Beat by a Honda
Old Sep 17, 2001 | 09:34 PM
IsuzuMini's Avatar
Beat by a Honda
A few days ago a me and a friend raced. He has a '94 Honda Civic Hatchback:Cold air intake(fenderwell), Header, Some kinda ***** catback and they installed an Integra GSR motor with V-tech. I have a '91 Camaro RS Auto, Stock. I just got it so I havent quite perfected take offs. We pulled up to the light and when it turned green, we took off. We were neck and neck for a sec. but then he left my *** pretty bad. I want something that can beat the **** outa him. I was thinking lose the smog pump, go to a carb, headers without all the air ****, and a 3in catback. Anyone have any other suggestions on mods for a win?
Old Sep 17, 2001 | 10:06 PM
AdioSS's Avatar
Car: 96 Impala SS
Spray it That'll get you the best results for the money. Just make sure you keep track of how full your bottle is. Cuz you just know, one day you'll get challenged and the bottle will be empty.
Other than that, loose some weight (from the car! 100lbs=1 tenth), change the gears, swap a bigger cam in, port&polish the heads/intake, etc. A torque converter will tear him up at the line (if you don't smoke the tires) but it won't help as much on the top end.
~ Cheston Phillips ~ =Impalaitis ~ = tri9_SS
'96 BBB Impala SS "ADIOSS" & '91 white Caprice 'n0n 9c1' w/L03
Old Sep 17, 2001 | 10:32 PM
HrdRockA4305's Avatar
Ok that car sounds very similar to somone i know around here who has a honda, and his runs a 15 flat. Its gonna take some $$ to make a TBI/auto car do that, as i am unfortunately painfully aware as i'm on a very tight budget. Theres a couple guys who can run that fast with a TBI and a few who are even faster. I'd say to start with get a decent cat back of your choice, non-air headers and no cat/smog pump, open element, 3.73 rearend with a good posi, and that'll get you much closer. But to beat him its gonna take more fuel, a chip (possibly custom), and maybe 1.6 rockers and a cam (which requires MORE chips tuning). The swirl port heads sure aren't helping either, but thats a very expensive upgrade. Basically what i'm saying is its gonna take lots of work to make an RS that fast. But i'm not talkin sh-- to you, my car has the same engine and its nowhere near Vtec spankin fast yet.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/123,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
StangEater's Avatar
he's right, it's gonna cost quite a bit to get an L03 to go anywhere..for the money i'd say get yourself a decent 350 built, slap a carb on there, 3.42's or 3.73's...and you'll be fine, we all suffer from the sh**ty 305, ditch it
[This message has been edited by StangEater (edited September 17, 2001).]
Old Sep 17, 2001 | 10:37 PM
"I was thinking lose the smog pump, go to a carb, headers without all the air ****, and a 3in catback. Anyone have any other suggestions on mods for a win?"
Actually, if you do this and put in a nice but not ridiculous cam, you should have him as long as you get a good launch. Go get'em!
Old Sep 17, 2001 | 10:59 PM
JPrevost's Avatar
Car: 91 Red Sled
I would like to make a few things very clear. The Lo3 has a very nice bottom end but the heads are ****. If you ever take a look down the intake port of a stock head you'll notice that you can only see HALF of the port and the valve. This really hurts performance because it's like giving your engine this HUGE header exhaust system and then sticking on a 2" muffler.
If I still had my 305 I know I would have to do something about the heads. I would either save for the edelbrock or worlds products BUT the vortec heads after all the machine work might be an even better bang for the buck. Once you scrap the "velocity" port heads you've got a LOT more potential.
If you're going to do a cam swap and an intake, why not just go a little deeper and do the heads?
As for getting a stock 305 into the 14's, this would be my plan with cost in mind.
Intake manifold, home made ram air or open element, better rear diff with low (high number) gears, a nice bump stick like an Lt1, headers to a 2.5" or 3" exhaust depending on your bump stick, then loose some weight (about 200 lbs). To get the hole shot I would think about better LCA and relocation brackets. Those mods had better get you into the 14's but if you did the heads you'd be punching for 13's. Oh yeah, and after all that work you'll definatly want to get a custom eprom burned or bump up the fuel pressure.
, Jon (350 TBI!)
91 Red My website
Old Sep 18, 2001 | 02:49 AM
ChevelleCLM's Avatar
4th gen or 350 time for you. My 350 is bone stock save for the headers, and I run low 14's with a 305 throttle body. Our cars weigh about the same, and If you have an auto, thats one thing going for you.(good launches) I would look for a 350 to build up, and just put some flat top pistons in it, and get yourself some good Cast Iron heads, and a good intake, and slap your throttle body on that. I would not trade a my TBI for a carb if it gave me 50 HP! The drivability is just not there with a carb. Trust me. I have done both. I still have the option to put performance parts on my motor, but choose not to. I am damn proud to have a classic daily driver that is injected, and gets 20 mpg with 3.73's and a 4 speed.
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
Old Sep 18, 2001 | 11:27 AM
BahamutRS's Avatar
Bah, just do some exhaust mods and you'll own his sorry *** ....but gears would really insure a win...jump ahead and never look back. :P
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
MSD 8.5mm plug wires
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 18, 2001 | 01:04 PM
ws6formula89's Avatar
Pssst....get heads and gears...hehe.
Old Sep 18, 2001 | 04:44 PM
pimpintheRS's Avatar
i hate honda's but they are getting faster.. i wont even race on the street because i dont want to get beat by a swapped v-tec motor..A few friends in hodas running in the 14's with the bottle.. rice is getting faster around here.. so i am putting in gears and posi cost around 300 for parts then find someone to put in and lt1 cam and intake manifold probably edel... then i will race right now i drive around and say your not worth my gas!!! it works!
Shawn
Old Sep 19, 2001 | 12:59 AM
chevyguy8's Avatar
Its probably going to get moved pretty soon to Racing board but here it goes.
I have raced my friends 95 Integra GSR 5spd and I have handed his *** every time. Now I know that his car is heavier plus he has sounds but he also has headers, no cat, cat back and intake.
Make sure you race him from a stop position cause it is hard to keep up with them once that Vtec motor gets going.
As for mods, exhaust and gears youll need nothing else.
91 Camaro LO3 RS 5-spd
Open air element,ACCEL 8mm wires w/cap n rotor, K&N filter, flowmaster, Edel. TES Headers(not installed). dual fans.
Old Sep 19, 2001 | 10:32 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
<font face="Verdana, Arial" size="2">A few friends in hodas running in the 14's with the bottle.. rice is getting faster</font>
No offense but rice throws bottles on anything. Thats why they are fast cause thats all they can do is throw a bottle on. So if u look at it, thats pretty pitful. A car running a 15 flat or 14's thats on the bottle.
Don't let the bottle scare u. Anyone can throw on a bottle and push a button. It takes skill to make a car run fast on motor.
[This message has been edited by 91Bird305 (edited September 19, 2001).]
Old Sep 19, 2001 | 04:27 PM
with or without the bottle if you lose you lose..and actually the guy runs a low 13 in a honda civic.. all motor he runs a high 14... so w or without the bottle if you lose you lose.. i think of the bottle of a mod and you cant just throw the bottle on a car unless you dont care for your engine...
with gears posi exhaust and maybe a cam you'l be something to be recon with.. and you'll spend half as much for every mod!! chevy runs the mother!!
Shawn
....yeah my thirdgen.org name is gay but i've had it for a while.....
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with ac delco plugs.. i like but not noticed
removed rear hood seal.. runs cooler i liked
accel cap and rotor..not a real mod
coming soon 3.42's with slp posi.. my first big mod!!!
lt1 cam shaft in the mail!! now 2 big mods to do!
Clarion cd player 2 planet audio 6x9's 2 tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps gotta love the f-body trunk, system hits!!!
Old Sep 19, 2001 | 07:16 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I disagree. U can throw a bottle on anything really, as long as the bottom end is half way decent or ok. I have seen people throw bottles on GEO's for godsakes. So no, I don't look at throwing on a 75 shot of NOS and hitting the button all the time a good mod. NOS is suppose to be "insurance" when it comes to street racing.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
armybyrd
Oct 24, 2015 06:59 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
Cameeeero
Sep 18, 2015 04:00 PM
InfinityShade
Aug 22, 2015 08:00 PM
