black box
Old Aug 15, 2001 | 09:59 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
black box
what is the black box with all the hoses coming out of it above the passenger valve cover on my stock 92 rs 305 tbi and can i get rid of it without messing up the computer
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Aug 15, 2001 | 10:06 PM
Tas's Avatar
Tas
that's part of the heater valve I believe. not sure exactly. I'll check my chiltons manual when I get back.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 15, 2001 | 11:11 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Yeah it is. It splits off when your heater is on it feeds coolant through the heater core, when its not it just runs it through the radiator. and its all vacuum operated.
I guess you could get rid of it, but your going to mess up your heater stuff. Just splice the hoses together and your either going to have heat on all the time or none at all.
Mike
[This message has been edited by burntblues (edited August 15, 2001).]
Old Aug 16, 2001 | 01:37 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
you can move it, get longer hoses and put it somewhere else.
Old Aug 16, 2001 | 02:39 PM
i just bought this car and the heater doesnt work i cant just hook it up like i did my 89 camaro just run the hoses straight to the heater core i had no problem with any hot air coming out of it i didnt have any valve on it or anything
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Old Aug 16, 2001 | 03:02 PM
Tas's Avatar
Tas
Just because coolant will go to your heater after doesn't mean it will blow hot all the time It will blow hot when the heater is on. The blower motor will push air through the heater. That's how it works.
Old Aug 16, 2001 | 03:58 PM
so that means i can get rid of the black box and rerought hoses to my heater core right
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Old Aug 16, 2001 | 08:18 PM
and what about those tubes going into my exhaust it looks like there running to the heater vavle to can i take them out and plug the holes up
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Old Aug 17, 2001 | 12:55 PM
snflupigus's Avatar
1/4 inch pipe plugs for your manifolds is beleive, those are your air injection lines, that send o2 to your exhaust for better emissions to help the cat along.
Old Aug 17, 2001 | 10:37 PM
so can i take off the 1/4 inch pipe plugs or will it run like **** i dont care about emmission
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Old Aug 18, 2001 | 12:32 AM
Hulk0202's Avatar
You can plug them and it'll be fine. Sorry bro, but if you've got 180* water circulating into the cabin, it's gonna heat it up whether the blowers on or not.
Old Aug 18, 2001 | 04:20 AM
Tas's Avatar
Tas
enough with the guessing and shiet. Some 3rdgens never had the heater valve and people have deleted it and not noticed extra heat in their car.
Old Aug 18, 2001 | 10:34 AM
91rscruiser's Avatar
hey i dont think that those hoses he's talking about are the heater hoses.he also mentioned a black box,so i think he's talking about the AIR diverter valve(im pretty sure that box is the diverter valve).i just looked at it and yes it is above the passenger v.c. and it is a black box with i believe 5 hoses on it.the heater valve is right to the right of it.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-stock L03 305,TH700R4,2.73's,only mod for now is a Flowmaster 80 series replacement muffler.
-best 1/4 mile times:16.2@84/2.37 60ft
Old Aug 27, 2001 | 08:52 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
That box is the A.I.R diverter valve switch that switches on or off allowing air into your exhaust manifolds and catalytic converter to dilute the exhaust gases (I sound like the friggin' Science Guy)depending on your engine temp and whether you're in open or closed loop. I took all that crap out and my computer doesn't throw a code.
92' Camaro RS 305 TBI
Best ET - 14.6 @ 96 mph
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index...ew&rideid=4860
Old Aug 27, 2001 | 11:57 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The AIR diverter valve is worth over $300 brand new. You may be able to sell it for some cash.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Aug 27, 2001 | 08:23 PM
Jza's Avatar
Jza
I can't imagine who would spend anywhere near $300 to add emissions equipment to his/her car.
Old Sep 2, 2001 | 09:42 AM
Rice_Cooker_'88's Avatar
I think he IS talking about the diverter valve. the heater valve is a little round shaped thing that sits right above the pass. side v.c.. the air diverter is right next to it. To check, the hoses on the heater valve are flexible, so you can move it. The diverter on the other hand is rigid and wil not move. If you remove the diverter box, then with it you can remove the smog pump, and the air tubes that run into the manifold and plug them with 1/4" brass plugs. You'll have to either get a shorter belt, or play around with the routing of the stock one if you remove the smog pump. Some of the third gens didn't have the air diverter box because they ran on carbs, and did'nt have all of the emmission control **** that the newer ones do.
'88 CAMARO 305
OPEN AIR ELEMENT
FLOWMASTER CAT BACK EXHAUST
COMPUTER CHIP
HYPERTECH 160* THERMO.
Old Sep 2, 2001 | 05:35 PM
snflupigus's Avatar
you would pay that much for it, not now, but in about 20 years. TRUST ME. i now own a 69 that needs restored, people pay huge money for original stuff, try 8 dollars for a correct bolt. save it in a box in your garage, sell it later. investing is fun isnt it.
Old Sep 3, 2001 | 10:26 AM
Pukka's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jza:
I can't imagine who would spend anywhere near $300 to add emissions equipment to his/her car.</font>
The reason it costs so much is because GM is the only place that makes it.
Live in an emissions state and you could EASILY spend that much to get a car through emissions testing
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
MantyZ28
Jan 18, 2016 08:30 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
zayne0
Aug 24, 2015 07:22 PM
