Cam Query
Old Nov 20, 2001 | 10:50 PM
Buck268's Avatar
Cam Query
I have a LO3, daily driver, cold and hot weather (Michigan). As of now, totally stock, getting open air soon, and flowmaster 80. What would a good camm set up be? What type of lift and duration? Should I get 1/6 rockers? good gains? Thanx!
Old Nov 21, 2001 | 09:51 AM
fast_broker's Avatar
IMO, get a Summit cheapo 204/214deg at .050" lift with .420"/.442" LIFT CAM FOR $79 or so. Worth it's weight in gold and computer will work fine.
Old Nov 21, 2001 | 10:18 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I concur. Thats probably the best bang for the buck in terms of cam. If you want to spend more, consider the one of the Comp Cams Xtreme Energy grinds, along with new lifters and valve springs.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Nov 21, 2001 | 11:15 AM
92Camaro305TBI's Avatar
Anyone recommend the L98 cam with 1.6 rocker For a mild to high modified LO3?
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
Old Nov 21, 2001 | 11:54 AM
DAHULK2000's Avatar
I've heard LT1 or LT4 cams are good for LO3's? Is this true, or the summit one is better?...
92 Firebird 305 TBI
K&N Open Air Element
K&N Crank Case Filter
Just a begginer, soon i will advance!
Old Nov 21, 2001 | 01:30 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
any year lt1 cam is a great choice for an LO3 however keep in mind i would recommend you change the valve springs as well b/c the stock springs normal cant handle an lt1 cams lift for very long.. a set of lt4 valve springs 40-45, a used lt1 30-50 or so..
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets,posi 323 , lt1 cam and new valve springs
Old Nov 21, 2001 | 01:59 PM
ZRATED's Avatar
I put in my lt1 cam a few months ago and I was wondering how hard it is to replace the valve springs on the lo3?
Old Nov 21, 2001 | 07:21 PM
Buck268's Avatar
What if I just installed 1.6 rocker arms inplace of the 1.5's, would that help any noticable amount? Also, did the LO3 have flat tappet, or what?
Old Nov 21, 2001 | 09:23 PM
Nitroburn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Buck268:
What if I just installed 1.6 rocker arms inplace of the 1.5's, would that help any noticable amount? Also, did the LO3 have flat tappet, or what?</font>
Just installing 1.6 rockers will give you a little more on the low end torque, but that's about it. It will not change the operating range of the engine. The stock HYD. ROLLER cam has .234I/.257E lift (at the lobe) with 1.5 rockers that's .351I/.385E VALVE lift. If you were to use 1.6 rockers, the total valve lift would be .374I/.411E. The duration would increase only SLIGHTLY @.050 lift.
89 T-Top Firebird 305 TBI Project Car (with approval from my wife!)
[This message has been edited by Nitroburn (edited November 21, 2001).]
Old Nov 21, 2001 | 09:26 PM
Buck268's Avatar
wow, thanx for the indepth response, I am still trying to learn all I can, so that was great!
Old Nov 22, 2001 | 12:55 PM
Buck268's Avatar
Who makes a good (keep in mind budget) 1.6 roller rocker set?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
