Installed Open Element...One Question Though...
Old Jun 15, 2001 | 06:46 PM
91TealRS's Avatar
The Tech Article concerning installation of an OE says that you should disconnect your battery to reset the computer. Why do you need to do this?
Old Jun 15, 2001 | 07:06 PM
PopaPork's Avatar
****...I just installed mine. I ripped off the poopy stock set up and put mine on, without disconnecting anything. Maybe it could throw off your computer or something but mine is running fine. Same with my friends...he ripped his off too. (knock on wood)
89 Rs Camaro 305 TBI
Custom Performance Chip
Open Air Element
80 Series FlowMaster Muffler 2.5 inch Cat Back
BFG 235/60r15 Apperance: Black gray pinstripe. Black interior with Gray center piece in seat. Blue Gauge lights and 2 Blue neons under dash Board.
90 Iroc Checkerd Tail lights
Iroc Foglights
System: Pioneer 5200 Head unit Polk 3 ways up front and in the back. Kenwood 300 watt amp pumpin a 8inch JBL GT
"So many engines, so little time"
www.rit.edu/~cjp8408
Old Jun 15, 2001 | 07:11 PM
91TealRS's Avatar
I didn't disconnect anything either and it runs fine with me too. Just wondering...you know...in case you are really supposed to for some reason.
Old Jun 15, 2001 | 07:39 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I think it's to let the computer adjust to the new air coming in (fuel/air mixture). I think it will adjust by itself in about a week though even if you don't disconnect it.
Old Jun 16, 2001 | 01:13 AM
JPrevost's Avatar
Car: 91 Red Sled
It's just a good rule of thumb to reset the ecm after you do something performance related. This way the ecm resets to it's stock variables and relearns what the new engine wants. You don't need to do it but it is just a good idea.
, Jon (350 TBI!)
91 Red My website
Old Jun 17, 2001 | 09:22 AM
91TealRS's Avatar
Is it possible to reset the ECM by pulling its fuse? I can't get the negative battery cable disconnected...the bolt is stripped.
Old Jun 17, 2001 | 10:48 AM
dtpmike's Avatar
mine is stripped too, jsut use a vise grip and clamp it on, it should move.
Old Jun 17, 2001 | 11:04 AM
91TealRS's Avatar
Alright got it disconnected! Thanx!
Old Jun 17, 2001 | 05:40 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
it resets the integrator numbers in your ecu. they are what correct rich/lean conditions.
if you want to know more about that. go to the dyi chip board. or check out the best damn garage on the internet. sorry lost the addy for it, youll have to do a search in the boards for it.
Dale Earnhardt, #3 has crossed the finish line with a victory.
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
