Odd noise while accelerating...
Old Oct 6, 2001 | 03:57 AM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
When I rev the engine, engine sounds fine, but when I'm on the street and driving, the engine makes a sort of "ticking" noise. As soon as I let off the gas, it stops. Ccould this be one of the injectors or something? The car dosen't lack performance, just "ticks". Please help....
1988 Camaro Sport Coupe
  • 305 TBI
  • 700R-4
  • 14"x3" K&N Filter
  • Flowmaster Cat Back System w/ 3&1/2" tips
  • Y2K Origional Vette Rims
  • Pioneer 6200 Deck
  • 2 Kenwood 600 watts
  • 2 Infinity Reference Subs
  • Sony 3-way 6x9s in custom panels
  • up to 137.0 dB
  • "speed" stripes
Coming soon...4th Gen Seats
Old Oct 6, 2001 | 10:55 AM
pianiy's Avatar
That could be valve tap or possibly pinging. Better hope its the latter, check your timing and upgrade your gas for that.
~Luke
'91 Firebird :: L03/700R4 ::
Mods: Catco cat - Flowmaster 80 series - B&M Shift kit - TA tail lights - GTA rims - K&N - MacEwen guages
Stereo: Pioneer DEH-P8200R - Cadence 4x6's - Pioneer 6x9's - Kicker amps - Kicker 10" CompVR
Firebird parts - Selling an '80 Firebird for a friend
Moderator of tranny board over at TransAmGTA.com
Old Oct 6, 2001 | 11:55 AM
Could it be the speedometer? I did put in a 140mph one from a junkyard with a broken odometer and tripometer....but I'll check the timing today.
[This message has been edited by coolguywalt (edited October 06, 2001).]
Old Oct 9, 2001 | 12:36 PM
<font face="Verdana, Arial" size="2">Originally posted by coolguywalt:
</font>
Someone help me out here....
Old Oct 9, 2001 | 01:01 PM
z28camaro396's Avatar
My stock speedometer ticks sometimes as well and my tripometer doesn't work. It was like that when i bought it. Mine doesn't tick all the time but just sometimes like starting up on a cold day and stuff. Check your speedo cable, it may be a little lose and in need of lubrication or something. Does it tick when you aren't driving (i.e. at a red light, when you crank it up)?
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), Kenwood c.d. player, Sony Xplod 6x9's, Blaupunkt 3 1/2's.
Old Oct 10, 2001 | 07:34 AM
89rsRod's Avatar
hey it could be your open air element, mine started doing the same thing right after i installed my OAE, only when i drive does it tick
Old Oct 10, 2001 | 01:59 PM
Well, I think that I have it isolated to what it is....the tickingis coming from the #7 cylinder, somewhere in the valvetrain. Could it be a loose rocker arm? anything else? The odd thing is that it is ONLY THAT CYLINDER! The rest are really quiet.
Old Oct 14, 2001 | 01:19 AM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Try to tighten the exhaust manifold, my car did the same thing and that was the problem. It is a turd to do
Old Oct 14, 2001 | 02:01 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I agree with MightyMouse.. my RS does the exact same thing, I found it to be my drivers side exhaust manifold.. snug it back down, and it'll be quite for a couple of weeks, then it started up again.. I tighened it back up again today.. it's making be consider headers... Oh and since you think it's Cyl #7, tighten the back nuts first.. but make sure you spray on some WD40 or similar penitrating oil if it's all rusty. Does anyone have tips on how to stop the nuts from coming loose again & again..
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
[This message has been edited by FastElectrics (edited October 14, 2001).]
Old Oct 14, 2001 | 09:42 AM
ONEFINE8T9's Avatar
locktite
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Oct 14, 2001 | 10:47 AM
DM91RS's Avatar
Car: 91 RS
Use 3/8 split lockwashers. They will help keep it from vibrating loose. Good luck!
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...
Old Oct 14, 2001 | 11:59 AM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
The OE exhaust manifold has tabs that can be folded down to lock the bolts in place. It is hard as hell to do though (you'll notice the tabs when you relize that the socket won't go on.)
Old Oct 14, 2001 | 03:48 PM
Thanks guys! I'll go try that right now....
Old Oct 15, 2001 | 06:10 PM
Yup, that quieted it down DRAMATICLY!!! Well, it is still there, but you have to listen for it really hard now....by the way, is the noise caused by leaking exhaust gas?
Old Oct 19, 2001 | 08:25 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
YES
Old Oct 25, 2001 | 04:35 AM
TBIfly's Avatar
Ive had the same issues and continue to have them.
There are 2 distinguishable noises...
pinging..which only began to occur upon acceleration after i had the timing advanced 2 degrees.. (going to drop it one to cure the ailment)
pinging also only occured in the 1500-2500 RPM range...even after upgrading to 91 octane.
The other noise is definitely exhaust leak...usually most common at the collectors (donuts) just tighten all the bolts down, and if you are feeling a bit froggy, jump on replacing those gaskets too. as for the collectors...after the gaskets...locktite them puppies.
the only other noise i can think you may be referring to is the vroom sound....its supposed to do that.
db057
Jan 10, 2020 08:55 PM
Mark_ZZ3
May 24, 2018 01:02 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
