91 Camaro Service light flashing.... one the key is on....
Old Nov 19, 2001 | 11:57 PM
91camaro305RS's Avatar
ok what could be causeing my service engine light to come on and stay flashing very rapidly....even with just the ignition turned on with the car off....its seems to idle high..and the tranny seems to be in limp mod....i need help please...
thanks
nathan
Old Nov 20, 2001 | 12:06 AM
chevySS's Avatar
The service engine light always comes on when you turn the key on before you start it. You sure it doesnt go off when you actually start the car?
Teal Green 91 Camaro RS
305, Automatic Tranny
Stock for now
Old Nov 20, 2001 | 12:12 AM
Flashing....do you see that...Flashing....i'm not stupid.....flaashing all the time....pleae help
Old Nov 20, 2001 | 02:56 AM
Jza's Avatar
Jza
There might be a short to ground in the wire that leads to the A pin in the ALDL connector. That would put the car in field service mode and would cause the SES light to flash. Just a theory.
Old Nov 20, 2001 | 02:58 AM
Jza's Avatar
Jza
<font face="Verdana, Arial" size="2">Originally posted by Jza:
There might be a short to ground in the wire that leads to the A pin in the ALDL connector. That would put the car in diagnostic mode (engine off) or field service mode (engine running) and would cause the SES light to flash. Just a theory.</font>
Old Nov 20, 2001 | 07:33 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Have you messed with the prom lately. That is what is causing mine to flash rapidly. Its in LIMP mode. Runs like crap.
Old Nov 20, 2001 | 05:05 PM
yes..shes in limp mode....high idle...how do i get her out of limp mode...this all happened after a lt1 cam and edel intake....soon headers
thanks nathan
Old Nov 21, 2001 | 11:05 AM
Mine is stuck in limp mode as well. Waiting for new ECM to see if that cures it.
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
