finalizing TBI motor-to-be
Old Sep 20, 2001 | 11:11 AM
fast_broker's Avatar
ZZ4 shortblock, FastBurn heads, ZZ4 cam (with 1.6 RR's on intake, 1.5RR's on exhaust for .506"/.510" lift, 208-209/221 duration)
412hp/398lb-ft WITH 650cfm Holley carb, 33BTDC. Gave up on the HotCam 'cause I know I can reach my 400hp goal with a smaller cam.
This is basically a FastBurn 385 (350cid/385hp/385lb-ft) but with roller rockers (instead of the 1.5 ratio ZZ4 stamped pieces, yuk, that come with the FastBurn motor) and 1.6 ratio on the intake instead of the 1.5 ratio, which I am sure the intake of the FastBurns liked. The friction factor alone from the RR's is probably worth 10-15hp and the rest of the gains are from the added intake lift.
TBI to be put on over the next couple weeks or so, small unit for now, 454 unit if I need it, which I probably will. Stock market is beating me up so bad, it is terrible... Also, will probably swap the heads to Vortecs after FastBurn PROM is done just to see what I can get out of those Vortec, heads, while I still got 'em in the garage.
I hope all are well!!!
[This message has been edited by fast_broker (edited September 20, 2001).]
Old Sep 20, 2001 | 02:36 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like a plan. Keep us updated frequently because it's lonely being one of the few guys with a 350 and TBI. It would ben nice to have somebody to share bin files with, that is if you're going to stay with the 8746....or aren't you?
Good luck with the market.
, Jon (350 TBI!)
91 Red My website
Old Sep 20, 2001 | 03:44 PM
ChevelleCLM's Avatar
Hey what about me?! Do I count?
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. TBI w/custom harness and prom best 14.5@90
Old Sep 20, 2001 | 06:05 PM
I have the truck 7747 ECU, sorry.
Also in the process of lengtheneing my Wrangler 40" so if I run into trouble(s), the TBI implementation will have to wait a little while longer.
Old Sep 20, 2001 | 06:24 PM
NTChrist's Avatar
I think the other Fast Broker on this site is into Jeeps too. Hmmm.
No guts, no glory.
Old Sep 20, 2001 | 07:53 PM
Tas's Avatar
Tas
40"?? I want to do 10"-12" check this out: http://www.promed-systems.com/prod02.htm
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 20, 2001 | 10:00 PM
steve8586iroc's Avatar
fast_broker, it's good to see your back with us. Thought we might have lost you last week. Wasn't sure where you worked in NY, just glad to hear from you again.
Steve
Old Sep 20, 2001 | 11:30 PM
NJ SPEEDER's Avatar
that sounds like an awful lot of power for a 2barrel tbi unit. i am thinking you may get your best results with one of the holley 4barrel units. the 700cfm would work great for full range torque, the 900cfm would get ya more top end but sacrifice a little torque.
later
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 21, 2001 | 11:19 AM
Yep, I am still here (thanks, Steve) but now I have to deal with what those guys have done to our economy and stock market. Bummer. These last few days, I am losing more money in ONE day than I make on one month. But, you don't lose until you sell... Some short-term trades have now, obviously, turned into long-term holds, which ties capital, just when the housing prices are getting good, too.
Tas, is that your Jeep??? Pretty cool looking. Trying to get some heim-jointed arms made for my steering. OEM stuff getting old... I'm gonna get some pix of mine up for you guys one of these days. I know you are "car" ugys, and so am I. I just also happen to like Jeeps. Also, might lengthen the Wrangler 40", just for a Winter project. and a 7747 ECU'd 502cid Conversion (like the GMPP one in the catalog) would be nice, too...
I personally don't like Holley injectors so I won't consider their units, sorry. Just my ways/experience. No offense, at all!
I still plan on an MPFI conversion (using the podless 454TBI as air control) down the road which I presume will be just as illegal as a RamJet. I suppose I could just use a RamJet but I wouldn't be able to do the tweaking like I do now with the GM TBI. VERY easy to swap in a motor for emmissions test every year or two, especially in a Jeep. The entire front clip comes off in like 1/2 hour and makes the job easy. Swapping the engines is a small price to pay, really, for high-performance. Plus, it gives me a chance to clean things up in the compartment a bit every so often. But, gotta keep an OEM'ish TBI motor in the garage...
I am pretty sure that the small TBI will not get me to 400hp... That motor is sucking some air on the dyno...
On the evil side, I am getting rather tired of TBI/PROM work. I mean, I feel it is superior to carb, still, in many ways, especially for a street motor, but with the 4.56 gears in my Jeep, the mileage benefits of the TBI and TH700R4 are greatly diminished. ie, TBI with 3.07 gears = great mileage, 3.07 carb sucks, but TBI and carb with 4.56's are equal for mileage, or close enough to not have to bust my butt over the PROM. Just something I have noticed as I try to find ways to spend more time with wife/kids/clients thses last sveral months. I have a 1406 Edelbrock on my Jeep motor now with OOB vortecs, COMP XE250 still and it runs like a banshee with the 4.56's. Only about 15mph on the highway at 2500rpm's, though, vs 19mpg with 3.07's with same tires. about 11mpg in city/daily driving, though, with the carb vs about 13mpg with TBI and 4.56's. I have pissed off some CT cops, lately, so I might have to bring the Jeep back to CA for a bit. I think because I beat a cop-buddies 5.0 stanger.
Take care, guys.
EDIT: That Jeep is pretty cool, Tas, in your link. He extended the bed nicely. I am going to basicall add a whole 'nother rear-section to mine. From just behind the door jam area back... about 40" worth, moving the rear axle back 40" as well, not leaving it in the OEM location. will "un-tub" the OEM fenders where the original tires are now, too. Considered tandem rear axles (OEM location and 40" location) but a buddy of mine did that in a an old Blazer and convinced me otherwise...
[This message has been edited by fast_broker (edited September 21, 2001).]
Old Sep 21, 2001 | 02:18 PM
NJ SPEEDER's Avatar
you could swap to some form of port injection and keep all the egr and other tree hugger parts if you use a tpi ecm. just plumb the injector bungs into the existing tbi manifold and get a custom chip burned. that would prolly even be pretty cheap.
later
tim
14.209@95.46mph
Best 60' 1.917
Old Sep 21, 2001 | 03:50 PM
Tas's Avatar
Tas
heh thats not my Jeep. That guy is rich. The holley TBIs use GM injectors now.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Old Sep 23, 2001 | 07:23 PM
EGR? The time I spend on trying to fake it/make it work I would RATHER spend on putting an OEM engine/ECU in.
Seriously, EGR is the right thing to do, but for me, I won't consider it a problem.
EDIT: Holley TBI's were "supposed" to have GM similar injectors but HOLLEY decided to use their own injectors to save money. That is a year-old(+) decision and was an obvious one to me... NEVER gonna happen: profit margin too high for holley with their own injectors.
[This message has been edited by fast_broker (edited September 23, 2001).]
92firebirdguy
Sep 1, 2016 07:53 AM
BLK87Z
Sep 18, 2015 11:29 PM
89bird2.8
Sep 18, 2015 07:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
