Best way to spend $1400 on a relatively stock LO3??
I've got an open element filter and a flowmaster 80 series right now. I'll do the rest of the free stuff later...
Here's what I was thinking:
Edelbrock headers, Catco cat, Edelbrock exhaust. About $800.. Then a fastchip computer chip. Another $160.. Then a Comp Cams 268H high energy cam.. Another $300.. Should I take the $200 and do some ignition upgrades and a shift kit? Or should I try to have someone install some 3.73 gears instead of a camshaft?
Need some ideas. I'm pretty set on the catback, cam and cat idea, I just need help with the last parts...
Edlebrock headers- $330
Gut your car- $0
Posi unit- $325
Install Kit- $125
Gears- $200
Installation- $250---optional if your good
Total $1230
IF you get 3.73 gears your car will be very quick.
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock TES Headers, Exhaust cutout, Edlebrock open element, 160 degree T-stat, and a Stage 2 FastChip.
2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from http://www.MrMikes.com
Gut your car- $0
Posi unit- $325
Install Kit- $125
Gears- $200
Total $1230
The car still has to be tested for emmisions.. I would rather just put a higher flowing cat on than gut it. Also, I need a new catback kit bad, my tubes are rusting..
I think i'm going to go with exhuast, headers, cat, and gears..
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Gears w/posi
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
If you are a little bit sketchy about the whole engine swap thing, then get the gears and a posi. Otherwise build a 350.
Gears and posi. It will make the car into a whole new machine. Next, if you really have the mod bug under skin, just do external engine parts that will transfer over to a 350 when you switch. Also, don't forget to upgrade the suspension. Nothing like spnning the tires while getting the jump put on you by an escort or something.
Jerry
1989 Lt. Blue RS 5-speed
355 crate motor, Compucam 2040,
PST Front suspension,
Hotchkis rear suspension,
EDL T.E.S., 3" Flowmaster
Harwood cowl hood
1994 Black Z28 6-speed
Nothing major, but FUN!
Jerry
Harwood cowl hood
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i would say headers/exhaust, gears, heads, cam
those are the areas on an LO3 where you you will notice alot of power increase by replacing stock with aftermarket parts. one other thing is instead of buy a compcam you can svae money by buyingangood used lt1 cam and replacing your valve springs with lt4 springs, its more work but its still cheaper on the parts.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
91 camaro RS
- 305 TBI
<font face="Verdana, Arial" size="2">Originally posted by 92fire-audio:
Need some ideas. I'm pretty set on the catback, cam and cat idea, I just need help with the last parts...</font>
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
I found a shop in my area that will put in posi and 3.73 gears for $250.. I don't think that's too bad. Looks like I will be getting exhaust, cat, headers, ECU upgrade and 3.73 gears.. After that, I'll save up again and get lt1 cam, vortech heads and MSD ignition.. By next summer hopefully i'll be in the low 14's...
Genopsyde
Oct 7, 2015 08:35 PM
Ozz1967
Aug 16, 2015 10:23 PM
