Finished my LT1 cam swap today..
Old Sep 23, 2001 | 11:23 PM
92fire-audio's Avatar
Well i finished my cam swap today.. I got an lt1 cam out of a 94 camaro.. Installation wasn't too bad except for how long it took..
Heres a couple things that surprised me:
1. The springs are doing fine. I have 139K miles on the engine, i'm in shock that the springs arn't binding or the valves arn't floating..
2. The exhaust tone changed so much. It just sounds so sweet now..
3. I'm finally done and I can whoop up on those 'stangs at my school now..
I haven't driven it that much yet, i'm making sure there are no leaks and everything is set right.. I installed an accel 300+ digital ignition too.. It was simple, i love it.
Somebody said that I should grind off the water pump bushing, well, either mine didn't have one on the cam or it fit with it on. I didn't have a fitting problem at all and i didn't make a mess...
Ok, i'm a little crazy after working on this car for the past 2 days, so if this doesn't make alot of sense, forgive me.
Old Sep 23, 2001 | 11:51 PM
Tas's Avatar
Tas
Old Sep 24, 2001 | 02:12 AM
pimpintheRS's Avatar
planning to do this soon.. was it hard what was the hardest and how much did you actually have to take off?
....yeah my thirdgen.org name is gay but i've had it for a while.....
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with ac delco plugs.. i like but not noticed
removed rear hood seal.. runs cooler i liked
accel cap and rotor..not a real mod
coming soon 3.42's with slp posi.. my first big mod!!!
lt1 cam shaft in the mail!! now 2 big mods to do!
Clarion cd player 2 planet audio 6x9's 2 tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps gotta love the f-body trunk, system hits!!!
Old Sep 24, 2001 | 09:48 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The radiator & a/c condenser need to be removed. I suggest having the a/c purged before. The a/c condenser is hard plumbed, so just moving it aside without disconnecting it is risky. FYI, the cam bettered my 1/4 mile e/t by .2 seconds. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Sep 24, 2001 | 10:03 AM
FiReBReTHa's Avatar
how modified is yours?
i wanted to do a swap on my bird 305 but nothings really chagned...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Sep 24, 2001 | 10:21 AM
TMoNeE's Avatar
Car: 87 Z28
<font face="Verdana, Arial" size="2">Originally posted by 92fire-audio:
</font>
I dont suppose you would be savvy to writing a step by step tech article.. i have an lt1 cam out of a 94 and I want to install it in mine... if not a tech article,... maybe email me a step by step process.
Old Sep 24, 2001 | 10:47 AM
It's basically summed up here:
http://www.racer-x.f2s.com/proc/caminst.htm
If you arn't familiar with your engine then I wouldn't recommend doing this swap. It gets pretty involved and there is alot of things that can go wrong. The hardest part was getting the valve lash set right. The car will run like poop with the lash set wrong.
Get a TDC locator from summit or jegs, it makes it a lot easier. Get all the other stuff listed on that page, you need it all..
Old Sep 24, 2001 | 03:30 PM
Anyone know how long I should wait to bring the engine's rpms up high? I want the cam to break in first and I don't want stuff breaking. I think I'll go easy on it for the first 300-500 miles...
Old Sep 24, 2001 | 04:36 PM
NJ SPEEDER's Avatar
if the cam and/or lifters are new you should put at least 100-150 miles on the car before yopu really romp on it. if the they are used they are already set in and all i can say FIRE AWAY!!!!!!!!!
you gotta let us know track times before and after the swap if you have them.
congrats on the swap. hopefully my car will be all the way back together, including the cam, some time before the next ice age
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 24, 2001 | 09:48 PM
I haven't ran my car yet at the track, however, I can say it was a SOTP difference.. The cam really does nice above 3000 rpm.. I'm glad I got 3.73 gears now because it stays in the powerband a lot longer. I lost some low end torque but I actually think that will help me launch with less wheelspin... The idle is kind of rough, it shakes the car at stop lights but nothing extreme.. You can still see out of the mirrors .
I'm happy with the swap..
Old Sep 25, 2001 | 12:35 AM
lonsal's Avatar
You may need to adjust the IAC. Pull the connector out of the IAC, then adjust the throttle stop for the rpm's at idle. Then shut off the engine and plug back in the IAC connector. I am still playing with the fuel pressure regulator on mine. BTW, my track times are at a new track that just opened at the California Speedway in Fontana, CA. I ran a best of 15.495 @ 89.92 mph. 60' was 2.323. Unfortunately I was rejected at tech for not having a current proof of insurance, (mine was 4 months expired). I had to race home (67 miles round trip) and didn't get my first race in until nearly noon. Mid 90's temperature by then. Next Street Legal Drag session in a couple of weeks.
Old Sep 25, 2001 | 11:38 AM
BahamutRS's Avatar
Not only that, but if you improve your 60 ft a little more, then you'll be into low 15's, and depending on the weather, maybe you'll hit 14's. Good luck =D
Old Sep 25, 2001 | 04:43 PM
NJ SPEEDER's Avatar
do you have a stick or auto? if you have an auto, a good convertor, somthing around 3000-3400 stall would prolly bring back a lot of that torque it feels like you lost. that cam is designed to put peak torque around 3200rpm in a 350 motor, so it is prolly slightly above that in the 305.
later
tim
Old Sep 25, 2001 | 05:24 PM
Honestly, I don't mind that I lost low end torque.. It actually makes the car easier to drive in traffic.. I don't have to constantly slow down so much now..
Old Sep 26, 2001 | 06:35 PM
91 Bandit II's Avatar
What are the numbers for the "LT1 cam"? Lift, duration, etc?
Old Sep 26, 2001 | 09:19 PM
lonsal's Avatar
Scroll down on this link for the LT1 cam spec's. https://www.thirdgen.org/messgboard/...ML/002357.html
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
Cameeeero
Sep 18, 2015 04:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
jharrison5
Aug 19, 2015 05:53 PM
