cam question
Old Sep 15, 2007 | 06:10 PM
miked0002's Avatar
cam question
I have a 1990 rs tbi. My question is what would happen if i put a cam in for a non-computer controlled car? Thanks in advance for any help
Old Sep 15, 2007 | 06:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cam question
Depending on the cam, you could end up with too little vacuum for the computer to be happy.
Old Sep 15, 2007 | 06:22 PM
miked0002's Avatar
Re: cam question
its a comp cam extreme energy...i got it off a friend of mine
Old Sep 15, 2007 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: cam question
There are a lot of cams in the Xtreme Energy line, you need to know which one.
Old Sep 15, 2007 | 06:58 PM
miked0002's Avatar
Re: cam question
i cant figure it out. the part number doesnt come up anywhere.
Old Sep 15, 2007 | 07:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: cam question
What markings are there on the cam?
Old Sep 15, 2007 | 09:08 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Re: cam question
Overlap is a big factor when determining cam shaft compatibility. For example if a stock cam in a stock application idled at 30 map and you replaced it with a camshaft that idled at say 60 map it most likely wouldnt even idle because it would be rich. At open throttle it most likely would become extremely lean. Have you considered burning your own chips?
Old Sep 16, 2007 | 08:28 AM
miked0002's Avatar
Re: cam question
i don't know how to burn a chip, i don't know what that is. i'll just buy a new one for my car. but the markings on it are 1z306262 and on the other side it has x e stamped into it
Old Sep 16, 2007 | 05:21 PM
Re: cam question
Its easy, Check out the stickies at the top of the message boards. There are a bunch of editors out there that make it very user friendly and its its fairly inexpensive. I was reluctant at first, but with my engine combination I was forced to learn. Now its just a fun hobly for me. My motor wouldn't even run on the stock programming. I'm so glad I took the time. This site is the most helpful I have found and there are some really brilliant members here who are more than willing to help whenever you ask...as long as you research first, questions here are never a problem.
Old Sep 17, 2007 | 07:24 PM
miked0002's Avatar
Re: cam question
is it gonna run if i put this cam in?
Old Sep 18, 2007 | 06:23 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: cam question
Simply put.....NO.....not a fat chance. Guys have stalling and drivability problems with the LT1 cam which is only marginally bigger than stock. Even if it did run, you won't gain any power because of the type of FI that TBI is. Tuning is a necesary evil with these cars. Once you get the hang of it, it's a blessing.
Old Sep 18, 2007 | 08:10 PM
miked0002's Avatar
Re: cam question
ok thank you. i guess i'll be carberating it then
Old Sep 18, 2007 | 08:44 PM
BMmonteSS's Avatar
Car: 84' Monte
Re: cam question
Just so it's perfectly clear, TBI is perfectly capable of supporting a big cam. It'll actualy run better than a carb would.....but it requires chip tuning.
Old Sep 19, 2007 | 10:05 AM
miked0002's Avatar
Re: cam question
isn't stuff for emission controlled cars more expensive?where i live we dont have emissions testing but, they do a visuial. so i can't even but headers on my car without failing that. isn't there a street rod plate or something i could get to by pass all of that
Old Sep 19, 2007 | 11:10 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: cam question
maybe you should tell us where you live first to determine that as what for the carb/tbi thing goes, it's always easy to slap on a carb, but i would go the other way and learn some custom chiptuning. you can probably achieve better performance than a carb with a properly set up tbi, plus better milage if you care.
Old Sep 20, 2007 | 12:31 PM
miked0002's Avatar
Re: cam question
i'm in eastern pennsylvania...a friend hade a lot of parts sitting around but i had to make it carb to use them
Old Sep 20, 2007 | 03:06 PM
BMmonteSS's Avatar
Car: 84' Monte
Re: cam question
PA has some screwly smog laws, and they vary so wildly between counties that if you ever move you could have to change everything. If you don't have an inspection station that will overlook things like headers then you really need to consider sticking with TBI.
You can still modifiy your car in a smog **** county, you just have to use parts that have a C.A.R.B. number. Eldelbrock makes some headers that has this number, all you have to do is supply this number at your inspection. Unfortunately there is no CARB number for swaping to a carb.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
