Changing engine coolant - a few questions.
Old Jul 6, 2001 | 11:03 PM
One Eyed Jack's Avatar
Okay I think I know how I can drain the coolant. But what can I do with the waste? I live on a lake and have a septic tank, and dont want my lawn turning brown. Plus I have pets that would like to eat the antifreeze. Who takes used antifreeze? And how much does my car hold, so I can proprely measure? Thanks.
1992 Pontiac Firebird
- 305ci V8 TBI / Automatic Trans / Loaded
- MODS: Edelbrock 14x3 Open Element Air Cleaner, Dual outlet exhaust
Old Jul 7, 2001 | 06:02 PM
dtpmike's Avatar
well catch it all in a pan, walk over to the woods, dump it in. Or you can put it in milk jugs and take it to Olsen Tire and they should take it. Any auto repair place will probably take it for free.
You dont really need to measure the antifreeze. Where do you live..up north where it snows? If it gets really cold Id just put one jug in and fill the rest with water. IF you live in florida or somewhere like it, just put a little bit in since water cools better.
Old Jul 7, 2001 | 06:50 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I usually put 1 gallon of antifreeze in my car, I think that makes it safe to about -10 or 20 degree's, which is plenty for where I live. It's good to hear of someone else that care's about disposing of coolant properly rather than just dumping it in the woods or down the storm drain, I take my used oil and coolant down to the local fast lube place and they take it, I would think theres one around you that will take it too, just stop and ask.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
[This message has been edited by DartByU (edited July 07, 2001).]
Old Jul 7, 2001 | 11:47 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
My car' entire cooling system is rated to hold 17.2 quarts of a 50/50 mix. I would think that the Firebirds would be about the same.
50/50 is the safest ratio to keep. It increases the boiling point of the water, lowers the freeze point, and helps dissipate heat better than just water alone. It's good from -30 deg up to about 250 deg. I know how that's important to you because I live around the Great Lake Region like you. And it do get cold.
Straight water is only good until 32 deg. before it freezes, and it boils at 212 deg. That Water Wetter stuff helps that in warmer areas, but don't ever let it freeze. I've read that it expands more than the water.
The easiest way to mix the antifreeze/water is a big iced tea pitcher. Mix it 50/50 and poor as much as you can in. Then use whatever is left to top it off after the engine is warmed up a few times. Check it daily for about 3-4 days. That'll allow you to keep good tabs on it. 17.2 quarts is 4.3 gallons. That's 2.15 gal. of each. That's a lot of fluid & weight. About 24 lbs. No, actually about 32 at 8lbs./gal. I dunno what antifreeze weighs.
OK, I'm babbling now. Time to say BYE.
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited July 07, 2001).]
Old Jul 8, 2001 | 10:17 PM
Andy89RS's Avatar
For the safety of your pets, if you spill any coolant, hose it down as much as possible to dilute it. The best thing to do actually would be to keep them in the house till you're done.
Old Jul 8, 2001 | 10:35 PM
okay cool, thanks guys!
Old Jul 9, 2001 | 01:36 AM
FiReBReTHa's Avatar
hey jack, its in general engine, i asked, too much to type,
nm, im just lazy,
ok, HERE WE GO:
go to auto store, pick up a prestone FLush kit, i bought mine for 4.94$ it has it where your supposed to connect a t into something, but i didnt do what it said cause i was short on time, what i did is i got some auto lockers from craftsmen, squeezed the clip on the lower radiator hosed, wrestled from the top of the car to pull it off, i had a tub under it, its gonna leak, then pull off the thermostat housing, and put hose in, and turned on, kept it in till most anit freeze came out, then i put in this cleaner from prestone, so then there was only water and the cleaner, then i started the car with the the heater on. for ten minutes, then i opened the bottom hose again and put the hose in where the thermostat housing was, and turned it on flushing all that out, it mostly fell on the floor. then flushed with water, closed looped it(connected everything) then ran again. cooled, let it drip from lower hose, then after that, placed new thermostat and gasket, and 50.50 mix, closed it up and was good to go.
if any question, post and ill check again tommorow. or email or im me Firebretha@aol.com
keeping in mind that if anyone else says anything, do it their way if its opposite from me, i did my first today.
and keep in mind guys, most of this stuff isnt from nature, and will kill nature. so be thoughtful and go to a firestation and drop it off.
thanx
91 FireBird 305 V-8
Edelbrock Catback, Fourth Gen Console. i have six cupholders. all for starbucks!
ghetto rigged cold air intake,
"My G/f Once Wanted To Break Up Because Of Competition With The Car."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
God Created The Earth, And Then Turned Up The Bass
Old Jul 13, 2001 | 01:15 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
i recently changed my timing chain and put in the new dexron antifreeze ..the red stuff... it seems to be pretty good and the best part is that you dont even have to change the fluid for up to 5 years(so they say)...
Old Jul 13, 2001 | 09:17 PM
FiReBReTHa's Avatar
how hard was it to swap the timing chain?
its something ive been considering,
thanx!
Old Jul 13, 2001 | 09:21 PM
FiReBReTHa's Avatar
thanx!
91 FireBird 305 V-8
GheTTo Riggers INC.
F-Body Meeting, Naperville IL, Chicago Ave and Washington. July 27, 8:00ish.
Part Search, I NEED A Harness For A Radiator fan, THANX
eightsixseven
Dec 16, 2024 01:50 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
