Help with Emmissions URGENT
Old Jul 4, 2001 | 01:03 AM
OldBlue's Avatar
Hey guys I REALLY need some help with my emmissions I dont get it. the car wont pass new rotor new cap new wires new plugs new fuel filter and my car is still in the same place as before emmisions wise 4% off on the HC's Ive ran tank after tank after tank of the injector cleaner and have run nothing but supreme for a month now and still its high. should I just go and get some of that stuff from napa that guarentees that you will pass emmissions? Im almost to the point that I think its the cat. not sure how much it costs to replace it though I know its gonna be around $90 though I dont think it could be the EGR because the engine only has 37K on it hell the whole car only has 37 K on it. But I need to get this done thurday cuz I have to go to court for not having plates while driving it ( expired temp ) and I cant get plates till it passes immisions but If I have plates when I go to court on tuesday they will most likley wave the fine.
Old Jul 4, 2001 | 11:18 AM
OldBlue's Avatar
ttt
Old Jul 4, 2001 | 11:28 AM
un4givin89's Avatar
GOSH DARN TREE HUGGIN HIPPIES AND THERE DAMN POLLUTION LAWS. THE AIR SMELLS FINE TO ME, CUT DOWN THE DAMN RAIN FOREST. NEED MORE WOOD ANYWAYZ. THERES LOTS OF AIR IF YOU CONSIDER HOW BIG THIS PALENT IS SO WHATS THE POINT.
Old Jul 4, 2001 | 11:34 AM
Tas's Avatar
Tas
the point is if you live where there are mountains, all that crap in the air turns into a giant cloud of crap and doesn't like going away.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 4, 2001 | 06:10 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
What type of engine do you have? Make sure your smog equipment is all there and functional. I really need to know more specifics before I can give you advice.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 6, 2001 | 12:58 AM
OldBlue's Avatar
its a 305 TBI with a 5 speed everything is workin ok I put a new PCV valve on it today checked everything out. When I pulled the plugs on it they looked liek they were the originals wich wouldnt surprise me since its only got 38K on the clock
Old Jul 6, 2001 | 02:22 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
when i bought my car i ran it through emmissions to get my tags and blew 792 on the hc scale with an applicable standard of 220 for my car. i bought new plugs and wires and took it through a few hours later and blew a 32, yes i did say 32. hc is unburned fuel. most common probs are plugs,wires,pcv,oil change, and the wonderful VACCUM LEAK. make sure your car is at operating temp when you take it through. that means 220*. if you fail again, next time you go you should ACCIDENTILY drop a crisp $20 bill when you hand him/her the paperwork. works like a charm.
Old Jul 6, 2001 | 10:17 AM
Pukka's Avatar
Definitely get the car tuned up, and have the timing checked. A bad EGR would show a fault code, so would a bad O2 sensor. With 37k I wouldn't think you have any serious problems.
Old Jul 6, 2001 | 10:13 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I just had the excact same problem and tried the same fixes you did. Mine wound up being the coverter ($220 installed). A bad EGR valve would cause you NOX gases to be high. A bad O2 sensor could also be a problem but you should be getting a trouble code.
Tim
Trent257
Oct 18, 2001 07:47 PM
redz28man
Sep 8, 2001 07:23 AM
ChillPhatCat
Carburetors
Aug 24, 2001 03:19 PM
ChillPhatCat
Aug 13, 2001 11:06 PM
chevyz28
Carburetors
Jul 2, 2001 12:04 PM
