Headers on a 305 TBI
Old Apr 28, 2001 | 09:49 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I was wondering if you needed to pull the engine, inorder to change the stock manifolds to aftermarket headers??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Apr 28, 2001 | 10:00 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Another question: Is it hard to replace the gears in the rear end?? I wanna go from the 3.08 to a set of 3.73. What do I need to do to make it POSI??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Apr 28, 2001 | 10:16 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
you dont need to pull the enigne to put on headers but you do have to be careful espically on the pass. side. its really a tight fit. just be careful and take your time.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old Apr 28, 2001 | 03:30 PM
KissmySS's Avatar
The drivers side is a breeze but the pass side is hard. You may have to unbolt the motor mounts and lift the engine a bit. Be prepered to sweet and cuss alot!!
91 camaro 305 Tbi(I love it!!!)
*Teal green
*z-28 Grille(red bowtie)
*Z-28 Fog lights
*tail light black outs
*limo tint
*Polished 16'z-28 rims(In side groves too)
*Flowmasters,flowtech headers with cut out
*K&N with dual snorkal ram air(in air dam)
*Accel,wires,cap,rotor,coil,rapid fire sparkplugs
*And all the free tbi mods
*B&m shift kit with hurst HotShift fuild and trans cooler
*Best Et 15.34 at 90 mph
*Neg traction and 2.73 don't help very much
Furture mods(Limited slip with 3.42s, mallory ignition box,ram air hood,and...........
Old Apr 28, 2001 | 07:30 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If you've never swapped diff gears before, suggest you leave it to an expert. In order to make it POSI....just buy one
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Apr 30, 2001 | 09:44 AM
RGZWS6's Avatar
One thing to be aware of is that the stock manifold bolts may have little tabs on them to keep from backing out. If you don't take these tabs off, what you think was the correct socket won't fit. Take the vakve covers off as well. It will help with access to the bolts (less in the way). More than likely one or both motor mount bolts will need to be removed to jack the engine up an inch or so to slide the headers on. Maybe not though. It's not that big a deal.
It took me 14 hours to do my headers and y-pipe. The cat hook-up was a pain. Collector gaskets are a pain.
Take some advice and get the GOOD copper gaskets FIRST! Do not use the paper poop gaskets that come with the headers. Get some GOOD locking header bolts as well.
You learn alot as you go. I took my time with mine and could probably do a second set in a fraction of the time. I did not reuse my A.I.R. so that cleaned things up a bit.
Leave the gears to an ASE certified specialist!!!
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (MAY 01), Wonder Bar
Old Apr 30, 2001 | 12:04 PM
JPrevost's Avatar
Car: 91 Red Sled
RGZWS6, I second that. The headers are a PITA but if you setup right and make some room to work you should be okay. You should definatly leave the gears to a pro that's done it before. They have special tools to set it all up.
, Jon (350 TBI!)
91 Red My website
Old Apr 30, 2001 | 01:42 PM
1989CamaroRs's Avatar
I dident have to lift the engie at all. I just took the valve covers off and the ac coompressor
89 Camaro Rs
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
-14x3 Summit Open Element Air Cleaner
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
79 Jeep Cj7
Old Apr 30, 2001 | 03:09 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I was quoted, $850.00 for new gears and installation. I know I can buy gears for around 300. Thats why i would of liked to do it myself
Old Apr 30, 2001 | 03:39 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
You had better have some heavy duty tools to do it yourself. My dad and I did a 3.73 and a posi swap summer before last. It was not an easy task. You need some fine measuring tools to get the backspacing and the pinion depth set right (you can do this with marking compound too). You will also have to press the bearings onto the pinion gear. We welded up a bearing puller and used the 40 ton hydraulic press to pull the old one off and press the new one on. Not a job for the faint hearted (or ill equiped).
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 30, 2001 | 08:18 PM
FiReBReTHa's Avatar
wait. if you lift the engine, do you still take out all that crap on the pass side?
and how difficult is it to remove original bolts? (dont want em breakin) 91 pont 305.
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old May 2, 2001 | 11:48 AM
RGZWS6's Avatar
Lifting the engine only an inch on the drivers side helped me slide the drivers side header on.
I kept my A/C in place!
I removed all of the AIR poop and the alternator before I started. The bolts were a piece of cake. Not one was rusted. Keep those little tabs in mind though if the exaust bolts have them.
89 Formula 305 TBI
Old May 17, 2001 | 02:48 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
My passenger side header was the easier one to do for me. I didn't have to lift the engine at all, just drop the starter and put it in from the bottom.
Old May 23, 2001 | 08:26 PM
Macgyver's Avatar
Do yourself a favor first, listen to me on this one, I know what I'm talking about.
Get a large set of side-cutters, CUT THE AIR LINES OFF YOUR MANIFOLDS.
Get a rachet and remove the AIR stubs.
Use assorted flathead screwdrivers to pry away the french locks on the exhaust manifold studs and bolts.
Buy good quality exhaust manifold gaskets.
The drivers side was the biggest PITA for me, the steering shaft was in the way, I had to loosen it to get the headers on.
The passenger side spark plugs after the headers are a big PITA.
Since I knew about the french locks, and I had the ***** to just cut those worthless AIR lines off the manifolds, my header and y-pipe install took me 3 hours.
To get Positraction, you need to buy a posi carrier. Buy the carrier according to what gears you are going to run, not what's in your car. You have a 2-series carrier, 3.73 gears are for 3-series carriers. A shop needs to do the install because they need to set the position of the gears themselves, it's a very delicate procedure, micrometers and ****.
Old May 23, 2001 | 08:30 PM
Macgyver's Avatar
Oh, and I did not re-use the A/C compressor bracket that bolts to the passenger side manifold, The compressor is on there pretty good to begin with, I'm not worried about it.
I did re-use the drivers side alt support, I used one of the stock manifold studs to bolt it back up.
My dipstick isn't monted to anything but the engine block. It aint going anywhere..
Old May 27, 2001 | 09:48 PM
Macgyver's Avatar
Oh, BTW, you can buy 3.73 gears for a 2 series carrier, just make sure you buy the gears for the carrier, not the car..
Old Oct 15, 2023 | 08:58 PM
92camaro32's Avatar
Car: 92 Rs. And 2001 dodge ram 1500
Engine: 305 Tbi
Transmission: 5speed/y5
Axle/Gears: 3.08
Re: Headers on a 305 TBI
91 camaro RS
- 305 TBI
I have a 1992 chevy Camaro rs 5.0 tbi with 5 speed and i purchased the hedman hedders (68481) and everywhere i have read that you have to motify the ac but my ac like yours is on pass side. Im having a really hard time trying to get the drivers side on. Ive already removed the alternator and steering shaft and still cant get it to line up. Any advice?
Old Oct 18, 2023 | 06:40 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
My advice is to not bump threads that are old enough to go to a bar and buy themselves a beer...
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
