I have this problem with my fuel system
Old Oct 12, 2007 | 07:51 PM
ems2357's Avatar
Car: 1989 Chevrolet Camaro "RS"
Engine: LO3 305 V8 TBI
My 1989 Chevy Camaro RS 5.0 TBI, when u turn left or right the engine cuts out but if u go striat its perfect someone said it might be a blocked pick-up... What can i do to solve my problem? Can it also be my oil pressure switch? I appreate any help u can offer
Old Oct 12, 2007 | 11:22 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: I have this problem with my fuel system
It is probably in tank baffles are broken off. Does it happen with a full tank of gas???
//RF
Old Oct 13, 2007 | 11:24 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Also check your fuel pressure to make sure you maintain the constant 12-14
Old Oct 13, 2007 | 03:42 PM
ems2357's Avatar
//RF
no i cant let go under 3/4 tank of gas
Old Oct 13, 2007 | 03:53 PM
ems2357's Avatar
the gas gauge acts up also thanks Justin
i did its 13 psi
Old Oct 13, 2007 | 11:45 PM
RFmaster's Avatar
Car: 75 Beast
Well, it is the baffles. To keep fuel sock from uncovering most EFI tanks use baffle to keep fuel from quickly moving away during rapid changes in direction. When you have 3/4 to full tank fuel sock is always covered. Problem is much worst when gas level is below 1/4 level.
//RF
Old Oct 15, 2007 | 08:33 PM
ems2357's Avatar
//RF
how hard is it to replace a fuel tank?
Old Oct 15, 2007 | 11:02 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
hard
Old Oct 16, 2007 | 12:23 AM
RFmaster's Avatar
Car: 75 Beast
Well, yes it can be hard without a hydraulic jack and jack stands. Actually, if the tank is empty - I just support it with the jack and slowly lower it until filler neck clears. Having another pair of hands makes it much easier.
Warning! Make sure that you have all safety equipment handy - gas tanks are fire hazard especially empty ones. Plenty of ventilation and safety glasses.
//RF
Old Oct 16, 2007 | 05:34 PM
ems2357's Avatar
//RF
do u really have to take the rear end out?......
Old Oct 16, 2007 | 05:43 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
The rear end and exaust have to come off the car to get the tank out. There aren't a lot of options out there either, the baffled fuel tanks are hard to find, Just fill the car up more often. Easy solution.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
