?? Holley TBI 502-6 on edelbrock intake (3704)
Old Jul 3, 2001 | 07:41 AM
JeffC1500TBI's Avatar
I was thinking of buying the 670 CFM Two Barrel TBI Model 3210 from holley. problem is my edelbrock intake (3704) has 1 11/16" bores and appartently the holley is 2". WTF?? holley claims it's a stock replacment. Edelbrocks says to only use the stock TBI. any ideas????????
thks
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
3.73 Rear gear ratio,
Edelbrock performer TBI intake, performer cam, timing chain,
Hiflow cat with Rhino dual 2 1/2" out the rear.
Old Jul 3, 2001 | 08:40 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Holley gives you a thick-*** gasket that necks down from 2" to 1-11/16" so that you can use it on the stock intake.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jul 3, 2001 | 11:40 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Why not go with the Holley TBI intake? It has 2" bores.
Old Jul 3, 2001 | 12:42 PM
JPrevost's Avatar
Car: 91 Red Sled
Depending on your application a Holley unit might not be best. 670cfm is a lot, even for a 350hp street engine. My friend runs 600cfm double pumper on his 370hp 327, we put on a 750 and it didn't like it. BIG delay in throttle responce blah blah. I wouldn't install the edelbrock special TBI manifold. For the same price you could have any carb intake with a 1" spacer/adaptor.
What's the point of installing the holley 2" unit if the manifold is 1 11/16!!!!! Kind of like installing a 3" y-pipe and 3/4 headers with a single 2.25" out!
, Jon (350 TBI!)
91 Red My website
Old Jul 3, 2001 | 12:46 PM
thing is I already have the edelbrock intake cam & timing chain.. I installed it about 6 months ago.. just thought if I put a better TBI unit I might get more gains..
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
Old Jul 3, 2001 | 03:51 PM
DM91RS's Avatar
Car: 91 RS
With that being a basic stock motor in a truck I would recommend doing the ultimate TBI mods in the tech section of this web site and spending that money on some much needed headers. If you are set on buying the Holley 670 just pull the intake and any machine shop can drop a 2" end mill in those stock size holes, But what you are after the most would be bottom end and mid range torque with that heavy truck. Also make sure that you have a non-restrictive air intake system on there. Good luck!
91 RS 350TBI VORTEC HEADS PERFORMER INTAKE LT4 CAM 1.6 ROLLERS EDELBROCK HEADERS 3' EXHAUST 5SPD 3.08 GEARS
[This message has been edited by DM91RS (edited July 03, 2001).]
Old Jul 3, 2001 | 04:21 PM
thanks for all the info so far guys... as far as machining the intake to 2" bores apparently (this is right from edelbrock) you can't make them any bigger without hitting the water jackets. as for weight of the truck it's actually not that heavy.. its reg cab stepside.. sides of the box are fiberglass.
if anyone has any input on headers that would greatly be appreciated.. I was thinking of putting some one since I have a high flow cat & performance muffler but someone told me that if I drive it in the winter they wouldn't last more than 2 years because of the use of salt in the winter here. the other problem I have (maybe someone can help me here as well) my truck has that A.I.R. crap on it so I need headers to accomodate that..
thks
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
Old Jul 3, 2001 | 04:24 PM
Tas's Avatar
Tas
Jeff. Port your heads. Dyno Don K. did and he said he saw a 40HP improvement. Your main point of restriction now is in your heads, not the intake and TBI.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
InfinityShade
Aug 22, 2015 08:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
