injectors????? possibly shorted out?
Old May 24, 2001 | 01:14 PM
RyanSS's Avatar
Ok, i just got done fixing the short that happened when i grounded out the positive battery cable on the header. my car will start , but will not stay running. the injectors do not pulse at all,
do i need new injectors or could the whole short thing have messed up something else that is keeping the injectors from spraying?
89 RS (supposed 350) TBI auto
Old May 24, 2001 | 11:50 PM
Andy89RS's Avatar
Check the 20A fuse that's in the weather tight holder near the battery. It should be mounted to the inner fender just to the rear of your battery. It controls the injectors and ECM. I blew that fuse once and the car just cranked but wouldn't fire.
Old May 25, 2001 | 10:54 AM
RyanSS's Avatar
Ok, i checked that fuse, it's good. See, the only thing that doesn't work as far as i can tell is the injectors. the car will run, but only on the gas that i pour in the TB, after that is all burned, it dies due to lack of fuel(injectors not pulsing). if you guys can't help i'm gonna just go get some injectors and see. but i'd rather not take shots in the dark.(well, not actually dark, but semidusk i guess)
Old May 25, 2001 | 11:09 PM
Andy89RS's Avatar
If you're going to try different injectors just get a TBI off a car in the boneyard. That way you'll have test injectors (If those work, then go out and buy new ones) and you'll have a second TBI unit to modify without worry of ruining the only one you have.
Old May 26, 2001 | 01:42 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
hope you didnt fry the ecu. probably not, check all fuses twice with a volt ohm meter. sometimes they look good by sight, but in fact are not.
Old May 28, 2001 | 06:33 PM
RyanSS's Avatar
Ok, I had the ignition module tested, and it is good. The fuel pump doesn't prime at all, and even when I give the green wire going to the FP relay power, nothing happens.
I know that if the FP relay is bad, the ECM uses the Oil Pressure switch to turn on the fuel pump. I have sat and cranked my car for several minutes at a time, but to no avail. Also, my Oil pressure gauge doesn't work, does this matter?( it has never worked for as long as I have had the car and never affected anything before.)
I am about to take the ECM in to be tested at Autozone to see if I fried something in it.
Could I have blown the FP? It has less than 100 miles on it.
Any other suggestions??
Old Jun 5, 2001 | 05:44 AM
Vader's Avatar
Ryan,
Try supplying power directly to the pump at the ALDL conecctor. Whether or not the relay is bad, this should get power to the pump.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited June 05, 2001).]
Old Jun 6, 2001 | 12:56 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The green wire goes to the ECM.
You need to put power to the red wire on the relay.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
Thornburg
Aug 27, 2015 08:33 PM
Keith5
Aug 27, 2015 04:37 PM
Bryan F
Aug 18, 2015 02:28 PM
