Who here can burn me a custom TBI chip?
Old Oct 24, 2001 | 12:34 AM
Nate Hanson's Avatar
I need someone to burn me a chip for my truck. PLEASE HELP ME OUT!!
thanks so much
nate
Old Oct 30, 2001 | 09:44 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Ed Wright at Fastchip guarantees nobody's chip is faster.Custom is $350.Have heard many good reports about his work.
http://www.fastchip.com/index.htm
-Rich-
Old Oct 30, 2001 | 10:22 AM
Kyle F's Avatar
Jprevost burns Proms. Hes a college student in Columbus Ohio so I am sure he would do you one for some extra money. That is if you could make it down to columbus
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Oct 30, 2001 | 10:34 AM
JPrevost's Avatar
Car: 91 Red Sled
Before you jump into a custom eprom....why do you need one? What have you done that requires a custom eprom and not just fuel pressure tweak?
Old Oct 30, 2001 | 11:54 AM
I have installed a cam and aftermarket intake. I am also am going to be installing headers, roller rockers, and exhuast soon. what do you guys think? i think my chip is just to "general" for what I have done.
thanks
nate
Old Oct 30, 2001 | 05:30 PM
DM91RS's Avatar
Car: 91 RS
With the mod's in my sig I have not even had to raise fuel pressure yet and I am not running lean and have very few knock counts on the scanner. No counts at WOT or part throttle accel. Only in 5th gear hwy hill climbing. But with a 3.08 rear and .63 5th gear I cruise with a 1.94 final drive! WTF was GM thinking about with that tall of an OD?
You can probably do more mods with only fuel pressure adjustments. See what NJSpeeder has done without a custom chip!
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Oct 31, 2001 | 06:32 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Honestly, we can't really determine if you "need" a new chip or not without knowing the specs on the new cam. The Intake, Headers, exhust and Roller rockers won't "require" and new chip. The cam is what will make a lot of dfference. take a look at my setup below. It was slow as he!! before I started burning my own chips and it was the cam that screwed everything up for me.
-Lars
Old Oct 31, 2001 | 12:08 PM
fast_broker's Avatar
what they are saying is that if you have a mellow cam, mellow intake and stock exhaust, you may not need a cam. Are you running EGR? That matters too. what type of gas? what is your FP??? Then, when you add gears/headers/etc, you will have to do it all again... get it?
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
