Won't Run AGAIN
Old Jun 20, 2001 | 03:40 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Won't Run AGAIN
HELP!!! All I did was park it in the garage and now it will not run......I do know if I hold the throttle blades open then it will Idle but as soon as I let go of them it will die right now........
I hate this
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 20, 2001 | 03:45 PM
firbird's Avatar
When you push the gas does the blades open up more? if not it may be a broken cable
Old Jun 20, 2001 | 04:04 PM
Yes everything is opening fine.......It has a new TPS.....IAC......MAP. I am holding it open with a rod from outside the car. I Will not idle on its own. I will not start unless I hold the blades open also.
Brian
1989 Camaro RS
[This message has been edited by Brian Felts (edited June 20, 2001).]
Old Jun 20, 2001 | 07:03 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Might want to increase the idle speed. This happened to me. I had to have my dad hold the throttle open a little bit while he started it then hold it open while I increased the idle with that little connector unpluged. Then it would idle.
Old Jun 20, 2001 | 07:10 PM
89RS355's Avatar
Maybe the minimum air needs to be set. I don't think it is a part that has gone bad on you, rather an adjustment that needs to be set. When you hold it at idle, does it bounce or stay solid? Look into adjusting the miminum air and maybe checking the the iac passenges, etc. Good luck!!!!
Jerry
1989 Lt. Blue RS 5-speed
355 crate motor, Compucam 2040,
PST Front suspension,
Hotchkis rear suspension,
EDL T.E.S., 3" Flowmaster
Harwood cowl hood
1994 Black Z28 6-speed
Nothing major, but FUN!
Old Jun 21, 2001 | 02:01 AM
JPrevost's Avatar
Car: 91 Red Sled
Check your plugs! With the way it's been running so lean it wouldn't suprise me if some plugs are fouled up so bad that it won't hold an idle. Then check all the wires. Flip the TPS sensor a few times and hold it in a position just off idle and see if that helps any. Just curious but does the SES light blink really REALLY fast? If so the eprom isn't working and ecm is in "get home mode" which will NOT hold an idle with an aftermarket car.
, Jon (350 TBI!)
91 Red My website
Old Jun 21, 2001 | 08:01 AM
No not getting amy SES light, however the plugs are a good idea.
Brian
1989 Camaro RS
Old Jun 21, 2001 | 07:07 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Could be the EGR valve
Old Jun 23, 2001 | 01:00 AM
colincamaro's Avatar
check your injectors make sure both of them are spraying. I had a inj1 fuse get corrode just enough to lose that injector
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
