Best bang for the buck on TBI mods?
Old Nov 15, 2001 | 12:20 PM
super chevy's Avatar
Have owned a few TPI cars, but just bought a '93 Chevy 1/2 ton with 350 and TBI. I've read the tech articles, and already ordered some Edelbrock shorty headers from Summit. I would like to get a supercharger kit one day, but for now, as is a daily driver, real world mod ideas wanted.
Thanks,
SC
Old Nov 15, 2001 | 12:45 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
You're on the right track.Headers,Rearend Gears,Cam.Easy things are,Open Element Air Cleaner,Pulleys.A custom chip and a cam will make a big difference together.Relocating the IAT Sensor to a cooler location is worthwhile.Check out other questions on this forum.
-Rich-
Old Nov 15, 2001 | 02:53 PM
JPrevost's Avatar
Car: 91 Red Sled
Relocating the IAT to a cooler place does the same thing as adjusting fuel pressure. The only difference is that it's 10 times easier to adjust fuel pressure for a best mph in the 1/4 than it is to "relocate" your IAT.
I'll have to say the easiest mods are the ultimate TBI mods in the tech section and an open element. Next would be the adjustable fuel pressure. I'd do that before or during the header install. Basically your car will want more fuel and the ecm under light throttle will say: BLM ~132 or more after the open element and headers. When you go WOT the ecm defaults back to 128 which is obviously lean = bad for WOT and PE mode.
Do it right the first time. You'd be suprised what some simple things like fuel pressure will do for a car. Most guys that go from TPI or TBI to carb never thought about playing with fuel pressure or injector size. It's like slapping on a carb and not tuning it. Oh well, definatly go open element, worth the whole $15
[This message has been edited by JPrevost (edited November 15, 2001).]
Old Nov 15, 2001 | 07:30 PM
FRMULA's Avatar
Nitrous... period, best bang for the buck
Old Nov 15, 2001 | 08:35 PM
NJ SPEEDER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FRMULA:
Nitrous... period, best bang for the buck</font>
nitrous!!! best part time bang for the buck
for all aroudn use you will get the biggest gains from a little bit of gear, a full exhaust, and an open element air cleaner.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Nov 15, 2001 | 11:13 PM
Thanks guys. The truck's got a factory 3.73 posi rear. The Edelbrock headers will be here tomorrow. Going to order one of those air-raid high flow intakes/filters. Anybody know where to get one of those vacuum-referenced adjustable fuel pressure regs?
SC
Old Nov 16, 2001 | 05:08 AM
Jza's Avatar
Jza
Dealer.
Vac. Adjustable GM TBI regulator P/N 17113186 (~$41)
Old Nov 16, 2001 | 10:23 AM
BahamutRS's Avatar
Thanks for the part number...I'd rather get that one from GM for cheaper than the JET one.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Old Nov 16, 2001 | 01:47 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Heheh.. yeah.. you simply can't beat the "bang" you hear when a piston goes flying through your oil pan and nails the asphalt..
'88 Camaro, hunter green metallic, T-top
LO3 305 TBI/700r4
Performance mods: MSD Coil
Audio mods: Pioneer DEH-P3000, Pioneer 6x9s, Optimum 260 watt 3 channel amp driving 6x9's, prepping to build sealed glass sub box for single 12"
'86 Camaro, ultra silver metallic /w dark blue metallic racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: Accel 8mm wires, SplitFire plugs, Gabriel hijackers, poly swaybar bushings.
My Homepage, with pics.
Old Nov 16, 2001 | 02:05 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have a 92 GMC 1500 stepside with the 350, 5speed factory option. As you know the redline on the truck engine is 4500 rpm. It feels like its dead by 4000rpm. What woke my truck up was the LT1 roller cam. The truck block has all the provisions for the roller cam but didn't get it. I just bought the LT1 cam, roller lifters, spyder cradle, pushrods and valve springs from a 94 LT1 Z28 and put them in my truck. The difference is nothing short of incredible. It runs strong and clear to 5500rpm now. I run Edelbrock headers and random technology cat with dynamax catback. I ran a paxton supercharger (wish I had it with that cam) on it for 4 years too so email me if you want to talk about that too.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***getting ready for new engine. TBI version of this http://www.airflowresearch.com/Articles/A3-P1.htm
Old Nov 16, 2001 | 03:08 PM
I like the idea of the LT1 cam. The cam isn't a direct swap for my '93? I thought the roller lifters, etc were the same. If they aren't, does anyone make a cam for my block with same/similar specs? Did you put on the Edelbrock or GM tbi intake manifold, also? Are those manifolds worth the money?
Thanks,
SC
Old Nov 16, 2001 | 07:37 PM
killer305's Avatar
you cant really maximize hp and torque with single mods, it takes more of a package. you want an fuel press reg, and a open element. but you hear people on here saying "WTF my headers only gained me 1/10th in the 1/4" they dont understand that if you thow heads, intake, cam an headers at the same that you will get much more bang for buck then doing individual mods. i gaurantte that is you added heads, intake, cam and heads speratly on a dyno, and after each run raplcing it with the factor and adding a different mod, and added up the hp gain on each mod it would be much lower than if you used them all at the same time. however this bang for the buck is like compairing a shotgun to a bb gun. yeah the shotgun will cost more, but you will definatly get more power. so if i were going with "cheap" mods i would have to go with NOS. i dont know anouther was of pending 550$ and getting 125hp, if anyone here knows, SHARE THE WEALTH.
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
92firebirdguy
Sep 1, 2016 07:53 AM
69GTOby
Apr 18, 2016 02:34 PM
Glowsock
Sep 11, 2015 11:09 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
