Truck Aircleaner Setup on Camaro
Old Nov 5, 2001 | 10:22 PM
jcjohnston78's Avatar
I know that a lid of a 350 pickup will on a camaro's airclean setup, but will the whole truck aircleaner setup fit under the hood??
92 camaro RS 305tbi
hypertech thermomaster chip and 160 stat
accel racing wires
accel supercoil
accel cap and router
splitfire plugs
Old Nov 5, 2001 | 11:05 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
It should fit, but what you'll probably have to do is remove the spacer ring that chevy puts around the TBI. As for the hoses and stuff from the air cleaner that shouldn't be a big deal either, may have to slightly reroute it. If you do, try to run it somewhere where it'll get colder air...
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Nov 5, 2001 | 11:40 PM
that tbi spacer ring thingy is in the ultimate tbi tech pages right? Which hose are you talking about, im trying to get a aircleaner setup that comes out on the driver side if possible, So i can set up a cold air setup.......I found pic of the setup.
92 camaro RS 305tbi
accel racing wires
accel supercoil
splitfire plugs
Old Nov 6, 2001 | 11:40 PM
burntblues's Avatar
Car: 1989 Camaro RS
The spacer ring that I'm talking about just sits right on top of the tbi and the aircleaner will sit right on top of that. I can't think of any of the truck TBI aircleaners that will come out on the drivers side, most will exit over the passengers side, over the battery. You might also want to check on a monte carlo intake, they tend to be much bigger and have a larger diameter hose than ours.
I made a custom ram air setup for mine using the 2.8 liter setup. Its pretty sweet, takes air in from the grill and looks totally stock, if I can find a camera I'll send you a pic.
Send that one picture over though, I'd be interested in seeing it.
Mike
Old Nov 6, 2001 | 11:52 PM
is the monte carlo, aircleaner setup as big as a truck or just a little smaller
92 camaro RS 305tbi
accel racing wires
accel supercoil
splitfire plugs
Old Nov 7, 2001 | 09:13 AM
burntblues's Avatar
Car: 1989 Camaro RS
I'm guessing it might just be a little smaller. There is a good chance however that it'll be the same as the truck aircleaner. The lid is the same as the one in the pic you sent if I remember right...
-=-Mike
Terrell351
Jun 13, 2021 01:13 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
gta90
Sep 15, 2015 04:00 PM
355tpipickup
Aug 13, 2015 07:35 AM
squiggy2
Aug 9, 2015 09:30 PM
