High Idle problem
Old Nov 27, 2001 | 08:12 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
High Idle problem
My car suddenly has a vey high idle, we are talking in the neighborhood of 1500 to 2000 rpms. when I am in gear it is almost like I am using cruie control. Above the 2000 rpm range the car runs fine. When the clutch is pushed in, the rpm's go up instead of down. Only mods are open element, catback and pullies. Any sugestions
Old Nov 27, 2001 | 08:53 PM
89 4Mula 350 Tbi's Avatar
check your throttle make sure its not sticking you know check the obvious first
If all that checks out check your pipes are they really black like the car is running rich. Check your tps but if your tps was that much out of wack the comp should and would have set a code
I would check the throttle. Do you have after market pedals cause they dont like our cars gas pedal they stick to the side of the tunnel sometimes.
Old Nov 27, 2001 | 08:59 PM
JPrevost's Avatar
Car: 91 Red Sled
Check the throttle blades, check the IAC to make sure it isn't stuck open, then make sure you don't have a vacuum leak. Those are the most common reasons for a high idle.
, Jon (350 TBI!)
91 Red My website
Old Nov 27, 2001 | 09:19 PM
deadtrend1's Avatar
i had the same problem when i put my chrome valve covers in. Seems that i broke the 4 wire harness leading into my IAC, and i had to jerry rigg it for a week till i got a new pigtail harness. Its on the passenger side on the botton of the throttle body.
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
Old Nov 28, 2001 | 06:17 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I've noticed the same thing after I started exhaust mods.
Does the idle stay high or come down slowly?
Assuming everything in the previous posts check out. It can be normal for your idle to stay high for a few seconds and then drop. You have alot more air going through with your exhaust, and your ECM/O2 sensor may be compensating by raising your idle.
Sometimes my idle will hover at around 1500rpms for a second and then slowly go down to normal range whenever I shift out of gear.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Old Nov 28, 2001 | 08:26 AM
Car: 1992 Camaro
Engine: 350 miniram
Thanks for the suggestions, I am going to check all of those things today. So far the computer has not set a code.
Old Nov 29, 2001 | 09:50 PM
Car: 1992 Camaro
Engine: 350 miniram
On my drive home tonight, which is the first time I have driven the car since my post, I noticed that the high idle conditon was still present when I would push in the clutch. Then if I tapped the gas pedal to rev up the rpm's the car would then fall into its normal 650 rpm idle speed. Do you think it is my throttle sticking or something else. How should I go about fixing it.
[This message has been edited by david auster (edited November 29, 2001).]
Old Dec 3, 2001 | 01:22 AM
kingtygr's Avatar
I have somewhat the same problem. when I start my car up cold, it will idle high, any where from 1000 to 2000, when it normally idles at around 550. it only does it cold though, once the engine warms up it's fine. and like was said before, if I tap the accelerator it'll drop beck down, sometimes. what could cause this? I recently rebuilt my TBI and tried to adjust the TPS the way the chilton manual says to, but it didn't seem to work the way they said it would, so i just tightened it down, other than the idle problem it runs fine, and no check engine light. (unless it's burnt out, but a burnt out SES light?)
Hondas get all the girls.
Camaro's get all the women.
'89 Camaro RS T-top L03, no mods.... yet.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 17, 2015 02:52 PM
