side so you dont run out of injector. Like Jprevost said, the chip takes care of it all when done right.
Old Apr 11, 2001 | 11:38 PM
TriGenRS's Avatar
I've got a question that relates to this:
Let's say i have a bone stock 305 TBI car.
I put a 350 or 454 injectors on it.
I heard that the 350/454 injectors would spray at a higher rate in a 305 car than if it was it in an originally equipped 350/454 TBI vehicle. This would be because the 305 injector pulse is higher than the 350/454 injector. Then when you put the higher flow injector in it will flow the higher flow rate WITH the 305 (higher) pulse.
Is this the truth or a "Psychic Phenomenon"?
89CamaroRS
Power Rating: 1.21 Jigowatts
Mods:Flux Capacitor
Future Plans: Time Travel
Old Apr 12, 2001 | 12:08 AM
JPrevost's Avatar
Car: 91 Red Sled
<font face="Verdana, Arial" size="2">Originally posted by TriGenRS:
</font>
You're right about them firing at the 305 pace. The problem with that is you're going to run WAY rich. That is why a custom chip would take that into consideration and would adjust for that. I really need a custom chip because right now the chip thinks I have a 305 and 305 injectors when in reality...
I wish the darn computer would tune itself with a really expensive o2 sensor.
  • 8" harm. balancer
  • Alston SFCs
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
