Cam
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Cam
I am going to be putting a cam in. I was thinking about going with the LT4 cam, I know alot of you guys have LT1 cams. But has I would like some opinions on the LT4.
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
The LT4 got me a little over 300hp in my car. The lift however will cause you to get the valve guids ground to accept the lift. YOu can see my parts in my sig.....I may be selling my LT4 cam and roller lifters.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Brian
1989 Camaro RS
Car: 89 Camaro
Engine: 97 LT1
hmmm I was wondering if the lift would be a problem. I really want the LT4 I thought I could get away with just slapping it in there though. Why are you getting rid of yours if you dont mind me asking?
I was thinking of getting a LT4 cam too. So what would i have to change? I thought it could just be easily swaped........thanx for any info!
92 Firebird 305 TBI
K&N Open Air Element
K&N Crank Case Filter
Just a begginer, soon i will advance!
92 Firebird 305 TBI
HEy Guys...
What about a L98 Cam with reworked heads?
Sound good. I want to get to 300HP. so.. will this help with my goal?
thanks
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
thanks
Car: 91 RS
LT4 cam went in my LO3 with no problems.
Stock heads, springs, seals and valves.
Stock rocker arms.
Installed new timing chain set.
Run's good. I am replacing the heads and intake and rocker arms is the reason that I did not change the seals or springs. It will work but if you have alot of miles on the engine I would change them if you are not planning to change the heads.
Stock rocker arms.
Car: 89 Camaro
Engine: 97 LT1
Thats what I wanted to hear!! I was hoping that it would just go in with no problems. So you had to make no alterations to the heads at all right? Just making sure. I will however install the new timing chain set while I am in there. Thanks
Car: 91 RS
You don't have to touch the heads unless you're going to 1.6 rockers in which case you will have to extend the pushrod holes towards the rocker stud for clearance.
Good luck.
Good luck.
since i'm not really deep into the chevy's yet (key word yet), what models had lt4's in them? or even lt1's for that matter? think it'd be safe to go to a recycler and get one out of the block or just get a new one? I'm working everything up on paper for my L03, gonna restore my RS fully and soup up the engine till i decide to swap in a 350 and just use the mods out of the 305
Hondas get all the girls.
Camaro's get all the women.
'89 Camaro RS T-top L03, no mods.... yet.
only the 96 Grand sport and collectors editon corvettes have the lt4, it might be all manuals too but i cant remember. Its definitley only in 96. As for lt1's that 92-96(auto only) vettes and 93-97 fbodies
1984 Z51 Auto, Ported and polished intake, K&N, MSD, Ram air/Cold air intake, no cat, no AIR, no egr, no swirls plates
[This message has been edited by nsimmons (edited December 05, 2001).]
www.sdpc2000.com had LT4 cams for $130 a couple months ago.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
since they're roller cams then they should still be good in used engines right? hopefully i can find a junk yard around here that won't know the difference between any of em and get one cheap.
Yeah, I know, as soon I saw corvette, I knew I'd be better off just buying one, unless I got reeeeeally lucky, which I probably won't.
By the way, how much would a professional porting job for heads cost on average? If I was careful think I could do a good enough job myself? I am mechanically inclined, just want to know if it's best to leave that to pro's
'89 Camaro RS T-top L03, T5, 3.08 10 bolt stock rear, Edelbrock Pro-Flow filter, more to come as the money flows....
Car: '00 Chevrolet Corvette
You're better off getting new heads than trying to (or paying to) port the LO3 stockers. They're junk. For not a whole lot more money and no more effort you could get everything that you need to put a set of Vortec heads on your car and you would be at least 10,000 times happier. Just my opinion though...
-Mark W.
'88 SC Camaro w/ 305 TBI
-Mark W.
Car: 91 RS
Ditto on the LO3 heads. Just look down the intake port and you will see why and if you don't understand then find a set of heads that are not swirlport and check them out. Half the port is blocked on the LO3's.
You should be able to find a set of casting number 081's cheap and then do a mild porting job on them for cheap or do the above for new heads and add Vortec's or World 305's.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
No, I know that, I'm planning on getting new heads, probably the world torquers, but I was wondering about porting them. or would they not need it?
[This message has been edited by kingtygr (edited December 06, 2001).]
<font face="Verdana, Arial" size="2">Originally posted by 92Camaro305TBI:
HEy Guys...
What about a L98 Cam with vortech heads?
thanks
</font>
HEy Guys...
thanks
</font>
