car idlin high
Old Oct 20, 2001 | 03:45 PM
Trent257's Avatar
car idlin high
how can i adjust it, today after work i sat in my car for like 10 minutes and it was idling at 1500??
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
----Comming in a few days----
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco HighFlow catco cat
Old Oct 20, 2001 | 04:13 PM
NJ SPEEDER's Avatar
what was the water temp and the outside air temp?
if ti was cold it may just be taking a while for the car to get up to temp and get out of the warm up loop in hte computer.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Oct 20, 2001 | 04:20 PM
Trent257's Avatar
it was about 65 outside, and it had been sitting for 9 hours while i was working
Trent
---Car---
---Stero---
profile cl640 110x4
Old Oct 21, 2001 | 10:00 PM
Keith5's Avatar
Car: C1500
If you drive it right away how long does it take it to drop down?
1989 Pontiac Firebird Formula LO3/700R4
-180 degree stat, Hooker Cat-Back, Wonder Bar
http://www.geocities.com/krt80/
Old Oct 21, 2001 | 10:02 PM
Trent257's Avatar
as soon as i put it in park,
Trent
---Car---
---Stero---
profile cl640 110x4
Old Oct 21, 2001 | 10:48 PM
Neo's Avatar
Neo
<font face="Verdana, Arial" size="2">Originally posted by Trent257:
</font>
Mine does the same thing.
Old Oct 23, 2001 | 08:51 AM
Keith5's Avatar
Car: C1500
I mean how long does it take it to drop down even after you put it in neutral. About 3 or 4 minutes on the road and mine is normal, I think.
Old Oct 23, 2001 | 08:16 PM
FiReBReTHa's Avatar
whats the typical idle, i think mines hitting.... bout... 800.... with ignition prob i think
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 25, 2001 | 04:18 AM
TBIfly's Avatar
91 RS T-5
I had my car taken in for diagnostics a few weeks ago and found the timing was retarded a bit. the guy advanced it 2 degrees and now it revs for a bit (only noticed a couple days ago) at about 12-1400.
I also have low RPM ping...even with 91 octane..so im gonna have it retarded 1 degree....
Id say take it in for the $60 dollar diag.
Old Oct 25, 2001 | 11:09 AM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by TBIfly:
Id say take it in for the $60 dollar diag.</font>
WTF???!! Don't do that! 1500 rpm is normal when your car is cold!
1 degree of timing ain't gonna to @#$@.
Old Oct 25, 2001 | 11:15 AM
manuel's Avatar
I had that prob. =D
If you want my advice.You need to tell us how is the RPM in drive. After you go home, how is the engine temp and RPM while driving and in park. Good luck.
Mustangs and Camaros can run, but birds can Fly_-^
Old Oct 25, 2001 | 11:41 AM
deadtrend1's Avatar
I had this problem once, i broke the pigtail wire harness putting my chrome valve covers on and that made it not get the voltage to drop the idle plunger. It was up about 15-1700 rpms.
Old Oct 25, 2001 | 04:24 PM
TBIfly's Avatar
Keith, 2 degrees made a draastic change in my car's operation, so 1 degree is bound to make a considerable difference.
In southern Ca...the air temp rarely drops below 40... so even at idle (speaking only of the 2 camaros ive worked on and my experience alone) the car idled at 900-1100 after just starting the car.
not fast....not pretty....but has great potential for both.
Old Oct 25, 2001 | 11:58 PM
Keith5's Avatar
Car: C1500
I've played with my timing before and 1 or 2 degrees still doesn't do @#$@.
It's normal for our cars to idle at 1500 when they are cold. In drive cold they should probably idle around 1000. After they have warmed up and are in drive they should idle at 500.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Linson
Aug 21, 2015 02:12 PM
Exxon Limited
Aug 9, 2015 08:13 PM
