any one familiar with this TBi spacer plate ?
I was thinking about putting a TBI spacer plate on my car i recently removed the stock air filter and installed an open element style along with a cat back exhasut on my 92 camaro rs 305. http://marine-performance-parts.com/...eanerstud.aspx
along with these new injctors http://marine-performance-parts.com/...ctorspair.aspx
any suggestions ???
any suggestions ???
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Re: any one familiar with this TBi spacer plate ?
That sounds over hyped, looks really thin at the "airfoil" part, and it outrageously priced. It would also be pointless if you were running a carb manifold.
It is supposed to either give the fuel more time to atomize, or give the air more velocoty. Don't know if it works or not, but if it does it probably wouldn't be noticable.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Actually I think I read on here that the CFMtech spacer is one of the better ones to get. Notice thats not an airfoil there, it is where the spacer allows the 2 bores to meet. Therefore allowing each half of the engine access to both throttle bores.
I really have no experience, never had one, just saying something I read somewhere. I was thinking about getting one along with an open element eventually.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
This is a close loock at your intake mainifod, as you can see there is already a opening from one bore to the other. I never tried that spacer but im shure it will not give you any real power.
http://www.cardomain.com/member_page...86_24_full.jpg
http://www.cardomain.com/member_page...86_25_full.jpg
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
But will the spacer make any difference in engine and or exhaust noise? I knew someone with a bored TB with a spacer on his 5.0 Mustang and it sounded like he had a turbo the sucking noise was so loud.
Engine: LO3
Personally, if I start working on the motor, im gonna buy the CFM tech spacer. I have heard both good and bad. Either way though, you will get the cool factor
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
