TBI Upgrades....?
Old Sep 27, 2001 | 01:22 PM
Chad's Avatar
TBI Upgrades....?
I have an 89 RS with a 305 TBI. I have the 14x3 K&N and spintech exhaust. Who has a better TBI unit? Any suggestions? Also, if I change my cam to a LT1, what will I have to do for smog and for it to run correctly. Kinda new to all this, so as much info you can provide will be greatly appreciated. Thank you!
Old Sep 27, 2001 | 07:42 PM
JPrevost's Avatar
Car: 91 Red Sled
The cam should pass the sniff test as long as you have a cat converter and a working EGR system.
Read a lot of the old posts and use the search tool to find info about TB units and why most of use agree they aren't needed unless you're pushing 300+hp.
, Jon (350 TBI!)
91 Red My website
Old Sep 27, 2001 | 10:12 PM
TriGenRS's Avatar
"Who has a better TBI unit?"
You dont need a high flow TBI right now.
Go here:
https://www.thirdgen.org/newdesign/t...imatetbi.shtml
https://www.thirdgen.org/newdesign/t...matetbi2.shtml
or
http://www.turbocity.com
But to answer you question...Holley makes a 670 TBI with 68#? injectors. You could also steal one from a 454 truck and that has 70+# injectors. Both are 2" throttle bores...bigger than your current manifold setup.
89CamaroRS
Power Rating: 1.21 Jigowatts
Mods:Flux Capacitor
Future Plans: Time Travel
Old Sep 28, 2001 | 10:11 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using a ported rochester throttle body from Turbo City.Chose this over Holley because I've heard the GM injectors are a little more reliable than the ones on the Holley.Probably don't need either unless you've got 300HP+.
Rich
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Sep 28, 2001 | 10:32 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
in holleys support, they are using newer injectors now.
how do you like your spintech exhaust?
Old Sep 28, 2001 | 05:22 PM
Chad's Avatar
I love my spintech exhaust! Glad I got rid of my Flowmaster.
Old Sep 30, 2001 | 05:45 PM
snflupigus's Avatar
deeper? louder? crisper? less hollow? than flowmaster?
Old Sep 30, 2001 | 09:04 PM
Chad's Avatar
It's deeper, lighter, and ALOT more flow! I noticed an increase in performance just betweeen this and the Flowmaster.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
