267HP 305 TBI, Fnotes article up.
Old Apr 22, 2001 | 07:26 PM
Tas's Avatar
Tas
tell me what you think.
http://members.tripod.com/GRK_Taz/tech/fnotes.html
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Apr 22, 2001 | 09:55 PM
FastBroker's Avatar
When you gonna do it, tas? I bet the duration specs of the cam they are using are similar to the ZZ3/4 roller cam, huh? ie, 208 intake duration? You could probably get by with a ZZ4 take-off OR you could use the Hot Cam I bet, too, which is EFI compatable for sure with a little more duration than the ZZ4 and you'd only be able to use 1.5 rockers? NEVER built a 305 so i don;t know how much lift before cyl wall smacks... Hot is .492" with 1.5's, .525" with 1.6's... Big lift, man. Match that with good heads, you are on your way!!!
Old Apr 22, 2001 | 11:38 PM
90Iroc-Zee's Avatar
heh, i know uve prolly heard this before and know this statistics, but just get an iroc, insurance isnt that much different and "outta the box" i get 300 lbs/ft of torque.
1990 G92 5spd LB9 - 3.42
Accel Ignition/Wires (8.8mm), Advanced Timing, Homemade Ram Air, TB Bypass, Ported and Gasket Matched Plenum, 14.4 @ 94mph w/2.0622 60ft
Old Apr 22, 2001 | 11:57 PM
Zac's92's Avatar
Thank you very much Tas.
Zac
Old Apr 22, 2001 | 11:59 PM
Tas's Avatar
Tas
welcome. I don't think I'm gonnd do it, I got 156k miles now. I just want to make it look good before the engine dies so when it does I'll have a whole new car. I finished the exaust(bought it at least), I'll probably do rims or leather seats next.
Old Apr 23, 2001 | 09:21 AM
Zac's92's Avatar
I might do it I just turned 100k and I have all the parts to do it. It's just a matter of which project gets the time and money.
Zac
Old Apr 23, 2001 | 01:01 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Thanks for posting that, Snuf, but I would rather build the 310 hp boat engine combo.
Old Apr 24, 2001 | 02:28 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
thanks for postin the article it gives me a clue about my own times.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old Apr 24, 2001 | 05:54 PM
REDBIRD91's Avatar
HEY TAZ IT WONT COME UP FOR ME .
1991 Formula WS6 305 TBI
K&N 14x3" Open air filtercharger accel-8.8's,coil,cap,rotor,module.
poly's here and there.
245/50R16 255/50ZR16
3"catco cat
3" Borla cat back
3.27 POSI(B&W)REAR DISC
STRUT TOWER BRACE(EDELBROCK)
WONDER BAR
ADJ PANHARD BAR(HOTCHKIS)
TRAILING ARMS(HOTCHKIS)
more to come
Old Apr 24, 2001 | 07:00 PM
Tas's Avatar
Tas
they are really big files. They might time out for some people. I wrote how big they were.
Old Apr 25, 2001 | 11:22 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I'll be doing a 300 hp buildup on my 130,000 mile 305 this summer. Torquer Heads, Cam w/lifters and rockers and maybe hardened pushrods, keeping the stock bottom end, rpm manifold, 670 cfm TBI, and ofcourse a custom chip. I plan on spending around $1,800-$2,000. Most of this stuff will transfer to a 350 anyway.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Apr 25, 2001 | 01:38 PM
RGZWS6's Avatar
Interesting articles! I like how they eliminated the wheel hop by replacing only the LCA bushings and not the entire LCA. Hmmmm? I see cost savings here!!
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (MAY 01), Wonder Bar
Old Apr 25, 2001 | 05:04 PM
Tas's Avatar
Tas
Lakewood LCAs are only $80 from jegs. www.jegs.com and SLP sells boxed stock ones. www.slponline.com
Old Apr 25, 2001 | 05:12 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
sort of a waste of time to get fancy control arms when the bushings connecting them to the car are made of rubber. They are gonna squish and bend alot faster than the metal of the control arm is. I wouldnt waste my money on any aftermarket control arms unless i needed adjustable ones. Otherwise i think stock ones with solid bushings would be good for most cars and maybe welding a plate on the bottom if you wanna go crazy
Old Apr 27, 2001 | 05:23 PM
ONEFINE8T9's Avatar
<font face="Verdana, Arial" size="2">heh, i know uve prolly heard this before and know this statistics, but just get an iroc, insurance isnt that much different and "outta the box" i get 300 lbs/ft of torque.</font>
ahhh yes, the words of someone who has no clue what thier talking about..........
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Apr 27, 2001 | 06:09 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Hey Pab, all the bushings I've ever seen in aftermarket control arms are polyurethane...they are in my Lakewoods anyway. You could probably get away with stockers with the poly bushings, but with the Lakewoods at only $80, why bother?
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 27, 2001 | 08:32 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
the solid aluminum bushings are in jegs/summit
and ONLY 80 dollars? ONLY? thats it? For basically a chunk of metal that barely does squat more over stockers with a little tweaking? You guys must have money coming out of your ***
Old Apr 27, 2001 | 10:52 PM
Tas's Avatar
Tas
thats assuming nothing is wrong with the stockers. In the Popular Hot Rodding their stock arm was noticeably bent.
-Tas
[This message has been edited by Tas (edited April 27, 2001).]
Old Apr 29, 2001 | 08:51 AM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
I replaced mine cause they were both bent... The panhard rod also...same thing...
Old Apr 29, 2001 | 03:47 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
and how long does it take to look to see if yours is bent? I might also add this peice of advice DROP THE FRIGGIN MAGAZINES AND PICK UP THE WRENCHES, VICARIOUS EXISTANCE IS A WASTE OF TIME
[This message has been edited by Pablo (edited April 29, 2001).]
Old Apr 29, 2001 | 04:02 PM
Tas's Avatar
Tas
I speant all yesterday putting a 3" body lift on my friends T-100 Toyota and 3 weeks ago the same thing on a friends Explorer. Just because I don't talk about all the non F-body mods I do I'm tired of people thinking I sit on my *** for months at a time reading magazines. Pablo, you're not the only person I've heard this from and I'm getting tired of it.
Old Apr 29, 2001 | 04:08 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Well the only person you can blame for that is yourself because all i see is you quoting magazine articles and using them like other people use experience. Go out and put those friggin headers on your car allready and while you are at it pick up a junkyard 3.42 rear etc and on and on
Old Apr 29, 2001 | 04:31 PM
Tas's Avatar
Tas
I quote those because I've been collecting them since I was 10. Think I was even driving in 1994 when that mag came out talking about puttling LT1 heads on Gen 1 block?? As for the headers my sister had to take the Formula yesterday(and from now on 'till Nov.) since some choonty *** vatos decided to side swipe her parked Nissan and my dads '68 Jeep. Not like its any of your business. So since we didn't have the bird to tool on we did the body lift, tranny cooler, and fixed his ARB dual air lockers.
Old Apr 29, 2001 | 05:08 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
<font face="Verdana, Arial" size="2">Originally posted by Tas:
Not like its any of your business.</font>
THEN WHY DID YOU VOLUNTEER THE INFORMATION *******? I DIDNT ASK WHAT HAPPENED TO YOUR CAR.
as for magazines, i wipe my *** with most of the articles I see. If you were wrenching instead of reading how to swap on the latest aftermarket part that just so happened to donate whatever part they sell so hotrod could do an article on how to install it and hence sell more of them you would realize how innacurate, biased, and generally vapid these articles are when it comes to actual information. You wanna talk abut F notes, I could write F notes the friggin BOOK and no one was here to teach me no one was here to be my guiding hand.
Thats the problem with this friggin message board, there is a very small percentage of doers and a very high percentage of dreamers. I guess the only positive is that any thirdgen that can get out of its own way becomes a "sleeper"
Old Apr 29, 2001 | 05:19 PM
Tas's Avatar
Tas
I volunteered the info because the guys like you make incorrect judgements based on the info you do see even though its a tiny part of what's really going on. I had to hear crap from Kevin L. and his dad about asking questions about parts and then not buying then. Did they ever think that there was something else that I might be comaparing the above to before I decided what I was going to do? No. All they saw is that I didn't by their stupid 305 TPI heads which they didn't know the miles on anyway. Does that mean I did didn't spend that money??
Old Apr 29, 2001 | 05:39 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Thats a cute story and all but I dont care, sorry has nothing to do with the subject at hand. Focus and make up your mind! either you want someone to know your life story, or you dont tell it. Its always been very simple for myself. As far as incorrect judgments.. again.. lets get back to this dimension here. This thread is full of regurgitated magazine drivel.. and alot of your posts are! thats a fact, not a judgment call. Another fact is that you learn more and get more experience by doing rather than by just reading. This is not to say you shouldnt research your options but it comes to a point where its not research but it is vicarious existance.
but enough of this talk. THis doesnt have to do with TBI only the problems with the TBI board
Old Apr 29, 2001 | 06:07 PM
Tas's Avatar
Tas
LoL focus on what? A dropout looser who has nothing better to do than flame newbies all day who just want some help? Maybe the Armed Forces can straighten you out like my friends fkup brother and his friend. Its a shame that it has to come to that though.
Old Apr 29, 2001 | 06:15 PM
Slow 89 Iroc's Avatar
90Iroc-Zee, Craig its me Len!!! Shoot an email my way....you dont have yours posted.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
