quick help ordering intake and cam??
Old Sep 19, 2001 | 11:14 PM
91camaro305RS's Avatar
got a 91 305 tbi..planning on getting headers cam intake....upgrade tbi if needed chip and fuel regulator if needed.......was looking at the performer tbi intake....need a good cam? please help...i want to uses the stock roller lifter and rods....engine have 71,000 on it and there are in good shape.....want a good cam setup that will work with what i have listed and a good set of headers......i want to keep the computer happy but get the most gain....could some one give me the part #'s to that cam i need pref crane or comp...cam....with the lifts also.....and i was planning on a gear setup.....will i be able to so that with me cam swap...and is there anything special i need to get..thanks
nathan
Old Sep 20, 2001 | 12:21 AM
ZRATED's Avatar
You should go with lt1 cam it is the best cam for our cars and is very cheap and easy to find!!
One Tight Teal green 91 RS (my first car
All Rustangs suck!!!!
5.0 TBI with Auto trans
Z-28 wheels
K&n with dual snorkel intake
Tx Smog Pump Delete option
Valve cover breather
Rapid Fire plugs with Accel ignition wires,coil,cap and rotor
Flowtech headers with flowmaster and Half way cutout
B&M shift kit with trans cooler and hurst hotshift fulid
Hypertech thermomaster chip
96 LT1 cam with
New liffters and timing chain
All the free TBI mods
Old Sep 20, 2001 | 01:25 AM
chevyguy8's Avatar
ZRated,
What are you running with your mods?
Any HP estimates?
thanks
91 Camaro LO3 RS 5-spd
Open air element,
ACCEL 8mm wires w/cap n rotor,
K&N filter,
flowmaster,
Edel. TES Headers and custom 3" I-pipe(not installed yet).
dual fans,
82 glass hood with open vents,
removed grille,
16" Chrome IROC-Zs,
Z28 wing
[This message has been edited by chevyguy8 (edited September 19, 2001).]
Old Sep 20, 2001 | 06:30 AM
is there a cran or comp cam that is close to the lt1 cam....? or whaty yr is the best...or can i go to advanced and ask for a replacement cam for a lt1 certain year and engine please help thanks
also is a zoom double roller any good?
Old Sep 20, 2001 | 02:13 PM
BahamutRS's Avatar
There were five or seven (I forget) different grinds for the LT1 cam. I don't think it matters which one you get, but you'll probably have to shave a bushing off the end of the cam to make it fit, but that's all...I got mine out of a 1996 Corvette, almost brand new, because he bought the car, never drove it, and then swapped a hotter cam in right away. It doesn't matter though, ANYTHING is better than the L03 cam.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
MSD 8.5mm plug wires
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 21, 2001 | 02:13 AM
ZRATED's Avatar
My fastest time was 15.34 at 90 mph that was with a short belt and a half way cut out, with neg traction and 2.73s.
I have not ran it yet with cam in becuase I am waiting for my 3.42 gears and posi to come in. The lt1 cam will make a noticeble difference in your car.
Z-28 wheels
96 LT1 cam with
Old Sep 21, 2001 | 02:18 AM
ZRATED's Avatar
The lt1 cam will also give you a much tighter sound out of the exaust pipes!!
Old Sep 22, 2001 | 08:31 PM
DM91RS's Avatar
Car: 91 RS
ZRATED, did you do anything to your heads when you changed the cams? I mean such as porting and or changing the springs. Also are you still running the stock intake? Thanks for a reply!
[This message has been edited by DM91RS (edited September 23, 2001).]
Old Sep 23, 2001 | 01:08 PM
DM91RS's Avatar
Car: 91 RS
Another question has come to mind after reading the Car Craft article about a 300plus HP 305 buildup. If the intake for the stock heads does need replacing does it make sense to spend 15 bucks more and get the Edelbrock RPM intake? It made more power with the stock setup on the test motor they used. How do you guys think that it will work with the stock heads and LT4 cam? Thanks!
91 RS 5.0 TBI....Edel. TES headers .. 3" exhaust ..... 5spd 3.08
Old Sep 23, 2001 | 05:21 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
if you want it to run well right off the bat without a chip stay mild. Id suggest a performer RPM and an L98 or LT1 cam
Old Sep 23, 2001 | 06:08 PM
DM91RS's Avatar
Car: 91 RS
Hey Pablo. Doing well I hope. I just now burnt a new chip from the stock 91 to remove the speed limiter and raise the idle to at least where I can tell it's running. I will be using the LT4 cam that I have. Think I should use the 1.6 rollers as well or will that be too much?
Old Sep 29, 2001 | 09:58 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
stock springs will die with the 1.6's and you should have adjusted the idle manually along with the desired idle in the chip so that you keep your IAC counts down at idle. You want most of the air passing through the throttle blades rather than the IAC passage.
Old Sep 29, 2001 | 02:26 PM
DM91RS's Avatar
Car: 91 RS
Springs will be new with 1.6 rockers. The car idles right where I set it. I did not pay much attention to the idle air counts the last time that I had my scanner hooked up. I'm fixing to drop the oil pan and see what it looks like and if things look decent I may install my Vortec top end and see what it will do. See ya.
Jake_92RS
Jan 28, 2020 10:37 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
