tbi?
Old Aug 9, 2001 | 11:39 PM
brihoop's Avatar
tbi?
i have no clue what my car is. all that i know is that its an 88' V8-305-Fi-5.0L and it says fuel injection on this think under the hood. i have no idea if its a tbi tpi or what. if any1 knows or has an idea of what it is respond to this.
Old Aug 10, 2001 | 12:28 AM
manuel's Avatar
OK,I can that everybody here knows what a TBI is. I will try.
OK,TBI is Throttle Body Injection.It has two heavy duty fuel injectors above the Throttle
Body.TBI is similar to carb.TBI has less parts to break than TPI.The TBI is located in the center of the intake manifold,under the air cleaner assembly.
OK,TPI is an intake manifold. With TPI,every cylinder has a fuel injector,and air tube runners. Unlike TBI,TPI is a rectangular intake that cover pretty much of the engine.TPI shares a Throttle body,without the injectors above the throttle body.The Throttle body controls the air intake and idle air control and throttle position sensor.TPI has a Mass Air flow sensor.The throttle body in TPI is located in the front of the intake. Both the plenum and the intake manifold are connected.
Please,for those that have a better understanding of TPI and TBI please do not mock or scorn me.I just state what I believe of the difference.If you know anything that I quoted wrong or missiong please tell me before making me look like a jackazz.
Old Aug 10, 2001 | 07:26 AM
Enkil's Avatar
TBI looks like you have a garbage can lid in the middle of your engine.
TPI looks like you have a metallic spider humping your engine
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Aug 10, 2001 | 10:18 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
One way to find out a lot of info. about your car is to type in the VIN in the VIN decoder on the homepage. This can be found on your insurance card or in the lower driver's side corner of your dash under the windshield.
[This message has been edited by JRoy91RS (edited August 10, 2001).]
Old Aug 10, 2001 | 11:01 AM
vjo90RS8's Avatar
Car: 2002 Z28
VIN
8th E = TBI
8th F = TPI
Old Aug 10, 2001 | 09:19 PM
TrueBlue91RS's Avatar
Enkil,
that's one of the most interesting ways I've ever heard TBI and TPI distinguished from one another.
Short, sweet, and to the point... if a little odd.
Old Aug 11, 2001 | 01:35 AM
brihoop's Avatar
ya enkil, it was good. and its one of the only ones that actually told me an answer!
Old Aug 11, 2001 | 04:39 AM
So......... what is it then, TBI or TPI?
Garbage can or humping spider?
Old Aug 11, 2001 | 10:23 AM
brihoop's Avatar
it is the garbage can tbi
Old Aug 14, 2001 | 11:04 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Then you found the right place, welcome. Oh, sometimes the garbage can lid looks funny. 8^)
http://photos.yahoo.com/bc/topdownso...hotos%26.src=p
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
[This message has been edited by lonsal (edited August 14, 2001).]
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
