L98 cam in a LO3 engine
Old Aug 25, 2001 | 10:17 AM
88firebirdTBI's Avatar
i just did a cam swap and know my TBI 5.0 has a L98 cam in it. It is a reasonable difference,i was wondering what kind of power gains i was looking at. My car pulls alot harder now and it idles a hell of alot better. any comments
Steve
88 Firebird TBI(WS6),TH700R4 - Open Element, Catco 2 1/2 High Flow Cat, K&N filter 14*4 element, American Thunder Flowmaster Catback Exhaust, 180 Stant thermostat, Accel cap and rotor, L98 cam
Old Aug 25, 2001 | 11:57 AM
JPrevost's Avatar
Car: 91 Red Sled
The L98 cam was built for the TPI system. I don't know every spec about the cam (too lazy to look it up) but it's definatly a higher lift than the stock L03 piece. You probably also changed your timing chain, right? If you did that could be a major reason why the car is idling much better. The TPI cam was designed to work with the long tube intake runners, not the short TB system BUT the Lo3 heads have a velocity design similar to the TPI runners (in theory) and this is probably why the cam feels much better all around. Did you go with 1.6 rockers? What else did you do other than the cam swap or was that it? Does anybody know the L98 and LT1 cam specs?
, Jon (350 TBI!)
91 Red My website
[This message has been edited by JPrevost (edited August 25, 2001).]
Old Aug 25, 2001 | 07:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The L98 cam specs are in the cam tech article on this site. The LT1 cam specs have been posted in an image file quite a few times on the TPI and General Tech boards, you'll have to do a search.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 25, 2001 | 07:59 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Did you have to mess with the computer.
Old Aug 25, 2001 | 09:46 PM
Tas's Avatar
Tas
the L98 cam is similar to a LT1 one but noone has recomended a L98 cam for the L03 in a while since used ones would be so damn old now.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Nov 13, 2002 | 05:16 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
anyone ever used l98 heads and a cam in a L03....I know the cam will work, but how about the heads???
Old Nov 14, 2002 | 01:46 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
LT1 specs: These very a little year to year on the LT1's but I got these specs a while back when someone posted them.
The duration at lash point in degrees at .050" tappet lift (intake/exhaust) is 205/207; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is .447/.459. Valve lash is zero/zero and lobe centerline is 116 degrees.
L98 cam works OK in the TBI cars but when you can get LT1 for just a couple dollars more you might as well go with it.
Old Nov 14, 2002 | 09:24 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Let's see...the 92-93 9C1 L05 uses the L98 cam and was rated at 205hp. If you do the straight numbers (205*(305/350)) you end up with 178hp. Somehow, I think you have more than that. Maybe 190.
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
