witch would your guys go with if ya had my setup
Old May 2, 2001 | 03:27 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
im looking at all the cams out there and am a bit confused. i have the money to buy one under about 150 or so. my mods are in my sig.
thanks
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old May 2, 2001 | 03:28 PM
bbtaz97's Avatar
Car: 91 RS
L98cam, comp cam XE262 , those are 2 if been told about recently. keep in mind i do have to pass emmissions next month as well.
Old May 2, 2001 | 05:05 PM
NJ SPEEDER's Avatar
a cam is a logical next step. you will want to look long and hard at your tb though. if you haven't removed the ridges and done the tower riser mod you will not fully feed a good cam. the L98 cam should pass the breath test pretty easy, a 285 hp LT1 cam would also be a nice choice and should pass emissions once tuned in properly(fuel pressure and timing)
hope this helps
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old May 2, 2001 | 09:45 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Your car is currently equipped with a hydraulic roller cam. I've never seen a roller cam less than about $220.
91 RS
Black w/ red tweed
t-tops
14x3 Open Element
80 Series Flowmaster
Will be faster soon!
88 GTA WS6
Red with grey cloth
K&N Filters
TPIS Airfoil
Future Restoration
Old May 3, 2001 | 08:10 AM
bbtaz97's Avatar
Car: 91 RS
ok for now assume money isnt an issue for the cam
Old May 3, 2001 | 08:42 AM
FastBroker's Avatar
YOu can get GM rollers for less than $150 from SDPC2000.com. I like the LT4 OEM cam, VERY EFI friendly and not too much duration and huge lobe sep, which is good for EFI and will SURELY pass the sniffer. Should be like $160 or so.
EDIT: Another good cam is the roller cam they use in the RamJet 350 (1.6 rollers) and in the HT 383cid (1.5 ratio) engines. The RamJet 350cid makes 350hp, I think, and quite a bit of torque. Cam is quite mellow duration-wise, but with 1.6's and good heads, what's wrong with 350hp and gobs of low-end torque????
[This message has been edited by FastBroker (edited May 03, 2001).]
Old May 7, 2001 | 10:02 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Let's see what other names we can come up with for emissions test. I don't have to pas one, neener neener neener.
Old May 7, 2001 | 10:17 PM
NJ SPEEDER's Avatar
i got my LT1 cam for 20 bucks from a guy on the mafb.org mailing list. you can re use you stock roller lifters since they don't really wear unless they are messed up or you missed about 5 years of oil changes.
lata
tim
14.209@95.46mph
Best 60' 1.917
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Aug 14, 2015 08:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
