TBI Injector Spacers
Old Jul 20, 2001 | 04:51 PM
Loki705's Avatar
I was looking at the Injector spacers on www.turbocity.com . I was wondering if anybody had these and if so what they thought. Also do you have to buy two of them or just one? Thanks.
92 RS Camaro with 5.0L TH700R4 W/ B&M Shiftkit, K&N, Panasonic HU, JBL Plates in the front, Alpine 3-Way 6X9's in the back with two 10-inch Rockford Fosgates powered by a 220 watt Fosgate amp in the trunk.
Old Jul 20, 2001 | 05:11 PM
jmp1999's Avatar
If yu just mean the TBI spacer that goes underneath the unit. Dont have one. But watch your stock hood clearence. I have a 1/2" plate for my NOS and it is DAMN close!
Old Jul 20, 2001 | 05:14 PM
Loki705's Avatar
Its not the TBI spacer that goes between your intake manifold and the injection unit. There is a separate spacer they sell that raises the injectors inside the unit and are supposed to increase airflow.
Old Jul 20, 2001 | 08:41 PM
JPrevost's Avatar
Car: 91 Red Sled
Not just air flow, it's also to tune the fuel spray to just above the edges of the throttle blades. If the injectors are too low they'll spray right onto the blades at part throttle. It's complicated but it is a good idea to get one or make your own. I think you need to cut the TB base to get the stock fuel line fittings to fit.
, Jon (350 TBI!)
91 Red My website
Old Jul 21, 2001 | 04:50 AM
Loki705's Avatar
hmmmm i never thought of that.... Damn what a P.I.T.A. I will wait until tomorrow and go look at that. You don't think there will be enough play in the lines to make it fit?
Old Jul 21, 2001 | 06:02 AM
Tas's Avatar
Tas
I got one but haven't putten it in yet. like everything else. The one I got is the TD brand that makes a lot of intake TBI spacers.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 21, 2001 | 08:46 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
<font face="Verdana, Arial" size="2">Originally posted by Loki705:
</font>
The fuel lines are bendable, but not very much. If you've got smoe extra $$$, braided lines would work, and look much nicer too.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 21, 2001 | 06:13 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
WTF? you raise the injectors up from the throttle body? crazy man, crazy. i hadnt heard of this mod yet. ahh technology, what a wonderful thing...well most of the time.
Wide Open Till You See God...Then Brake
Old Jul 21, 2001 | 06:32 PM
JPrevost's Avatar
Car: 91 Red Sled
This isn't anything new. It's been around for at least 10 years. When you crank up fuel pressure you should always look at the fuel spray and make sure that it isn't dripping like a shower and spraying onto the throttle blades. Best way to tune it is with extra gaskets but if you move it up about a 1/4" then the plastic spacer would be wise.
, Jon (350 TBI!)
91 Red My website
Old Jul 22, 2001 | 02:24 PM
scauffiel's Avatar
I've got pix of the process on my site...
Steve
Steve's Trans Am Temple
Old Jul 22, 2001 | 05:36 PM
rsilver's Avatar
I know there was a thread on this, but where is the spray supposed to be hitting? What is ideal? Mine is wide and hits the top 1/3 of the throttle body rather than right above the throtttle plates. What is the ideal location and what happens if the spray is too high or too low? I think pablo or someone else had this one down. Appreciate any help...........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Jul 22, 2001 | 11:12 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm not an expert on this but for best gas milage you want to have the fuel spray a couple mm above the throttle blades at idle. The air moving by the throttle blades is so fast that it atomizes the fuel and makes for a very good mixture. I think that's best but if you raise the injectors at WOT you might notice a gain up top because the injectors are not restricting air as bad.
I could be wrong but that's what I've gathered over the past few years.
, Jon (350 TBI!)
91 Red My website
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
