HELP....OIL pump===Gas??
Old May 28, 2001 | 06:28 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
OK I am priming my oil system when I see gas shoot out of my fuel line ( its the feed line) Why would this happen How do they have anything to do with the other.
Brian
1989 Camaro RS
305 .030 over
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter LETS PLAY FORD!!
[This message has been edited by Brian Felts (edited May 28, 2001).]
Old May 28, 2001 | 07:15 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Are you running the ECM/TBI or Carb. I have read on here that the ECM kicks on the fuel pump when the engine has oil pressure. If you got power going to the ECM, even with the ignition off, the oil pressure may turn on the FP. Just a "Maybe"
Old May 28, 2001 | 07:17 PM
Hey its TBI and the Battery is in........Wonderful Idea I bet you are right on the money!!!!!!!!!!! THANKS SO MUCH!!!!!!!
BRian
1989 Camaro RS
305 .030 over
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter Ultimate TBI mods...14X3 K&N open Element Non-Drop... LETS PLAY FORD!!
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
