injectors don't fire!
Old Jul 27, 2001 | 09:32 AM
formula88's Avatar
whenever i crank the motor, there is no fuel goin to the tbi unit. I check to see if the pump is pumping, i think it is, its making that whining noise, could it be a bad fuel filter? Anything else? Any advice would be appreciated. Thanks.
Old Jul 27, 2001 | 09:44 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check your fuel pressure at the TBI unit. If its good it rules out the pump and filter.
Then check for voltage at the injectors.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 27, 2001 | 01:02 PM
NJ SPEEDER's Avatar
change the fuel filter first. and check to see if the injectors are making a little clicking noise when the key is turned. if there is silence then the injectors aren't firing and it is a wiring issue, if they are making noise then it is a fuel issue.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jul 27, 2001 | 07:50 PM
formula88's Avatar
NJ, should i crank it or just put the key in the on position?
Old Jul 27, 2001 | 07:51 PM
formula88's Avatar
oh yeh, i'm gonna wait till sunday to do it anyway.
Old Jul 27, 2001 | 09:38 PM
ChevelleCLM's Avatar
Tap a 9 volt pattery on your injector when the pump is running.
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
Old Jul 30, 2001 | 01:51 AM
Jza's Avatar
Jza
<font face="Verdana, Arial" size="2">Originally posted by Pukka:
</font>
what should the voltage be? just curious.
Old Jul 30, 2001 | 04:43 PM
NJ SPEEDER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by formula88:
NJ, should i crank it or just put the key in the on position? </font>
check it when cranking.
lata
tim
14.209@95.46mph
Best 60' 1.917
Old Jul 30, 2001 | 05:34 PM
KiDKiD911's Avatar
I had that happen once, and as silly as it sounds, the wiring connectors on the IGNITION COIL had slid off. That will actually stop your injectors from firing when cranking. Something to check.
Corey Turner - Toledo, OH
91 9C1 - "Project Potent Rodent"
http://www.geocities.com/kidkid911
-350ci / Ported Vortec's - 10:1 Compression
-Crane '509 lift hyd. roller cam / 1.5" Roller Rockers
-Ported Holley 670cfm TBI on a Edelbrock Multipoint EFI System / Paxton AFPR
-Heddman Full-Length Headers piped to Dynomax 2.5" True Duals / DM Turbo Mufflers
-K&N Dual Air Inlets running to Ram Air II Hood
-MSD 6A Ignition Controller / MSD Blaster 3 Coil / Accel wires-cap-rotor
-Ed Wright Fastchip in a 7747 ECM
-Flex-a-lite 210 Electric Fans - 160 Thermostat
-700R4 w/ a B&M Shift Kit
-3.43 Posi-Rear
-Ram Air II Hood, Custom spoiler
Old Aug 1, 2001 | 10:02 AM
formula88's Avatar
turns out to be the fuel filter guys. My guess it has never been changed since the car was new. Thanks
1992rs/ss
Jan 31, 2025 05:10 PM
Steve78LT
Feb 24, 2016 12:15 AM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
