can't romp on it....
Old Oct 28, 2007 | 04:42 PM
claysthe0ne's Avatar
My 92RS TBI(305) idles fine. I start it up and runs fine. I can drive it down the road, slowley accelerating. When I mash on the gas she starts acting likes she wants to die out. When I ler go of the pedal she goes back to normal. My timing is on, my plugs and wires are new, new distributor new cap,rotor. New tps, Iac, new 02 sensor. Any ideas. Fuel pressure is good. It's like the car is flooding out.
Old Oct 28, 2007 | 06:12 PM
jagone's Avatar
Re: can't romp on it....
I'm having the same prob right now. I have this also posted in the gen. tech/engine forum and had a couple replies. One said the timing may be retarded (which you said you checked), and the other said the Ignition control module. I'm posting from work so I haven't tried either one yet.
Old Oct 28, 2007 | 07:06 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Try replacing your fuel filter. I had the same problem at one time and that was the culprit.
Old Oct 28, 2007 | 08:20 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Im having the same problem right now too. Except mine happens alot when it rains. I tried replacing the coolant temp sensor, and I sanded the rust off of the little nubs on top of the distributor cap. So far today, it seems to be running better. But it usually runs good, and just picks certain days to act up. Almost left me stranded yesterday in the pouring rain. Wouldnt idle, wouldnt take any load under power even to slip the clutch at all. I pulled the vacuum hose for the MAP sensor, and it idled for a few seconds then smoothed out enough to drive home (albeit very slowly) but at least it hasnt left me stranded yet.
Old Nov 9, 2007 | 03:45 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Several years ago I had the same problem I was driving down the road went across some rr tracks when i accelerated all at once my car fell on its face and back fired. A buddy of mine runs a shop and and he kept the car for three days every day he went to work he took it out drove it and never got it to duplicate the problem. He suggested changing the ignition module to sse if that would fix it, and knock on wood she hasnt missed a lick since.
Old Nov 9, 2007 | 09:40 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Have you checked for a vacuum leak?
Old Nov 11, 2007 | 10:53 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yeah, do that.
Also consider replacing your EGR.
Old Nov 12, 2007 | 11:52 AM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
another thing i have ehard is a power relay im guessin for the injectors gives out because that happened to me in my g2500 van 350 tbi and i messed wit this relay and moved it around and it hasnt messed up knock on wood
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
5.SLOW
Theoretical and Street Racing
Jan 13, 2002 12:28 AM
87_Camaro
Nov 15, 2001 02:20 PM
speedfreaker
Nov 13, 2001 11:17 PM
poorboy8
Jul 31, 2000 09:50 PM
