Injector overspray
Old May 9, 2001 | 09:56 PM
speedlvr's Avatar
Injector overspray
When I take the aircleaner off after driving, the gasket between the throttle body base and fuel meter assembly is saturated with gas. The other gaskets are dry as dust. Either the fuel meter assembly has a very small crack that I can't see or the injectors are spraying too wide. Has anyone had this happen to them?
Old May 9, 2001 | 10:56 PM
JPrevost's Avatar
Car: 91 Red Sled
Mine is the same way. It's not a problem with the unit, just by design.
, Jon (350 TBI!)
91 Red My website
Old May 9, 2001 | 11:11 PM
speedlvr's Avatar
That gasket really does'nt look like it seals anything. Just seems to be a 'pad' for the meter assembly. Do you think there's any danger of fire associated with this? I know gas goes through that area all the time, but just sitting there? Thanks.
Old May 10, 2001 | 05:24 AM
89RS355's Avatar
Nah, you should be fine. Mine has always been like that, and it has only started on fire twice. Just kidding!
Jerry
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Old May 10, 2001 | 07:47 AM
speedlvr's Avatar
You almost had me there, joker.
Old May 10, 2001 | 11:43 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
no fire problems, its because the injectors vaporize the fuel pretty well on their own without airflow. so when you are at idle, im sure that the air inside the aicleaner is somewhat "humid" with gas. at least enough to get some stuff wet like that gasket. its does only seal from outside air, not a pressure seal or anything. there is also always going to be an amnt of fuel that splatters off the blades back up. but it gets taken care of in the end. drips or atomizizes again from heat of tb, and goes right into your engine.
no need to worry
Old May 10, 2001 | 01:28 PM
speedlvr's Avatar
Thanks a bunch. I hope your not pissed about the air conditioner thing. I didn't intend for any of it to be personal.
Old May 10, 2001 | 04:08 PM
snflupigus's Avatar
nope, just distributing my knowledge. dont worry, i take nothing personal on the web.
92-Formula
Dec 12, 2015 10:34 PM
camaro1185
Oct 26, 2015 06:51 AM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
